I have not found a way to resume my x2goclient sessions. I also end up having to terminate and start a new one when my connection breaks away.
I have found that the Terminate button is never enabled in my x2goclient window.
Has someone seen the same issue?
Ashish
Hi @Lawrence_L_Intel @Anil_A_Intel @BoonBengT_Altera @John_T_Intel Have you seen similar issues on the Dev Cloud platform mentioned in this post on the Dev Cloud platform?
-Hazlina
All terminal and X2go sessions with no keyboard activity seem to terminate in 20-30 minutes. We highly encourage running all the steps in batch mode. regards, Larry
Larry,
Can you please elaborate or point me to instructions for running in batch mode? My steps are pretty simple.
- devcloud_login
- ssh -L "..." from another terminal
- Launch X2GOClient
How does batch mode apply to the above?
refer to this document: https://github.com/intel/FPGA-Devcloud/tree/master/main/Devcloud_Access_Instructions#devcloud-access-instructions
and look for the section submitting batch jobs. use this link for access to various quick start guides for the supported workload processing: https://github.com/intel/FPGA-Devcloud/tree/master/main/QuickStartGuides
Find the flow you are working on there is a starting point batch script. Make sure if you are downloading the batch scripts and files to use the "raw" format.
Let me know if this works out ok for you.
Larry
Larry,
I understand that devcloud_login -b will run in batch mode. Thanks for the pointer.
However, the question in this case is about failing to be able to use the Resume button of the X2GOClient. Let me try running devcloud in batch mode and see if it addresses the issue I am seeing with the X2GOClient.
Ashish
Larry,
Running in batch mode does not help solve this problem.
