Application Acceleration With FPGAs
Programmable Acceleration Cards (PACs), DCP, FPGA AI Suite, Software Stack, and Reference Designs
504 Discussions
How OpenCL SDK memory access code is mapped to SDRAM ?
RElna
I was wondering if someone can guide me on how opencl sdk operations are mapped to memory. For example, if we define a global buffer input data variable, would this be mapped to SDRAM or FPGA RAMs ?
Also, if it is mapped to SDRAM, which interconnect is used for the connection (e.g., FPGA-to-HPS SDRAM or FPGA-to HPS bridge ?
How can we differentiate and specify these connections ?
Rana
HRZ
Valued Contributor III
Global buffers are mapped to the FPGA on-board DDR memory. All other buffers are mapped to either Block RAMs or registers depending on their size and access pattern.
Maybe someone else can answer your second question.
RElna
Thanks for your reply. Can you guide me to a reference where I can read more about the mappings ? I have searched online a lot and I could not find a definite answer.
I also would like to know how to access HPS SDRAM from the opencl code.
HRZ
