Application Acceleration With FPGAs
Programmable Acceleration Cards (PACs), DCP, FPGA AI Suite, Software Stack, and Reference Designs
477 Discussions
Arria 10 Transceiver Register Map(UG-01143 )にて 詳細機能をレジスタにて変更できると理解しています。 もし理解が正しい場合、いくつか設定したい項目があるのですが、 具体的な変更手順をご教示いただけないでしょうか。 例えば、a10_registermap.xlsxのExtended Register mapのAddress:C.0x120 vcm_sel を変更したいのです。 お手数をおかけいたしますが、宜しくお願い致します。
章安部井0
Deshi_Intel
hi,
I presume you are referring to Arria 10 NativePHY IP. In the IP, there is reconfiguration bus interface that user can use to access the register read/write of transceiver channel.
reconfiguration bus interface is build base on Altera Avalon Memory Map interface.
dlim
章安部井0
Dear dlim
this is abei.
thank you for your answer.
I will study control using the Avalon bus based on the information by your answer.
If it is difficult for us, please support.
BR
Deshi_Intel
HI Abei,
Sure, I will do my best to help you.
Deshi
Deshi_Intel
HI Abei,
I have not hear back from you for some time.
For now, I am setting this case to closure first.
Feel free to file new forum thread if you have any enquiry in future.
dlim
章安部井0
Dear dlim
this is abei.
I'm sorry , I delayed repry.
I tried changing the XCVR register settings.
I was able to adjust the offset voltage.
Thank you very much.
BR
Deshi_Intel
HI Abei,
No problem. It's good to know you are getting thing working in your project.
Alright, I am setting this case back to closure.
Feel free to file new forum thread if you have enquiry in future.
dlim
