Application Acceleration With FPGAs
Programmable Acceleration Cards (PACs), DCP, FPGA AI Suite, Software Stack, and Reference Designs
477 Discussions
PAC Arria 10 GX, reconfiguration not working on 1.2PV
HKim27
Hi, all.
I'm using a pac_a10 board and recently upgraded it to 1.2 production version.
Since then, reprogramming (partial reconfiguration) is not working.
Scenario here:
  1. I programmed the device with hello_world example.
aocl program acl0 $OPAE_PLATFORM_ROOT/opencl/hello_world.aocx
  1. I ran vector_add example.
cd exm_opencl_vector_add_x64_linux/vector_add make cp $OPAE_PLATFORM_ROOT/opencl/vector_add.aocx bin ./bin/host
  1. What I expect is, although the device is programmed with hello_world.aocx, it will be reprogrammed with vector_add.aocx and run smoothly, like the following sample output from https://www.intel.com/content/altera-www/global/en_us/index/documentation/fvf1521490619217.html#nms1523294913946
Initializing OpenCL Platform: Intel(R) FPGA SDK for OpenCL(TM) Using 1 device(s) pac_a10 : PAC Arria 10 Platform (pac_a10_f200000) Using AOCX: vector_add.aocx Reprogramming device [0] with handle 1 Launching for device 0 (1000000 elements)   Time: 8.046 ms Kernel time (device 0): 3.711 ms   Verification: PASS
Instead, however, it fails with the following error.
Initializing OpenCL Platform: Intel(R) FPGA SDK for OpenCL(TM) Using 1 device(s) pac_a10 : PAC Arria 10 Platform (pac_a10_eb00000) Using AOCX: vector_add.aocx Context callback: Specified kernel was not built for any devices ERROR: CL_INVALID_KERNEL_NAME Location: host/src/main.cpp:169 Failed to create kernel Segmentation fault (core dumped)
  1. If I program the device with vector_add.aocx and run vector_add example, it runs well. So, my guess is that reprogramming is not working.
Anybody has some idea on this?
Nooraini_Y_Intel
Currently I am reviewing the forum for any open questions and found this thread. I apologize that no one seems to answer this question that you posted. Since it has been a while you posted this question, I'm wondering if you have found the answer? If not, please let me know, I will try to assign/find someone to assist you. Thank you.
Nooraini
HKim27
@NYusof​
Thank you for your attention.
I have not found the answer yet, so assist will be great. :)
JonWay_C_Intel
Hi @HKim27​
Do you mean you configured the FPGA with hello_world.aocx, and then run the vector_add example (WITHOUT performing aocl program <device> vector_add.aocx)?
HKim27
HKim27
@JwChin​
Is there any update on this?
JonWay_C_Intel
Hi @HKim27​
Sorry i missed your reply. Thank you for following up.
Could you run the below steps:
Could you reboot your system?
Source init_env.sh
aocl install
program a hello_world.aocx to initialize the board
aocl diagnose (it should show the status as "Passed")
Then go back to performing: https://www.intel.com/content/altera-www/global/en_us/index/documentation/fvf1521490619217.html#nms1523294913946
make sure you have copied the vector_add.aocx into the "bin" folder
cp $OPAE_PLATFORM_ROOT/opencl/vector_add.aocx ./bin
Also, check if you have set your hugepages.
If this still fails, please confirm you meet the system requirement: https://www.intel.com/content/www/us/en/programmable/documentation/iyu1522005567196.html#oeh1528996494398
HKim27
@JwChin​
I finally found the solution. (after 8 month!!!)
Initialization script inside Intel Acceleration Stack Version 1.2 (inteldevstack/init_env.sh) has this line:
export CL_CONTEXT_COMPILER_MODE_INTELFPGA=3
According to the documentation, this environment variable prevent reconfiguration during OpenCL host execution.
By unsetting this, reconfiguration works well.
