Application Acceleration With FPGAs
Programmable Acceleration Cards (PACs), DCP, FPGA AI Suite, Software Stack, and Reference Designs
501 Discussions
On FPGA (but not CPU), face detection plus add-on models throws resize error.
SGrif4
Hardware/Software Used
Intel® Distribution of OpenVINO™ Toolkit 2018 R5
Intel® Vision Accelerator Design with Intel® Arria® 10 FPGA (IEI's Mustang-F100-A10)
following this: https://github.com/fritzboyle/openvino-with-fpga-hello-world-face-detection
Takeaways: (Looking at FPS of one video at a time using these models).
FPGA is not able to handle face detection plus add-ons (like age gender or head pose) on any video that was NOT the sample demo video as it runs into a resize error (highlighted below in yellow). However the CPU can run the face detection model with add-ons on any video (including the demo video).
Comparing the CPU vs FPGA running just the face detection model, the FPGA was always slightly slower than the CPU.
Questions/Concerns:
·     Why won’t face detection plus add-on models work on non-demo videos on the FPGA? (As in, will work on demo video that comes with tutorial will support add-on face detection, but add-on face detection won't work on my own video file).
One video – demo video
W/out Specifying FPGA (aka CPU) –
[ INFO ] Total main-loop time:80316.55 ms
[ INFO ] Total # frames:1719
[ INFO ] Average time per frame:46.72 ms (21.40 fps)
HETERO mode with FPGA –
[ INFO ] Total main-loop time:55428.89 ms
[ INFO ] Average time per frame:32.24 ms (31.01 fps)
One video – non demo video
[ INFO ] Total main-loop time:88910.86 ms
[ INFO ] Total # frames:2029
[ INFO ] Average time per frame:43.82 ms (22.82 fps)
[ ERROR ] OpenCV(4.0.1-openvino) /home/jenkins/workspace/OpenCV/OpenVINO/build/opencv/modules/imgproc/src/resize.cpp:3784: error: (-215:Assertion failed) !ssize.empty() in function 'resize'
JohnT_Intel
What do you mean by this? The result that you shared, I am seeing that with CPU only is running 21fps while with FPGA then it is able to run up to 32fps. This is showing with FPGA, it is able to run faster.
Questions/Concerns:
May I know if you are able to share with me the video? It should be able to work as the image resize should be performed in CPU.
SGrif4
---> Right, my error typo in the note. Thanks for pointing this out.
Questions/Concerns:
--> Please find it attached below!
JohnT_Intel
May I know if it is possible to upgrade your OpenVINO to 2019R1? I have tested your video and it is able to run on my setup without any issue.
