Analyzers
vtune_amplifier_2019_update4's Prerequisite
applemax82
I install vtune_amplifier_2019_update4 on centos 7.2. And below is the message about Missing Prerequisite:
Prerequisites > Missing Prerequisite(s)
There are one or more unresolved issues based on your system configuration and
component selection.
You can resolve all the issues without exiting the installer and re-check, or
you can exit, resolve the issues, and then run the installation again.
Missing optional prerequisites
-- The installed version of the Network Security Services library is not
supported
-- Kernel source directory is not found. Sampling driver cannot be built.
   1. Skip prerequisites [ default ]
   2. Show the detailed info about issue(s)
   3. Re-check the prerequisites
   h. Help
   b. Back
   q. Quit installation
Please type a selection or press "Enter" to accept default choice [ 1 ]:
What's the required minimum version of Network Security Services library?
Thanks!
Andrew
Ekaterina_L_Intel
Hi Andrew,
VTune Amplifier requires Network Security Services library (v3.22 or higher)
Regards, Katya
