Application Acceleration With FPGAs
Programmable Acceleration Cards (PACs), DCP, FPGA AI Suite, Software Stack, and Reference Designs
501 Discussions
Power measurement of Arria 10 FPGA
ADua0
I want to calculate the power consumption of fpga when I am running my opencl code on Arria 10 FPGA, is there any tool that can help me measure power
HRZ
Valued Contributor III
What board are you using? Nallatech and Bittware Arria 10 boards come with on-board power sensors and they provide exampels in their documentation as to how the sensor can be read in standard C code. I think Intel's reference board also comes with some power measurement tool. For other boards, you should probably consult the board manufacturer to see if they provide a power sensor on the board. If not, you will be limited to either using a PCI-E riser cable and measuring power on that, which would be accurate but potentially dangerous (due to possibility of shorting during measurement), or use a Plug-In Power Meter and subtract the measured power consumption with and without the board, to get the board power usage, but this will be highly inaccurate.
ADua0
@HRZ​ , I am using ARRIA 10 GX FPGA board, I found one source of https://www.intel.com/content/www/us/en/programmable/support/support-resources/operation-and-testing/power/a10-power_estimator_download.html, to download power estimator, but I am not able to edit anything, it needs password to make changes . Do you know any other solution ?
HRZ
That is a power "estimator", not measurement tool. Maybe one of the Intel mods can point to a power measurement tool/method for the Arria 10 GX board.
ADua0
Oh okay I got, @HRZ​ , I used quartus_pow that did generated estimate power, should I trust this report generated from quartus_pow.
ADua0
HRZ
That is also one option, but quartus_pow assumes a signal activity of 12.5%. Depending on the switching characteristics of your design, the value you get from quartus_pow could be close to the real value, or very far from it. The static power usage should be relatively accurate; it is the dynamic power usage that is the main source of difference between the real power usage and the estimation you get from quartus_pow.
