Load the temporary MAX10 image fail as below information:
[root@localhost intelrtestack]# sudo fpgasupdate /usr/share/opae/d5005/one-time-update/darby_max10*.bin
[2020-03-24 20:39:50,386] [WARNING ] Update starting. Please do not interrupt.
[2020-03-24 20:39:50,403] [ERROR ] Failed to find secure device for PAC 0000:18:00.0
You are currently using a 2.0 pre-beta version, as per table 3 in the link below. You have to upgrade it to 2.0 version first before upgrade to v2.0.1.
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug-qs-ias-d5005.pdf
Regards -SK
Thanks for your comment. I will have a try with 2.0 version.
I will set this case to close-pending for now. Please do not hesitate to get back to me within the next 20-day close-pending period if more help is needed.
Regards -SK
