Application Acceleration With FPGAs
Programmable Acceleration Cards (PACs), DCP, FPGA AI Suite, Software Stack, and Reference Designs
Double buffering
ADua0
I am trying to implement double buffering for my code, but somehow it leads to data dependency which I am not able to resolve.
Here is piece of my code:
float __attribute__((register)) sum[12];
float __attribute__((register)) sum1[2][48];
float __attribute__((register)) sum2[12];
float __attribute__((register)) sum3[2][48];
float __attribute__((register)) sum5[12];
float __attribute__((register)) sum6[2][48];
float __attribute__((register)) sum7[12];
float __attribute__((register)) sum8[2][48];
int iter = input_height * window * window;
int index =0;
sum_struct sum4;
sum_struct sum9, sum10, sum11, sum12, sum21, sum22, sum23,sum24;
int flag=0;
int inputWidth1 = inputWidth-2;
while (index != iter)
 index++;
for(int r =0 ; r<3*kernel_width; r++)
for(int y=0;y<2; y++)
 #pragma unroll
for(int j=0;j<6;j++)
   sum[j] = sum[j+6];
   sum2[j] = sum2[j+6];
  sum9 = read_channel_intel(c8);
  sum10 = read_channel_intel(c9);
  sum[11] = sum9[5];
  sum[10] = sum9[4];
  sum[9] = sum9[3];
  sum[8] = sum9[2];
  sum[7] = sum9[1];
  sum[6] = sum9[0];
  sum2[11] = sum10[5];
  sum2[10] = sum10[4];
  sum2[9] = sum10[3];
  sum2[8] = sum10[2];
  sum2[7] = sum10[1];
  sum2[6] = sum10[0];
 // flag= read_channel_intel(c16);
#pragma unroll
for(int i=0;i<12;i++)
sum1[index & 0x01][47-i] +=sum[11-i];
sum3[index & 0x01][47-i] +=sum2[11-i];
       int e5=0;
       int e10 =0;
       for(int y=0;y<pool_width2;y++)
        if( y<6)
        e5 = e1 + (y) * inputWidth1;
        sum4.dat[0]= sum1[index & 0x01][ (y)* pool_width+0];
        sum4.dat[1] = sum1[index & 0x01][ (y)* pool_width+1];
        sum4.dat[2] = sum1[index & 0x01][ (y)* pool_width+2];
        sum4.dat[3] = sum1[index & 0x01][ (y)* pool_width+3];
        sum4.dat[4] = sum1[index & 0x01][ (y)* pool_width+4];
        sum4.dat[5] = sum1[index & 0x01][ (y)* pool_width+5];
       else
        e5 = e2+ (y-6) * inputWidth1;
        sum4.dat[0] = sum3[index & 0x01][ (y-6)* pool_width+0];
        sum4.dat[1] = sum3[index & 0x01][ (y-6)* pool_width+1];
        sum4.dat[2] = sum3[index & 0x01][ (y-6)* pool_width+2];
        sum4.dat[3] = sum3[index & 0x01][ (y-6)* pool_width+3];
        sum4.dat[4] = sum3[index & 0x01][ (y-6)* pool_width+4];
        sum4.dat[5] = sum3[index & 0x01][ (y-6)* pool_width+5];
Any suggestions on how to effectively implement double buffering will be really helpful
FawazJ_Altera
Hello, I will go through your code and let you know the feedback Thanks
ADua0
