Application Acceleration With FPGAs
Programmable Acceleration Cards (PACs), DCP, FPGA AI Suite, Software Stack, and Reference Designs
empty report issue
beiwang2003
We installed Intel Quartus 19.2 and Intel FPGA SDK for OpenCL version 19.4 for the D5005 acceleration card.  When we tried to compile the example vectorAdd openCL kernel code with aoc -rtl vector_add.cl -report (or aoc -o vector_add.aocx vector_add.cl -report), we alway get empty report at vector_add/reports/report.html. Could you please advise?
Here is my running env
export QUARTUS_HOME="/opt/intelFPGA_pro/quartus_19.2.0b57/quartus"
export OPAE_PLATFORM_ROOT="/opt/intel/fpga-d5005/inteldevstack/d5005_ias_2_0_1_b237"
export AOCL_BOARD_PACKAGE_ROOT="/opt/intel/fpga-d5005/inteldevstack/d5005_ias_2_0_1_b237/opencl/opencl_bsp"
if ls /dev/intel-fpga-* 1> /dev/null 2>&1; then
if [ `id -u` = 0 ]; then
source $AOCL_BOARD_PACKAGE_ROOT/linux64/libexec/setup_permissions.sh >> /dev/null
fi
fi
OPAE_PLATFORM_BIN="/opt/intel/fpga-d5005/inteldevstack/d5005_ias_2_0_1_b237/bin"
if [[ ":${PATH}:" = *":${OPAE_PLATFORM_BIN}:"* ]] ;then
    echo "\$OPAE_PLATFORM_ROOT/bin is in PATH already"
else
    echo "Adding \$OPAE_PLATFORM_ROOT/bin to PATH"
    export PATH="${PATH}":"${OPAE_PLATFORM_BIN}"
fi
export INTELFPGAOCLSDKROOT="/opt/intelFPGA_pro/19.4/hld"
export ALTERAOCLSDKROOT=$INTELFPGAOCLSDKROOT
export PAC_DMA_WORK_THREAD=yes
QUARTUS_BIN="/opt/intelFPGA_pro/quartus_19.2.0b57/quartus/bin"
if [[ ":${PATH}:" = *":${QUARTUS_BIN}:"* ]] ;then
    echo "\$QUARTUS_HOME/bin is in PATH already"
else
    echo "Adding \$QUARTUS_HOME/bin to PATH"
    export PATH="${QUARTUS_BIN}":"${PATH}"
fi
source $INTELFPGAOCLSDKROOT/init_opencl.sh >> /dev/null
export QUARTUS_ROOTDIR_OVERRIDE="/opt/intelFPGA_pro/quartus_19.2.0b57/quartus"
EBERLAZARE_I_Intel
Were you able to compile the kernel? Did you encounter any errors during compilation?
If yes, could you share them.
beiwang2003
The compiling went through well, no compiling error. Thanks
EBERLAZARE_I_Intel
Can you check if you have gotten your main sources renamed, which may have caused the issue?
There is a related discussion that might related to this issue:
https://community.intel.com/t5/Software-Archive/Empty-Optimization-Report/m-p/1148246
beiwang2003
No name changes. The vector_add.cl example only contains the following:
__kernel void vector_add(__global const float *x,
                         __global const float *y,
                         __global float *restrict z)
    // get index of the work item
    int index = get_global_id(0);
    // add the vector elements
    z[index] = x[index] + y[index];
beiwang2003
The problem is fixed. I only copied the report.html file to my local computer to review with a browser. I will also need to copy the ./lib directory within ./reports to review the complete report. Thanks!
