0
0
2,108
Last month, NASA’s Perseverance rover landed successfully in Jezero Crater on Mars and has taken its first test drive. You may have seen video of the mission team at NASA Jet Propulsion Laboratory (JPL) standing up and cheering when news of the successful landing arrived here on Earth. The Mars 2020 Perseverance Mission Team is the first at NASA JPL to use a new high-resolution, multi-mission AV collaboration system developed by Amplified Design LLC, which was completed in time for the Mars 2020 Perseverance Rover launch in July of 2020.
This AV collaboration system spans 45 new collaboration areas across multiple floors at NASA JPL’s Space Flight Operations Facility in Pasadena, California. The system is based on nearly 200 Crestron DM NVX streaming media devices that provide secure, real-time AV encoding and decoding for the transport of real-time 4K video streams over standard Gigabit Ethernet. The DM NVX backbone distributes video to both the large and small work rooms as well as mission support areas for anywhere-to-anywhere video sharing. Crestron developed the DM NVX streaming media devices using Intel® Arria® 10 SoC FPGAs.
Click here to see the Amplified Design case study describing the NASA JPL AV collaboration system.
Click here for more information about Crestron DM NVX AV-over-IP streaming media devices.
Click here for more information about Intel Arria 10 FPGAs and SoC FPGAs.
Notices & Disclaimers
No product or component can be absolutely secure.
Intel does not control or audit third-party data. You should consult other sources to evaluate accuracy.
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
