Application Acceleration With FPGAs
Programmable Acceleration Cards (PACs), DCP, FPGA AI Suite, Software Stack, and Reference Designs
502 Discussions
Synthesis not working after update to OPAE 1.3
AIvan11
Info (16678): Successfully loaded final database: elapsed time is 00:00:17 Info (18936): Using revision output_files/dcp.green_region.pmsf as a baseline for afu_fit.green_region mask verification Internal Error: Sub-system: PGMIO, File: /quartus/h/pgmio_pof2_sys.h, Line: 194 ERROR IN READING unknown_tag 64 Stack Trace:   0x4db669: POF_READER::parse(FIO_PATH const&, char const*) + 0x509 (pgm_pgmio) 0x4db8db: PGMIO_POF2_PARSER::read_raw_sof(FIO_PATH const&, PGMIO_IPOF2_LISTENER&, char const*) + 0x18b (pgm_pgmio) 0x4dbbc5: PGMIO_POF2_IO::read_pmsf(FIO_PATH const&, PGMIO_IPOF2_METADATA&, PGMIO_IPOF2_DATA&, PGMIO_IPOF2_MASK&, PGMIO_IPOF2_LEGACY*) + 0x85 (pgm_pgmio) 0x62517: ASM2_PR_REGION::read_pmsf(ASM2_ITYPE_DEVICE&, FIO_PATH const&) + 0x7d (comp_asm2) 0x6fc1f: ASM2_PR_MASKS_ANALYZER::verify_region_mask(ASM2_IDEVICE&, ASM2_IPR_REGION&, std::string const&, FIO_PATH&) + 0x323 (comp_asm2) 0x700a0: ASM2_PR_MASKS_ANALYZER::verify_regions(ASM2_IDEVICE&, ASM2_IPARTITIONS const&) + 0x23c (comp_asm2) 0x5ef27: ASM2_PR_ASSEMBLE::verify_regions(ASM2_IDEVICE&, ASM2_IPR_PARTITIONS const&, ASM2_IREGIONS_ANALYZER&) + 0x5d (comp_asm2) 0x606b2: ASM2_PR_ASSEMBLE::assemble(DBCM_CHIP const&, DBCM_DEVICE const&, ASM2_IDEVICE&, ASM2_IPARTITIONS const&, ASM2_IBIT_LISTENER::IMASKS*) + 0x262 (comp_asm2) 0x220bc: ASM2_INSTANCE::assemble_to_bits(ASM2_ICHIP&, ASM2_IDEVICE&) + 0x6d0 (comp_asm2) 0x3f20d: ASM2_STATE::device_assemble(int) + 0x8b (comp_asm2) 0x36f8dd: asm_assemble_asmm(CMP_FACADE*, CDB_CHIP_DB_ENTRY*, ASM_OPTIONS*, ASM_PGM_OPTION_DATA*, unsigned int, DEV_FAMILY_ENUM, DEV_FAMILY_ENUM, DEV_PART_MANAGER*) + 0x1780 (comp_asm) 0x29f7d1: asm_assemble(CMP_FACADE*, unsigned int, bool&, FIO_PATH const&) + 0x83b (comp_asm) 0x408c75: QASM_FRAMEWORK::execute() + 0xcd (quartus_asm) 0x1ad86: qexe_standard_main(QEXE_FRAMEWORK*, QEXE_OPTION_DEFINITION const**, int, char const**) + 0x6a7 (comp_qexe) 0x40abf3: qasm_main(int, char const**) + 0xa5 (quartus_asm) 0x3f160: msg_main_thread(void*) + 0x10 (ccl_msg) 0x5b4c: thr_final_wrapper + 0xc (ccl_thr) 0x3f21f: msg_thread_wrapper(void* (*)(void*), void*) + 0x62 (ccl_msg) 0xac5c: mem_thread_wrapper(void* (*)(void*), void*) + 0x5c (ccl_mem) 0x8b49: err_thread_wrapper(void* (*)(void*), void*) + 0x27 (ccl_err) 0x5b8f: thr_thread_wrapper + 0x15 (ccl_thr) 0x41b11: msg_exe_main(int, char const**, int (*)(int, char const**)) + 0xb2 (ccl_msg) 0x40c988: main + 0x26 (quartus_asm) 0x21b97: __libc_start_main + 0xe7 (c)     End-trace
the output of:
quartus_asm --read_settings_files=on --write_settings_files=off dcp -c afu_fit
during the execution of:
$OPAE_PLATFORM_ROOT/bin/run.sh
Everything else succeeds, but somehow assembler fails at the end. Can anyone, please, help me solve this?
AIvan11
Patching Quartus with patch 1.38 that comes with Acceleration Stack 1.2 solved it.
AIvan11
