Developing Games on Intel Graphics
If you are gaming on graphics integrated in your Intel Processor, this is the place for you! Find answers to your questions or post your issues with PC games
489 Discussions
GMA950 glShadeModel(GL_FLAT) bug
thegeleto
I've stumbled on a driver bug, where when using glShadeModel(GL_FLAT) the triangle color is not always taken from the last vertex as it should.
Here's how this looks with the Intel card:
Intel GL_FLAT
... and the same thing with ATI and NVidia cards:
NVidia GL_FLAT
Executable (requires glut32.dll):
Source:
[cpp]#include "stdafx.h"
#include
void display(void)
int colors[7] = { 0xff0000,0x00ff00,0x0000ff, 0xff00ff,0xff00ff,0xff00ff,0xff00ff };
int indexes[18] = { 1,2,0, 2,3,0, 0,4,1, 4,5,1, 1,5,2, 5,6,2 };
float verts[21] = { 0,-2,0, 0,0,0, -1,1,0, -1,-1,0, 1,-1,0, 1,1,0, 0,2,0 };
glClear( GL_COLOR_BUFFER_BIT );
glEnableClientState( GL_VERTEX_ARRAY );
glEnableClientState( GL_COLOR_ARRAY );
glColorPointer( 4, GL_UNSIGNED_BYTE, 0, colors );
glVertexPointer( 3, GL_FLOAT, 0, verts );
glDrawElements( GL_TRIANGLES, 18, GL_UNSIGNED_INT, indexes );
glDisableClientState( GL_VERTEX_ARRAY );
glDisableClientState( GL_COLOR_ARRAY );
glFlush();
void init(void)
glShadeModel( GL_FLAT );
glMatrixMode( GL_PROJECTION );
glLoadIdentity();
glOrtho( -2, 2, -3, 3, -1, 1 );
int _tmain( int argc, char** argv )
glutInit( &argc, argv );
glutInitDisplayMode( GLUT_SINGLE | GLUT_RGB );
glutInitWindowSize( 250, 250 );
glutInitWindowPosition( 100, 100 );
glutCreateWindow( "Fix me!!!" );
init();
glutDisplayFunc( display );
glutMainLoop();
return 0;
}[/cpp]
The same thing happens with normals and when using VBO.
Tested on an Asus eeepc 1000h, Windows XP, with drivers version 6.14.10.4906(the latest from Asus) and 6.14.10.4926
BTW, the VBOs on 4926 are very unstable. 4906 has no VBOs
Chuck_De_Sylva
Quoting - thegeleto
Intel GL_FLAT
NVidia GL_FLAT
Source:
#include
void display(void)
glFlush();
void init(void)
glLoadIdentity();
init();
glutMainLoop();
return 0;
}[/cpp]
I will open a driver bug for this. Stay tuned.
delle
Any news for this?
Doraisamy_G_Intel
Unfortunately, GMA950 is not actively supported anymore. I will check with the team to see if this resolved previously.
-Ganesh
