I have problems testing programs of Intel(R) oneAPI DPC++ Compiler 2021.1 (2020.8.0.1005) for FPGAs with Quartus 19.4 support for a custom platform: Stratix10 GX with Quartus 19.4 BSP.
After compilation, I run the program and It try to reprogram the Stratix10GX, but one of the messages shows "Autodetect Cable not Found"
MMD INFO : [acls10_ref0] Trying Full-Chip Reconfiguration (JTAG)
MMD INFO : Autodetect Cable not found!!
MMD INFO : setting Cable to default value 1
MMD INFO : setting Device Index to default value 1
MMD INFO : executing "quartus_pgm -c 1 -m jtag -o "P;reprogram_temp.sof@1""
As the default jtag chain is 1, the IDs do not correspond to the FPGA chip and the programming fault. For my device jtag chain is :
1) USB-BlasterII [5-4]
020A40DD 5M(1270ZF324|2210Z)/EPM2210
C32150DD 1SG280HH(1S2|2S2|3S2)/..
and the programming error is as below:
Error (18952): Error status: The device chain in Programmer does not match physical device chain. Expected JTAG ID code 0xC32150DD for device 1, but found JTAG ID code 0x020A40DD.
Error (209012): Operation failed
If I try to test an OpenCL program and run it after "aocl program *.aocx" it is successful.
How I can program the FPGA with OneApi? I had tested three examples: fpga_compile, loop_unrool, and max_concurrency(this worked for me the first time that I run, and never again).
I appreciate your kindle help
Typically you would program the FPGA via JTAG once and after that, run-time reconfiguration should happen via PCI-E. You can manually reconfigure the FPGA via JTAG by using the following chain of commands to extract the .sof from your .aocx file (replace text between ** with appropriate names):
aocl binedit *aocx_file* get .acl.fpga.bin *bin_file*
aocl binedit *bin_file* get .acl.sof *sof_file*
And then run quartus_pgm to program the FPGA (@2 points to the second device in the JTAG chain):
quartus_pgm --mode=JTAG --cable=1 -o "p;*sof_file*;@2"
Then do a reboot and after that PCI-E-based reconfiguration should work if your BSP has been created correctly.
Hi ,
Hope the community discussion was useful and the issue is resolved.
Just to add on please find the knowledge base link below for similar JTAG errors
Thanks and Regards
Anil
