Application Acceleration With FPGAs
Programmable Acceleration Cards (PACs), DCP, FPGA AI Suite, Software Stack, and Reference Designs
504 Discussions
Difficulty with SSH key instructions
ydaglian
Hi all,
First of all, thanks for helping me. I'm an Intel employee in Intel Brazil and I'm trying to use the FPGA DevCloud.
After following the instructions on github, I'm stuck and need help to proceed.
I've completed every step until section "3.3 - Downloading a SSH key". I can't execute the commands on instruction 5:
Instruction 5 on section "3.3 - Downloading an SSH key"Instruction 5 on section "3.3 - Downloading an SSH key"
If I try the command "Host devcloud", mobaterm shows the error "Host: command not found". I didn't create a file called "config", and neither can I find a directory on my PC.
Could you please help me?
Thank you a lot!
HRZ
Valued Contributor III
You should first create a folder named ".ssh" in your "home" directory, then create a file named "config" inside that folder, and then add those lines inside that file.
HRZ
ydaglian
Thank you, that was it!
I had to learn a little bit of Linux terminal commands to do it, but your answer helped me to know what to search for!
I believe the commands should be stated in the DevCloud tutorial. It could help other users.
JohnT_Intel
The directory information was mention in Chapter 3.2.
May I know if the issue is resolved?
ydaglian
Hi John,
Thank you!
Yes, the issue is resolved.
