Application Acceleration With FPGAs
Programmable Acceleration Cards (PACs), DCP, FPGA AI Suite, Software Stack, and Reference Designs
504 Discussions
Problem in compiling and running the dma_afu example ?
msolt
I am trying to build the dma_afu sample available in (inteldevstack_v1.2). The sample comes with a gbs file which i am able to run and test successfully. However, when I run the software with the gbs file I built myself, i get the following error.
"Running test in HW mode
No suitable slots found."
i am aware that this may happen if the FIM version is not compatible with the AFU image. However, I made sure both my gbs file and the one comes with the example have the same number. What else might be the reason I got this error ?
Here is the step I took to build the gbs according to the documentation.
afu_synth_setup --source hw/rtl/filelist.txt build_synth
cd build_synth
$OPAE_PLATFORM_ROOT/bin/run.sh
this gives me the dma_afu.gbs
MEIYAN_L_Intel
Could you check on the BMC version for acceleration stack 1.2?
Also, could you provide information with command fpgainfo?
msolt
Thank for your response. I figured out that was a license issue. The gbs file wasn't built properly. I fixed it by updating the license following the disussion in another forum https://forums.intel.com/s/question/0D50P00004ZMIyk/error-213009-file-name-outputfilesafufitgreenregionpmsf-does-not-exist-or-cant-be-read?language=en_US
MEIYAN_L_Intel
Thank you for your update.
