Application Acceleration With FPGAs
Programmable Acceleration Cards (PACs), DCP, FPGA AI Suite, Software Stack, and Reference Designs
502 Discussions
pac n3000 8x10G lspci|grep 0cf8 not listed
fzhan51
the verison is Alpha-1 (D.1.0.13)after upgraded to production verison and kernel switch between "CentOS Linux (4.19.8) 7 (Core)" and "CentOS Linux (3.10.0-1062.18.1.el7.x86_64) 7 (Core)", "lspci|grep 0cf8" disappeared,I tried "sudo ./nvmupdate64e -c nvmupdate_10G_0CF8.cfg -f" to update Intel XL710 Firmware,and install i40e.ko
again and again.I remeber that when swithed the kernel to 3.10.0,and performed "sudo yum remove kernel-headers.x86_64"
then build i40e-2.9.21 failed,thus I tried i40e-2.10.30,and compiled passed,but said "invalid private key" when being installed.
I guess there might be something wrong in upgradation,for example,I follow Beta upgadation instead of Alpha upgadation
by mistake.would that happen?
anyone can help to correct it?
fzhan51
i think that as a pcie dev,it's independent of a driver/system kernel when recognize the dev id.the dev id can't be recognized means that the firmware is going incorrect;I suspect only involving OTSU can fix,but I don't know how
JonWay_C_Intel
