Application Acceleration With FPGAs
Programmable Acceleration Cards (PACs), DCP, FPGA AI Suite, Software Stack, and Reference Designs
504 Discussions
I can't compile example to test in node
DeusMMJr
Hi, I'm trying to compile an example in node 189 but the tool reported te following error!
u28549@s001-n189:~/examples_aoc/hello_world$ aoc -board=pac_s10_dc device/hello_world.cl -o bin/hello_word.aocx -report -v
aoc: Environment checks are completed successfully.
aoc: Cached files in /var/tmp/aocl/ may be used to reduce compilation time
You are now compiling the full flow!!
aoc: Selected target board pac_s10_dc
aoc: Running OpenCL parser....
aoc: OpenCL parser completed successfully.
aoc: Linking Object files....
aoc: Optimizing and doing static analysis of code...
aoc: Linking with IP library ...
Checking if memory usage is larger than 100%
aoc: First stage compilation completed successfully.
Compiling for FPGA. This process may take a long time, please be patient.
Error (18640): The Quartus Partition Database File '/home/u28549/examples_aoc/hello_world/bin/hello_word/build/dcp.qdb' was generated using version 'Version 18.1.2 Build 277 02/12/2019 SJ Pro Edition', which cannot be read by the current version of the Quartus Prime software. Regenerate '/home/u28549/examples_aoc/hello_world/bin/hello_word/build/dcp.qdb' using the current version of the Quartus Prime Software.
Error (19296): Cannot load none snapshot - ensure the design has been compiled through all earlier stages.
Error (19829): dcp.qdb cannot be assigned. The dcp.qdb file is missing Partial Reconfiguration or Reserved Core subpartitions and assigned to the root partition. In order to assign a QDB file to the root partition, it must be created from a design using Partial Reconfiguration or Reserved Core subpartitions. To correct this error, ensure that the creation and assignment of the QDB is correct.
Error: Flow failed:
Error (23035): Tcl error: ERROR: Error(s) found while running an executable. See report file(s) for error message(s). Message log indicates which executable was run last.
Error (23031): Evaluation of Tcl script s10_partial_reconfig/flow.tcl unsuccessful
Error: Quartus Prime Shell was unsuccessful. 6 errors, 198 warnings
Error (16546): Cannot load final database - ensure all earlier stages of the compiler have completed.
Error (17941): The design could not be loaded due to errors.
Error (23031): Evaluation of Tcl script scripts/adjust_plls_mcp.tcl unsuccessful
Error: Quartus Prime Shell was unsuccessful. 4 errors, 0 warnings
Error: Compiler Error, not able to generate hardware
FawazJ_Altera
May I know which aocl version do you use?
Furthermore,which quartus version?
thanks
DeusMMJr
Intel(R) FPGA SDK for OpenCL(TM), 64-Bit Offline Compiler
Version 18.1.0 Build 222 Pro Edition
Copyright (C) 2018 Intel Corporation
Quartus
Version=18.1.0.222
Edition=pro
HRZ
Valued Contributor III
Your BSP is for Quartus v18.1.2, but you are using Quartus v18.1.0 to compile. Update your Quartus to v18.1.2. Or better yet install Quartus v19.2 and use the new devstack v2.0.1:
https://www.intel.com/content/www/us/en/programmable/products/boards_and_kits/dev-kits/altera/intel-fpga-pac-d5005/getting-started.html
DeusMMJr
Hi! Thanks by your reponse. The node administer already solve this issue.
FawazJ_Altera
My apologize for the late reply from our internal teams, I am still investigating the root cause behind this issue, once I get a reply, I will let you know. The delay due to holidays season.
Thank you
DeusMMJr
Hi FJumaah, the administer solved this issue updating environment. Thanks a lot!
