Analyzers
5294 Discussions
vtss.sys led to a blue screen on Windows 10
Etienne_K_
hi,
whilst running the CPUz stress-test (http://www.cpuid.com/softwares/cpu-z.html) my system unexpectedly froze and the following bluescreen notified me that the culprit might have been vtss.sys:
SYSTEM_SERVICE_EXCEPTION (3b)
An exception happened while executing a system service routine.
Arguments:
Arg1: 00000000c0000094, Exception code that caused the bugcheck
Arg2: fffff80017192b72, Address of the instruction which caused the bugcheck
Arg3: ffffd00135eb3370, Address of the context record for the exception that caused the bugcheck
Arg4: 0000000000000000, zero.
Debugging Details:
SYSTEM_SKU:  SKU
SYSTEM_VERSION:  System Version
BIOS_DATE:  07/25/2014
BASEBOARD_PRODUCT:  SABERTOOTH X79
BASEBOARD_VERSION:  Rev 1.xx
BUGCHECK_P1: c0000094
BUGCHECK_P2: fffff80017192b72
BUGCHECK_P3: ffffd00135eb3370
BUGCHECK_P4: 0
EXCEPTION_CODE: (NTSTATUS) 0xc0000094 - {EXCEPTION}  Integer division by zero.
FAULTING_IP:
vtss+12b72
fffff800`17192b72 c3              ret
CONTEXT:  ffffd00135eb3370 -- (.cxr 0xffffd00135eb3370)
rax=0000000000020000 rbx=fffff800a6d7a1f0 rcx=0000000000001004
rdx=0000000000080004 rsi=000000003f0f4a01 rdi=0000000000020001
rip=fffff80017192b72 rsp=ffffd00135eb3d98 rbp=0000000000000401
 r8=ffffe0013f0f4a01  r9=ffffe0013f0f4a60 r10=ffffd0012ede6260
r11=ffffd00135eb3de8 r12=ffffd00135eb43a0 r13=0000000000080004
r14=0000000000000286 r15=0000000000001004
iopl=0         nv up di pl nz na pe nc
cs=0010  ss=0018  ds=002b  es=002b  fs=0053  gs=002b             efl=00000002
vtss+0x12b72:
Resetting default scope
CPU_COUNT: c
CPU_MHZ: c82
CPU_VENDOR:  GenuineIntel
CPU_FAMILY: 6
CPU_MODEL: 2d
CPU_STEPPING: 7
DEFAULT_BUCKET_ID:  WIN8_DRIVER_FAULT
BUGCHECK_STR:  0x3B
PROCESS_NAME:  cpuz_x64.exe
CURRENT_IRQL:  0
ANALYSIS_VERSION: 10.0.10240.9 amd64fre
LAST_CONTROL_TRANSFER:  from fffff8001718f543 to fffff80017192b72
STACK_TEXT:
ffffd001`35eb3d98 fffff800`1718f543 : fffff800`a6d7a1e0 fffff800`163ab8c6 ffffd001`35eb43a0 ffffe001`00000001 : vtss+0x12b72
ffffd001`35eb3da0 fffff800`a6ed7ebd : fffff800`a6d7a1f0 ffffd001`35eb4150 ffffe001`3e4adac0 00000000`00000002 : vtss+0xf543
ffffd001`35eb3e30 fffff800`a6ed5390 : ffffe001`392fd840 00000000`00000000 ffffe001`378b3701 ffffd001`35eb40b0 : nt!PspInsertThread+0x63d
ffffd001`35eb4050 fffff800`a6ed4f79 : ffffd001`35eb4420 ffffd001`35eb4920 00000000`00000001 ffffd001`35eb43e0 : nt!PspCreateThread+0x288
ffffd001`35eb4310 fffff800`a6b75863 : 00000000`00000000 fffff800`a6ed2e9e 00000000`0048fe78 00000000`0000000c : nt!NtCreateThreadEx+0x201
ffffd001`35eb4a90 00007ffe`f365402a : 00007ffe`f02898b6 00000000`00000001 00000000`00000000 00000000`00000000 : nt!KiSystemServiceCopyEnd+0x13
00000000`0048f998 00007ffe`f02898b6 : 00000000`00000001 00000000`00000000 00000000`00000000 00000000`00000000 : ntdll!NtCreateThreadEx+0xa
00000000`0048f9a0 00007ffe`f15abc5c : 00000000`00000004 00000001`40083250 00000000`00000120 00007ffe`f02c2c0f : KERNELBASE!CreateRemoteThreadEx+0x276
00000000`0048fe20 00000001`40022f8a : 00000000`00000005 00000001`7ee52e84 00000000`00000000 00000000`00000000 : KERNEL32!CreateThreadStub+0x3c
00000000`0048fe70 00000001`40002d87 : 00000000`00d19810 00000000`00000000 00000000`00d19810 00000000`ffffffff : cpuz_x64+0x22f8a
00000000`0048ff20 00007ffe`f15a2d92 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : cpuz_x64+0x2d87
00000000`0048ff60 00007ffe`f35c9f64 : 00007ffe`f15a2d70 00000000`00000000 00000000`00000000 00000000`00000000 : KERNEL32!BaseThreadInitThunk+0x22
00000000`0048ff90 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : ntdll!RtlUserThreadStart+0x34
FOLLOWUP_IP:
vtss+12b72
SYMBOL_STACK_INDEX:  0
SYMBOL_NAME:  vtss+12b72
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: vtss
IMAGE_NAME:  vtss.sys
DEBUG_FLR_IMAGE_TIMESTAMP:  55c4d1c4
STACK_COMMAND:  .cxr 0xffffd00135eb3370 ; kb
BUCKET_ID_FUNC_OFFSET:  12b72
FAILURE_BUCKET_ID:  0x3B_vtss!Unknown_Function
PRIMARY_PROBLEM_CLASS:  0x3B_vtss!Unknown_Function
ANALYSIS_SOURCE:  KM
FAILURE_ID_HASH_STRING:  km:0x3b_vtss!unknown_function
FAILURE_ID_HASH:  {739a51cd-f64b-01d1-9bcb-25792e387d80}
Followup:     MachineOwner
6: kd> lmvm vtss
Browse full module list
start             end                 module name
fffff800`17180000 fffff800`17242000   vtss       (no symbols)
    Loaded symbol image file: vtss.sys
    Image path: \SystemRoot\system32\drivers\vtss.sys
    Image name: vtss.sys
    Browse all global symbols  functions  data
    Timestamp:        Fri Aug 07 17:41:56 2015 (55C4D1C4)
    CheckSum:         00020719
    ImageSize:        000C2000
    Translations:     0000.04b0 0000.04e4 0409.04b0 0409.04e4
I am using the latest Intel Parallel Studio XE 2016 Prof. and have a 33GB memorydump for you should it be necessary.
Bernard
Valued Contributor I
Can you run .cxr 0xffffd00135eb3370  command in order to display exception context?
Bernard
Can you run also following command: ln fffff800`17192b72 and this one u@rip and this ub@rip L8,  these will display call stack around faulting IP (RIP register)
Etienne_K_
Sorry for opening two posts, but one post was kept in moderation for some reason...
6: kd> ln fffff800`17192b72
Browse module
Set bu breakpoint
6: kd> u @rip
nt!KeBugCheckEx:
fffff800`a6b6b240 48894c2408      mov     qword ptr [rsp+8],rcx
fffff800`a6b6b245 4889542410      mov     qword ptr [rsp+10h],rdx
fffff800`a6b6b24a 4c89442418      mov     qword ptr [rsp+18h],r8
fffff800`a6b6b24f 4c894c2420      mov     qword ptr [rsp+20h],r9
fffff800`a6b6b254 9c              pushfq
fffff800`a6b6b255 4883ec30        sub     rsp,30h
fffff800`a6b6b259 fa              cli
fffff800`a6b6b25a 65488b0c2520000000 mov   rcx,qword ptr gs:[20h]
6: kd> ub @rip L8
nt!KiBugCheckReturn:
fffff800`a6b6b234 e807000000      call    nt!KeBugCheckEx (fffff800`a6b6b240)
fffff800`a6b6b239 90              nop
fffff800`a6b6b23a cc              int     3
fffff800`a6b6b23b cc              int     3
fffff800`a6b6b23c cc              int     3
fffff800`a6b6b23d cc              int     3
fffff800`a6b6b23e cc              int     3
fffff800`a6b6b23f cc              int     3
And the command from your first post:
6: kd> .cxr 0xffffd00135eb3370
vtss+0x12b72:
Bernard
Hi Etienne,
Thank you for running those commands unfortunately their output points to KeBugCheckExe routine which was executing on CPU(core) #6.
In order to dump assembly content of vtss driver please run these commands: ub fffff800`17192b72 and u fffff800`17192b72. These commands should helpfully show the code which probably caused BugCheck.
Bernard
By looking at the call stack I suspect more CPUz utillity in causing that BugCheck. It seems that CPUz created and injected remote thread into address space of vtss driver.
Etienne_K_
6: kd> ub fffff800`17192b72
vtss+0x12b53:
fffff800`17192b53 488badd8000000  mov     rbp,qword ptr [rbp+0D8h]
fffff800`17192b5a 4881c4e8000000  add     rsp,0E8h
fffff800`17192b61 f644240801      test    byte ptr [rsp+8],1
fffff800`17192b66 7403            je      vtss+0x12b6b (fffff800`17192b6b)
fffff800`17192b68 0f01f8          swapgs
fffff800`17192b6b 48cf            iretq
fffff800`17192b6d 0f1f00          nop     dword ptr [rax]
fffff800`17192b70 cd00            int     0
6: kd> u fffff800`17192b72
vtss+0x12b72:
fffff800`17192b73 66666666660f1f840000000000 nop word ptr [rax+rax]
fffff800`17192b80 65488b042588010000 mov   rax,qword ptr gs:[188h]
fffff800`17192b89 488b90b8000000  mov     rdx,qword ptr [rax+0B8h]
fffff800`17192b90 488d8a78040000  lea     rcx,[rdx+478h]
fffff800`17192b97 48f7411800ffffff test    qword ptr [rcx+18h],0FFFFFFFFFFFFFF00h
fffff800`17192b9f 7503            jne     vtss+0x12ba4 (fffff800`17192ba4)
fffff800`17192ba1 33c0            xor     eax,eax
Ah ok, the problem is, I randomly also got a MACHINE_CODE_EXCEPTION bluescreen and the system crashed so hard that I couldnt get a memory dump. Afterwards I saw a vtss.sys error and I thought that maybe there would be something wrong with vtss which also led to the MACHINE_CODE_EXCEPTION.
I have since removed vtss from the workstation and I have not experienced any MACHINE_CODE_EXCEPTIONs
Bernard
Is this MACHINE_CHECK_EXCEPTION or MACHINE_CODE_EXCEPTION type of BugCheck?
Etienne_K_
Sorry, it should have been MACHINE_CHECK_EXCEPTION.
Bernard
MACHINE_CHECK_EXCEPTION is always related to critical hardware fault and it seems strange that vtss could cause that. Anyway I am glad that your issue has been solved by removing vtss.
I advise you to contact Intel Premium Support in order to get help.
Bernard
Can you post  MACHINE_CHECK_EXCEPTION info as displayed by windbg?
Etienne_K_
Sadly not, because when I had MACHINE_CHECK_EXCEPTION Windows wasn't able to write a MEMDUMP :S :/
Bernard
Do you have still that BugCheck even after removing vtss?
I still cannot understand how vtss can cause of course indirectly MACHINE_CHECK_EXCEPTION
Etienne_K_
I removed vtss 2 days ago, and so far I had no BugChecks :/
Bernard
@Peter
Have you ever came across an issue where vtss caused MACHINE_CHECK_EXCEPTION BugCheck?
Peter_W_Intel
I haven't heard this from others, before. Sorry.
You may use "amplxe-sepreg.exe -u" to unload drivers to avoid this, if this was caused by vtss and/or vtsspp drivers. Was it caused by resource limitation (memory)? Sometime rebooting system is required, then run "amplxe-sepreg.exe -i ".
Please try 2016 version, if you met this again - please send crash report by using:
>amplxe-feedback -create-bug-report <report archive>
>amplxe-feedback -send-crash-report=<report archive>
