I met this error when I ran Inspector to detect memory problems:
This operating system is not supported. Suggestion: Check the Release Notes for a list of supported operating systems.
I did check the release notes, which says Windows7 and vs2013 are supported. There is anyting else I could do?
Thanks!
- Tags:
- CC++
- Debugging
- Development Tools
- Fortran
- Intel® Inspector
- Optimization
- Parallel Computing
- Vectorization
Hi Linwan - What do you get when you run winver from a command prompt? Also, do you get any error codes with the message?
Have you activated the OS yet?
Have you applied service pack 1?
