When the installation of Intel oneAPI Base Toolkit, v. 2022 (version 2022.1.2.154) proceeded to Intel DPC++ Compatibility Tool, my Windows 11 system froze and showed a blue screen with error code: DPC_WATCHDOG_VIOLATION. Before Intel DPC++ Compatibility Tool, the offline installer has already installed Intel Advisor, Intel oneAPI DPC++ Library, and Intel VTune(TM) Profiler. I tried to remove the installed components by Windows Install Clean Up and re-installed, however, there was still a blue screen. I viewed the Minidump file under C:\Windows\Minidump and analyzed the generated two dump files by Windbg Preview 1.2202.7001.0 (Administrator) using command `analyze -v`. The two dump files have the same results:
nt!KeBugCheckEx: fffff807`4be16220 48894c2408 mov qword ptr [rsp+8],rcx ss:0018:ffffbc00`b631a9f0=0000000000000133 2: kd> !analyze -v DPC_WATCHDOG_VIOLATION (133) The DPC watchdog detected a prolonged run time at an IRQL of DISPATCH_LEVEL or above. Arguments: Arg1: 0000000000000001, The system cumulatively spent an extended period of time at DISPATCH_LEVEL or above. The offending component can usually be identified with a stack trace. Arg2: 0000000000001e00, The watchdog period. Arg3: fffff8074c705330, cast to nt!DPC_WATCHDOG_GLOBAL_TRIAGE_BLOCK, which contains additional information regarding the cumulative timeout Arg4: 0000000000000000 Debugging Details: KEY_VALUES_STRING: 1 Key : Analysis.CPU.mSec Value: 3187 Key : Analysis.DebugAnalysisManager Value: Create Key : Analysis.Elapsed.mSec Value: 9285 Key : Analysis.Init.CPU.mSec Value: 577 Key : Analysis.Init.Elapsed.mSec Value: 31147 Key : Analysis.Memory.CommitPeak.Mb Value: 99 FILE_IN_CAB: 022322-17062-01.dmp DUMP_FILE_ATTRIBUTES: 0x1808 Kernel Generated Triage Dump BUGCHECK_CODE: 133 BUGCHECK_P1: 1 BUGCHECK_P2: 1e00 BUGCHECK_P3: fffff8074c705330 BUGCHECK_P4: 0 DPC_TIMEOUT_TYPE: DPC_QUEUE_EXECUTION_TIMEOUT_EXCEEDED BLACKBOXBSD: 1 (!blackboxbsd) BLACKBOXNTFS: 1 (!blackboxntfs) BLACKBOXPNP: 1 (!blackboxpnp) BLACKBOXWINLOGON: 1 CUSTOMER_CRASH_COUNT: 1 PROCESS_NAME: System STACK_TEXT: ffffbc00`b631a9e8 fffff807`4bcdb5ff : 00000000`00000133 00000000`00000001 00000000`00001e00 fffff807`4c705330 : nt!KeBugCheckEx ffffbc00`b631a9f0 fffff807`4bcdb211 : 00001a15`8a6caa8b ffffbc00`b6300180 ffff58e6`318cc154 fffff807`4bd98775 : nt!KeAccumulateTicks+0x20f ffffbc00`b631aa60 fffff807`4bcd8246 : 00000000`0025761b 00000000`00165426 00000059`50980180 00000000`00000000 : nt!KiUpdateRunTime+0x61 ffffbc00`b631aac0 fffff807`4bcd9552 : ffffab09`bd4ef750 00000000`00000000 fffff807`4c62b380 00000000`00000000 : nt!KiUpdateTime+0x686 ffffbc00`b631aeb0 fffff807`4bcd6e82 : ffffab09`bd4ef750 ffff8002`310aff50 ffff8002`00000000 00000000`00000002 : nt!KeClockInterruptNotify+0x272 ffffbc00`b631af40 fffff807`4bc8d720 : 00000059`50a80a9c ffff8002`310afea0 ffffbc00`b6a93970 00000000`00000000 : nt!HalpTimerClockInterrupt+0xe2 ffffbc00`b631af70 fffff807`4be17e2a : ffffab09`bd4ef7d0 ffff8002`310afea0 00000000`00000000 00000000`00000000 : nt!KiCallInterruptServiceRoutine+0xa0 ffffbc00`b631afb0 fffff807`4be183f7 : 00000000`bb37c832 00000000`00000001 00000000`00000000 fffff807`4bd59e4b : nt!KiInterruptSubDispatchNoLockNoEtw+0xfa ffffab09`bd4ef750 fffff807`4bc95e1c : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiInterruptDispatchNoLockNoEtw+0x37 ffffab09`bd4ef8e0 fffff807`4bc95de1 : fffff807`4c64d118 ffffbc00`b6300180 ffff4fef`3af39304 ffff4fef`00000002 : nt!KxWaitForSpinLockAndAcquire+0x2c ffffab09`bd4ef910 fffff807`4bf20b89 : 00000000`00000000 00000000`00000000 00000000`0108fda0 00000000`02d2fb34 : nt!KeAcquireSpinLockRaiseToDpc+0xc1 ffffab09`bd4ef940 fffff807`4c28d2b8 : 00000000`00000008 00000000`00000000 00000000`00000000 ffff8002`74aab1c0 : nt!HalpRegisterProfileSourceInterruptHandler+0x19 ffffab09`bd4ef970 fffff807`ac4b1dbc : ffff8002`736d6d00 ffff8002`5b22c080 00000000`779936e0 00000000`02d2fa0c : nt!HalpSetSystemInformation+0xabae8 ffffab09`bd4ef9a0 ffff8002`736d6d00 : ffff8002`5b22c080 00000000`779936e0 00000000`02d2fa0c 00000000`00d5c000 : vtss+0x1dbc ffffab09`bd4ef9a8 ffff8002`5b22c080 : 00000000`779936e0 00000000`02d2fa0c 00000000`00d5c000 00000000`00000000 : 0xffff8002`736d6d00 ffffab09`bd4ef9b0 00000000`779936e0 : 00000000`02d2fa0c 00000000`00d5c000 00000000`00000000 00000000`00000000 : 0xffff8002`5b22c080 ffffab09`bd4ef9b8 00000000`02d2fa0c : 00000000`00d5c000 00000000`00000000 00000000`00000000 fffff807`4be28775 : 0x779936e0 ffffab09`bd4ef9c0 00000000`00d5c000 : 00000000`00000000 00000000`00000000 fffff807`4be28775 ffff8002`724e2080 : 0x2d2fa0c ffffab09`bd4ef9c8 00000000`00000000 : 00000000`00000000 fffff807`4be28775 ffff8002`724e2080 ffff8002`54e99af0 : 0xd5c000 SYMBOL_NAME: vtss+1dbc MODULE_NAME: vtss IMAGE_NAME: vtss.sys STACK_COMMAND: .cxr; .ecxr ; kb BUCKET_ID_FUNC_OFFSET: 1dbc FAILURE_BUCKET_ID: 0x133_ISR_vtss!unknown_function OSPLATFORM_TYPE: x64 OSNAME: Windows 10 FAILURE_ID_HASH: {9bea1b25-7b12-a130-9e47-df6b77a6b755} Followup: MachineOwner ---------
It seems that the previously installed Intel VTune(TM) Profiler has some errors. After that, the installer could not be started after showing the icon.
The system information is:
Processor: Intel(R) Core(TM) i7-8750H CPU @ 2.20 GHz 2.21 GHz
Windows version: Windows 11 21H2
Operating system version: 22000. 493
Experience pack version: 1000.22000.493.0
System type: 64-bit operating system based on x64 processor
Visual Studio version: 17.1.0
(the previous similar post was marked as spam)
