Community
cancel
Showing results for
Search instead for
Did you mean:
AMD ShadowFX sample is hangs on Intel HD 4000 GPU
Hi all! I'm try to use the ShadowFX from GPUOpen-Effects/ShadowFX - C++ - GitHub
During debug on Visual Studio 2012 the sample is hangs on file
ShadowFX\amd_shadowfx_sample\src\ShadowFX_Sample.cpp (line 1561):
void CALLBACK OnD3D11DestroyDevice(void* pUserContext)
    SAFE_RELEASE(g_pShadowMapPS);
Call Stack:
  ShadowFX_Sample_Debug_2012.exe!OnD3D11DestroyDevice(void * pUserContext=0x0000000000000000) Line 1561
> ShadowFX_Sample_Debug_2012.exe!DXUTCleanup3DEnvironment(bool bReleaseSettings=false) Line 3014
  ShadowFX_Sample_Debug_2012.exe!DXUTChangeDevice(DXUTDeviceSettings * pNewDeviceSettings=0x0000000003387b30, bool bClipWindowToSingleAdapter=true) Line 1912
  ShadowFX_Sample_Debug_2012.exe!DXUTChangeDevice(DXUTDeviceSettings * pNewDeviceSettings=0x0000000000377390, bool bClipWindowToSingleAdapter=true) Line 2151
  ShadowFX_Sample_Debug_2012.exe!DXUTCreateDevice(D3D_FEATURE_LEVEL reqFL=D3D_FEATURE_LEVEL_11_0, bool bWindowed=true, int nSuggestedWidth=1920, int nSuggestedHeight=1080) Line 1704
  ShadowFX_Sample_Debug_2012.exe!wWinMain(HINSTANCE__ * hInstance=0x000000013f4a0000, HINSTANCE__ * hPrevInstance=0x0000000000000000, wchar_t * lpCmdLine=0x0000000000306684, int nCmdShow=10) Line 375
Hi Andrey,
I am looking into this, I will let you know what I find out.
-Michael
Hi Michael, Thank you for your response.
On AMD R7 240, nVidia 210 it is working fine.
The problem is absent on the last driver, but during debugging of a sample, it works very slowly.
Hi Andrey,
So with the latest driver the issue is not present?
-Michael
Hi Michael,
Yes.
