Application Acceleration With FPGAs
Programmable Acceleration Cards (PACs), DCP, FPGA AI Suite, Software Stack, and Reference Designs
Enabling Hugepages
rj29
Respected sir/madam,
Can you please guide me in enabling hugepages in my intel devcloud node. This is because the following command, sudo sh -c "echo 2 > /sys/kernel/mm/hugepages/hugepages-1048576kB/nr_hugepages" which was given in the official document of streaming_dma_afu, is not working as the usage of "sudo" is not allowed in the devcloud node.
I request you to give an alternative to enabling hugepages.
Thanking you,
yours truely
EricMunYew_C_Intel
May I know which document you followed?
EricMunYew_C_Intel
Hi, unfortunately we couldn't grant you the admin right, however you may run it on your local installation.
