是使用方法不正确?
May I know if you have program the bitstream with the SignalTap enabled? If no, you will need to program it before you are able to run the SignalTap.
Hi JohnT,
1, I check the filelist_mode_0_stp.txt as below
+define+INCLUDE_REMOTE_STP
C:filelist_mode_0.txt
QI:../par/${OPAE_PLATFORM_FPGA_FAMILY}/extra_tcl-0_stp.tcl
../par/nlb_0_stp.sdc
2, Also I check the filelist_base.txt
+define+BIST_AFU
nlb_400.json
test_sw1.sv
test_rdwr.sv
test_lpbk1.sv
nlb_lpbk.sv
nlb_csr.sv
nlb_C1Tx_fifo.sv
ccip_std_afu.sv
ccip_interface_reg.sv
ccip_debug.sv
nlb_gram_sdp.v
platform/${OPAE_PLATFORM_FPGA_FAMILY}/local_mem.sv
resync.v
altera_std_synchronizer_nocut.v
QSYS_IPs/${OPAE_PLATFORM_FPGA_FAMILY}/RAM/req_C1TxRAM2PORT.qsys
QSYS_IPs/${OPAE_PLATFORM_FPGA_FAMILY}/RAM/lpbk1_RdRspRAM2PORT.qsys
include_files/common
../par/stp_basic.stp
which means, signaltap remote debug has been enabled .
above file including gbs, txt,tcl,stp are unchanged vendor original design example.
just can not active stp according the vendor's example.
thanks
jim
Do you program your FPGA using sof file? What is the you use to run the SignalTap?
Hi JohnT,
In windows side, we did not download any sof via signaltap GUI. because that is not mentioned in the manual.
I was trying to duplicate the original example on 6.1 remote signal tap setup and use. but failed.
I put what I have done here for reference, maybe I miss out something.
we create project as below using filelist_mode_0_stp.txt
[root@fig01 nlb_mode_0_stp]# afu_synth_setup --source hw/rtl/filelist_mode_0_stp.txt build_synth
Copying build from /root/inteldevstack/a10_gx_pac_ias_1_2_pv/hw/lib/build...
Set OPAE_PLATFORM_FPGA_FAMILY to A10
Configuring Quartus build directory: build_synth/build
Loading platform database: /root/inteldevstack/a10_gx_pac_ias_1_2_pv/hw/lib/platform/platform_db/a10_gx_pac_hssi.json
Loading platform-params database: /usr/share/opae/platform/platform_db/platform_defaults.json
Loading AFU database: /usr/share/opae/platform/afu_top_ifc_db/ccip_std_afu_avalon_mm.json
Loading parent database: ccip_std_afu
Loading AFU database: /usr/share/opae/platform/afu_top_ifc_db/ccip_std_afu.json
Writing platform/platform_afu_top_config.vh
Writing platform/platform_if_addenda.qsf
Writing ../hw/afu_json_info.vh
Open Quartus as below
[root@fig01 nlb_mode_0_stp]# cd build_synth/build
[root@fig01 build]# quartus dcp.qpf
Once the Intel Quartus Prime Pro Edition GUI opens, open the dcp.qpf project file
Click assignment->Revisions->new revisions-> create a new revision afu_dev based in the revioson afu_synth and the afu_dev will automatically being set up as current version
Quartus GUI->Processing->Start->Start Analysis & Elaboration processing may take several minutes to finish without error
under Project Navigator,switch page from Hierarchy to Files and double click stp_basic.stp to check ,nothing wrong founded.
close the stp_basic.stp and you will be asked do you want to save your changes? click yes or no both are ok. Do you want to enable current signaltap file for the current project? click yes
Close Quartus
[root@fig01 build]# cd ..
[root@fig01 build_synth]# run.sh
project was be build successfully.
the last part of compilation is shared as below
Info (23030): Evaluation of Tcl script ./a10_partial_reconfig/report_timing.tcl was successful
Info: Quartus Prime TimeQuest Timing Analyzer was successful. 0 errors, 176 warnings
Info: Peak virtual memory: 5475 megabytes
Info: Processing ended: Fri Mar 6 14:10:23 2020
Info: Elapsed time: 00:01:07
Info: Total CPU time (on all processors): 00:02:03
Info (19538): Reading SDC files took 00:00:12 cumulatively in this process.
Wrote nlb_400.gbs
PR AFU compilation complete
AFU gbs file is 'nlb_400.gbs'
Design meets timing
one thing I am quite confused was this compilation updated nlb_400.gbs file , i thought it should regenerate $OPAE_PLATFORM_ROOT/hw/samples/nlb_mode_0_stp/bin/nlb_mode_0_stp.gbs , but not.
and I have checked the nlb_mode_0_stp.gbs, and found that file was be updated based on modified time.
in linux side, we did like below
[root@fig01 build_synth]# sudo fpgaconf -B 0XD8 -D 00 -F 00 $OPAE_PLATFORM_ROOT/hw/samples/nlb_mode_0_stp/bin/nlb_mode_0_stp.gbs
[root@fig01 build_synth]# sudo mmlink -P 3333 -B 0XD8
------- Command line Input START ----
Bus : 216
Device : -1
Function : -1
Socket-id : -1
Port : 3333
IP address : 0.0.0.0
------- Command line Input END ----
PORT Resource found.
Remote STP : Assert Reset
Remote STP : De-Assert Reset
Read signature value 53797343 to hw
Read version value 1 to hw
Read write fifo capacity value 32 to hw
m_listen: 4
listening on ip: 0.0.0.0; port: 3333
in windows side, we did like below
cmd
cd D:\Jimlin\FPGA\devkits\PACArria10GX\example\nlb_mode_0_stp
D:\Jimlin\FPGA\devkits\PACArria10GX\example\nlb_mode_0_stp>system-console --rc_script=mmlink_setup_profiled.tcl remote_debug.sof 192.168.111.210 3333
and then we see the system-console GUI will launch and communicate with debug target until it print Remote system ready.
same time I could see new text kept updating from LINUX terminal side,seems handshake communication between host and target was success.
then we open stp_basic.stp was able to choose “System Console on … Sld Hub Controller System and jtag is reday.but keep asking me to program device to continue as in the firt picture.
also there is warning
Error(261009): Cannot run Signal Tap Logic Analyzer. Signal Tap File is not compatible with the file programmed in your device. The expected compatibility checksum value is 0x76AF59AF; the value read from your device is 0x9DDC57FD
hope this can give you a whole picture .
any other thing we can try ,please let me know
thanks
Jim
one spelling mistake
one thing I am quite confused was this compilation updated nlb_400.gbs file , i thought it should regenerate $OPAE_PLATFORM_ROOT/hw/samples/nlb_mode_0_stp/bin/nlb_mode_0_stp.gbs , but was not.
and I have checked the nlb_mode_0_stp.gbs, and found that file was NOT be updated based on modified time.
Please performed "sudo fpgaconf -B 0XD8 -D 00 -F 00 <build_synth dir>/nlb_400.gbs.gbs" before running the stp file.
Jo JohnT,
thanks for your suggestion.
Following your suggestion, performed "sudo fpgaconf -B 0XD8 -D 00 -F 00 <build_synth dir>/nlb_400.gbs.gbs" before running the stp file.
linux side :
[root@fig01 build_synth]# fpgaconf -B 0XD8 -D 00 -F 00 $OPAE_PLATFORM_ROOT/hw/samples/nlb_mode_0_stp/build_synth/nlb_400.gbs
Bus : 216
Device : -1
Function : -1
Socket-id : -1
Port : 3333
m_listen: 4
I have 1 connections now; latest socket is 5
5: binding first connection
5: Accepted connection request from 192.168.111.204
I have 2 connections now; latest socket is 6
6: Accepted connection request from 192.168.111.204
mmlink_connection::handle_management_command('HANDLE 00000001')
6: accepted handle value (' HANDLE 00000001'), setting to bound state
5: handle_receive() returned -1, closing connection, now have 1
6: handle_receive() returned -1, closing connection, now have 0
mmlink_connection::handle_management_command('HANDLE 00000002')
6: accepted handle value (' HANDLE 00000002'), setting to bound state
mmlink_connection::handle_management_command('RESET 1')
Write reset value 1 to hw
mmlink_connection::handle_management_command('RESET 0')
Write reset value 0 to hw
mmlink_connection::handle_management_command('ENABLE 1 1')
Enable channel 257 to hw
6: converted to data
windows side
then we open stp_basic.stp was able to choose “System Console on … Sld Hub Controller System and jtag is reday.but keep asking me to program device to continue as in the first picture.
also there is error.
Error(261005): Can't find the instance. Download a design with SRAM Object File containing this instance.
so I think nlb_400.gbs.gbs has no stp file included.
I go back to check afu.qsf
I have NOT found below assignment,which is used to enale REMOTE SIGNALTAP
set_global_assignment -name ENABLE_SIGNALTAP ON
set_global_assignment -name USE_SIGNALTAP_FILE ../hw/par/A10/stp_basic.stp
that 2 assignments suppose be to added to AFU.QSF by filelist_mode_0_stp.txt as below
I am going to put these below 2 assignments into afu.qsf and rebuild system, see what is going on
thanks
Jim
Yes, please try to include the stp into the design and try again. If you are still facing the issue, could you share with me your project?
Hi JohnT,
I am happy to share my project with you, it is a vendor provided example project, under that directory root/inteldevstack/a10_gx_pac_ias_1_2_pv/hw/samples/nlb_mode_0_stp
is there a convenient way to achieve project files like Quartus can does? if so, that would be handy.
If not, can you let me know which directory or which file do you need in what format?
thanks
Jim
You can use Quartus to achieve the project which include all revision.
Hi JohnT,
finally I got it works now.now signaltap can remotely capture data now.
the reason is that
after I put 2 assignments into afu.qsf
set_global_assignment -name USE_SIGNALTAP_FILE "../../hw/par/A10/stp_basic.stp"
those above 2 assignmetn supposed be done by extra_tcl-0_stp.tcl
but if you check the path in extra_tcl-0_stp.tcl you will find the path is wrong
set_global_assignment -name USE_SIGNALTAP_FILE ../hw/par/A10/stp_basic.stp.
the correct one is
the wrong one made stp file can not be included during the compilation, that is why stp always reported Can't find the instance. Download a design with SRAM Object File containing this instance.
that original extra_tcl-0_stp.tcl is provided by vendor, I have not changed it. that is root cause.
thanks for your help.
I think many other customer would duplicate same issue, if they follow the instruction from page 35 in chapter 6 AFU in-system debug of AFU Developer’s Guide for Intel FPGA Programmable Acceleration Card.
thanks all your help.
Best regard
Jim
I Share my project here with everyone for reference.
but when I was doing achieve project with ticking all version, system reported an error
Error(16368): Top-level design entity "dcp_top" is undefined
anyway I attached my project here, anyone wants single other file can email to me jimlinmake@hotmail.com.
thanks
jim
Thanks for sharing. I would recommend to always check on the Quartus report to confirm STP is included and compiled into your design so that the SignalTap is able to run.
Hi JohnT,
thanks for that, May I know which report and which part in that report should be check for confirming the stp is included?
any key words can be use to search ? I think this is very useful,
thanks
Jim
please look at .fit.rpt file.
Hi JohnT,
I have checked the file afu_fit.fit.rpt,which is 137.9MB, it is too long and too big.
I have not fund signaltap relative information,which can be use to indicate if sitnaltap file is included or not.
thanks
jim
If you look into fit.rpt, you will observed "inst_SLD_HUB_cont_sys" which is usually the SignalTap resource and in .synth.rpt, you will observed .stp file being included into your design.
Hi JohnT,
I have found my stp file is in the section source files read of afu_synth.syn.rpt, looks like stp file is included by compilation flow.
Jim
I am glad to help you on this.
