Application Acceleration With FPGAs
Programmable Acceleration Cards (PACs), DCP, FPGA AI Suite, Software Stack, and Reference Designs
499 Discussions
No JTAG hardware available for Quartus prime pro 19.1.0.240
zjinf
After install the QUARTUS PRIME PRO 19.1.0.240 software, when i run the command : jtagconfig, it says"No JTAG hardware available"
  1. The soluation :
$ sudo killall -9 jtagd
$ sudo jtagd
still not work(link at altera web:https://www.intel.com/content/www/us/en/programmable/support/support-resources/knowledge-base/embedded/2018/why-do-i-get-the-error-no-jtag-hardware-available-when-running-j.html)
2 I switch to other quartus prime pro 18.1(both installed on my pc), and run the command :jtagconfig, it's OK
Anybody can help me fix the jtag problem for quartus prime pro 19.1.0.240????
ShafiqY_Intel
Hi zjinf,
I believe you are using USB-Blaster II. There is some issue with USB Blaster II when using Quartus 19.1 version. Please follow the following KDB for workaround.
https://www.intel.com/content/altera-www/global/en_us/index/support/support-resources/knowledge-base/component/2019/why-does-my-usb-blaster-ii-not-work-when-using-intel--quartus---.html
I hope this will help.
Thanks😉
ShafiqY_Intel
Hi zjinf,
Thanks😉
zjinf
Hi MShafiq
Thanks very much ! it works well now!
