Application Acceleration With FPGAs
Programmable Acceleration Cards (PACs), DCP, FPGA AI Suite, Software Stack, and Reference Designs
IDV Tool
jones2
According to the operation steps indicated by the 576087 document, the following two problems occur during the use of IDV Tool, and the attachment is the problem screenshot.
1. Just collect the signals of the first 4 roads. The signals in the latter road are not collected or collected. There are only some peak signals;
2. The voltage level information and actual measurement values ​​in the collected 4 -channel signal are not in line with the actual measurement value, and the setting value does not meet.
Farabi
We need to know what device are you measuring? Do you know the part number?
regards,
Farabi
Farabi
What is the FPGA part number you are using? For example, Stratix 10, Agilex, MAX10 etc.
We need this information to help you.
regards,
Farabi
Farabi
As there is no response from your side, I am closing this case.
regards,
Farabi
