Analyzers
Community support for Analyzers (Intel VTune™ Profiler, Intel Advisor, Intel Inspector)
4963 Discussions
viewing the callgraph results
agabbin
I wrote a small script in perl which saves the results into a .html file, to be viewed by netscape etc.
Daniel_B_Intel2
how to use it?
agabbin
first save the output of vtl view:
vtl view >cg.txt
then run the script view.pl on the output file:
view.pl cg.txt
this will create a file called cg.txt.html and open it in netscape
jeffrey-gallagher
This is a great little script!
FYI only, on one system at LinuxWorld last month I had to actually invoke perl itself as well: probably something weird about the Linux installation, but worked like a champ:
$ perl view.pl cg.txt
cheers
jdg
