Hi All.
I'm using Direct3D11 with GDI compatible, but i have some artifacts on some new Intel GPU(530, 630)
For creating IDXGISwapChain with GDI compatible i use the following code:
DXGI_SWAP_CHAIN_DESC::Flags = DXGI_SWAP_CHAIN_FLAG_ALLOW_MODE_SWITCH; DXGI_SWAP_CHAIN_DESC::BufferDesc.Format = DXGI_FORMAT_B8G8R8A8_UNORM;
//Rendering prevcode:
ID3D11Context->OMSetRenderTargets(....); //Draw 3D data normaly... IDXGISwapChain->GetBuffer(0, __uuidof(IDXGISurface1), reinterpret_cast<void **>(&pDXGISurface)); HDC dxgiHDC = 0; pDXGISurface->GetDC(FALSE, &dxgiHDC); //DrawText using GDI functions pDXGISurface->ReleaseDC(0); IDXGISwapChain::Present(0, 0);
Result o Intel HD 530, Intel HD 630:
Result on Intel HD 4000, Intel HD 4600, Any AMD/nVidia card:
What do i do wrong ?
Is the issue still happening with the latest driver?
If so I need the template below filled out so an issue can be properly reported. If you have binary sample the produces the issue that would help as well.
System Setup Information:
System Used: (Manufacturer/Model)
CPU SKU: (i3, i5, Pentium, Celeron, etc.)
GPU SKU: (HD4400, HD5100, etc.)
Processor Line: (Y-Series, U-Series, etc.)
System BIOS Version:
CMOS settings:
Graphics Driver Version:
GOP/VBIOS Version:
Operating System:
OS Version:
API:
Occurs on non-Intel GPUs?:
Steps to Reproduce:
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
Expected Results:
Actual Results:
Additional Information:
Hi, Michael
I will check issue with the latest driver, if i can install it(becuase some notebook doesn't allow to install directly the latest driver from Intel site.)
I have the sumbitted bug report https://software.intel.com/en-us/forums/graphics-driver-bug-reporting/topic/757225
Ok, i will create the minimal C++ project in Visual Studio with executable file.
Hi, Michael
I attached the simple project with executable file:
There is some sreenshots with result on Intel:
On nVidia:
For more complete information about compiler optimizations, see our Optimization Notice.
