Analyzers
5307 Discussions
vtune: Error: Assertion failed: pytrace_event_handler
smita
Dear VTune Support Team,
I am running vtune_profiler_2020.0.0.605129 and having the following issue:
AMPLXE_TPSSCOLLECTOR: pytrace_event_handler:1038: registered == tpss_thread_manager_op_err_ok || registered == tpss_thread_manager_op_err_thread_found : Cannot register pytrace thread, result: 3
Assertion failed: pytrace_event_handler:1038: registered == tpss_thread_manager_op_err_ok || registered == tpss_thread_manager_op_err_thread_found : Cannot register pytrace thread, result: 3. Please contact the technical support.
In some of the attempts  there is no error if I run same job multiple times. Would you please suggest a solution.
Best,
Smita
Aleksei_O
Could you please download VTune 2020 Update 2, which is the latest public available,  profile and then let my know if the problem persists.
JananiC_Intel
We are forwarding the case to SME.
Aleksei_O
Hello Smita,
Thank you for your question.
What OS did you run Vtune on?
What analysis did you run?
Which app did you use, could we see and try it ourselves?
(Please could you provide the version of Python you were using)
Aleksei
smita
Hello Aleksei,
I am running MadGraph5_aMC@NLO (https://launchpad.net/mg5amcnlo) on linux.
Python 2.7.5
[GCC 4.8.5 20150623 (Red Hat 4.8.5-39)] on linux2
Best,
Smita
Aleksei_O
Hello Smita,
Can I ask you to profile your workload with VTune 2020 U2?
smita
I am working with:
which vtune
/opt/intel/vtune_profiler_2020.0.0.605129/bin64/vtune
Best,
Smita
Aleksei_O
Kevin_O_Intel1
We will need the information requested by Aleksei to make progress on this issue.
Thanks!
