I am trying to use the Windows Output Manager API (https://msdn.microsoft.com/en-us/library/windows/desktop/dd388980(v=vs.85).aspx) to enable HDCP on an Intel HD 530 graphics card. I am able to call "IOPMVideoOutput::StartInitialization" successfully but "IOPMVideoOutput::FinishInitialization" returns an error stating "HRESULT_FROM_WIN32(ERROR_GEN_FAILURE) : A device attached to the system is not functioning."
I am not sure why this is the case, any help would be appreciated. I have included the results of dxdiag.
Thanks for all your help.
------------------ System Information ------------------ Time of this report: 1/20/2017, 15:03:21 Machine name: Operating System: Windows 10 Enterprise 2015 LTSB 64-bit (10.0, Build 10240) (10240.th1_st1.161118-1836) Language: English (Regional Setting: English) System Manufacturer: Default string System Model: Default string BIOS: Default System BIOS Processor: Intel(R) Core(TM) i7-6700 CPU @ 3.40GHz (8 CPUs), ~2.8GHz Memory: 16384MB RAM Available OS Memory: 16306MB RAM Page File: 3145MB used, 15592MB available Windows Dir: C:\Windows DirectX Version: 12 DX Setup Parameters: Not found User DPI Setting: Using System DPI System DPI Setting: 96 DPI (100 percent) DWM DPI Scaling: Disabled Miracast: Available, with HDCP Microsoft Graphics Hybrid: Not Supported DxDiag Version: 10.00.10240.16384 64bit Unicode ------------ DxDiag Notes ------------ Display Tab 1: No problems found. Display Tab 2: No problems found. Sound Tab 1: No sound card was found. If one is expected, you should install a sound driver provided by the hardware manufacturer. Input Tab: No problems found. -------------------- DirectX Debug Levels -------------------- Direct3D: 0/4 (retail) DirectDraw: 0/4 (retail) DirectInput: 0/5 (retail) DirectMusic: 0/5 (retail) DirectPlay: 0/9 (retail) DirectSound: 0/5 (retail) DirectShow: 0/6 (retail) --------------- Display Devices --------------- Card name: Intel(R) HD Graphics 530 Manufacturer: Intel Corporation Chip type: Intel(R) HD Graphics Family DAC type: Internal Device Type: Full Device Device Key: Enum\PCI\VEN_8086&DEV_1912&SUBSYS_00008086&REV_06 Display Memory: 8280 MB Dedicated Memory: 128 MB Shared Memory: 8152 MB Current Mode: 1920 x 1200 (32 bit) (59Hz) Monitor Name: Dell U2412M(DisplayPort) Monitor Model: DELL U2412M Monitor Id: DELA07B Native Mode: 1920 x 1200(p) (59.950Hz) Output Type: Displayport External Driver Name: igdumdim64.dll,igd10iumd64.dll,igd10iumd64.dll,igd12umd64.dll,igdumdim32,igd10iumd32,igd10iumd32,igd12umd32 Driver File Version: 21.20.0016.4534 (English) Driver Version: 21.20.16.4534 DDI Version: 12 Feature Levels: 12.1,12.0,11.1,11.0,10.1,10.0,9.3,9.2,9.1 Driver Model: WDDM 2.0 Graphics Preemption: Triangle Compute Preemption: Thread Miracast: Not Supported by WiFi driver Hybrid Graphics GPU: Integrated Power P-states: Not Supported Driver Attributes: Final Retail Driver Date/Size: 11/2/2016 13:02:18, 94205376 bytes WHQL Logo'd: Yes WHQL Date Stamp: Device Identifier: {D7B78E66-5A52-11CF-80F2-1020BDC2D835} Vendor ID: 0x8086 Device ID: 0x1912 SubSys ID: 0x00008086 Revision ID: 0x0006 Driver Strong Name: oem28.inf:5f63e53470659c00:iSKLD_w10:21.20.16.4534:pci\ven_8086&dev_1912 Rank Of Driver: 00D12001 Video Accel: ModeMPEG2_A ModeMPEG2_C ModeWMV9_C ModeVC1_C DXVA2 Modes: DXVA2_ModeMPEG2_VLD DXVA2_ModeMPEG2_IDCT DXVA2_ModeVC1_D2010 DXVA2_ModeWMV9_IDCT DXVA2_ModeVC1_IDCT DXVA2_ModeH264_VLD_NoFGT DXVA2_ModeH264_VLD_Stereo_Progressive_NoFGT DXVA2_ModeH264_VLD_Stereo_NoFGT DXVA2_ModeH264_VLD_Multiview_NoFGT DXVA2_ModeHEVC_VLD_Main DXVA2_ModeHEVC_VLD_Main10 Deinterlace Caps: {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC3,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC3,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC3,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC4,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC4,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC4,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend D3D9 Overlay: Supported DXVA-HD: Supported DDraw Status: Enabled D3D Status: Enabled AGP Status: Enabled Card name: Intel(R) HD Graphics 530 Manufacturer: Intel Corporation Chip type: Intel(R) HD Graphics Family DAC type: Internal Device Type: Full Device Device Key: Enum\PCI\VEN_8086&DEV_1912&SUBSYS_00008086&REV_06 Display Memory: 8280 MB Dedicated Memory: 128 MB Shared Memory: 8152 MB Current Mode: 1920 x 1200 (32 bit) (59Hz) Monitor Name: Dell U2412M(DisplayPort) Monitor Model: DELL U2412M Monitor Id: DELA07B Native Mode: 1920 x 1200(p) (59.950Hz) Output Type: Displayport External Driver Name: igdumdim64.dll,igd10iumd64.dll,igd10iumd64.dll,igd12umd64.dll,igdumdim32,igd10iumd32,igd10iumd32,igd12umd32 Driver File Version: 21.20.0016.4534 (English) Driver Version: 21.20.16.4534 DDI Version: 12 Feature Levels: 12.1,12.0,11.1,11.0,10.1,10.0,9.3,9.2,9.1 Driver Model: WDDM 2.0 Graphics Preemption: Triangle Compute Preemption: Thread Miracast: Not Supported by WiFi driver Hybrid Graphics GPU: Integrated Power P-states: Not Supported Driver Attributes: Final Retail Driver Date/Size: 11/2/2016 13:02:18, 94205376 bytes WHQL Logo'd: Yes WHQL Date Stamp: Device Identifier: {D7B78E66-5A52-11CF-80F2-1020BDC2D835} Vendor ID: 0x8086 Device ID: 0x1912 SubSys ID: 0x00008086 Revision ID: 0x0006 Driver Strong Name: oem28.inf:5f63e53470659c00:iSKLD_w10:21.20.16.4534:pci\ven_8086&dev_1912 Rank Of Driver: 00D12001 Video Accel: ModeMPEG2_A ModeMPEG2_C ModeWMV9_C ModeVC1_C DXVA2 Modes: DXVA2_ModeMPEG2_VLD DXVA2_ModeMPEG2_IDCT DXVA2_ModeVC1_D2010 DXVA2_ModeWMV9_IDCT DXVA2_ModeVC1_IDCT DXVA2_ModeH264_VLD_NoFGT DXVA2_ModeH264_VLD_Stereo_Progressive_NoFGT DXVA2_ModeH264_VLD_Stereo_NoFGT DXVA2_ModeH264_VLD_Multiview_NoFGT DXVA2_ModeHEVC_VLD_Main DXVA2_ModeHEVC_VLD_Main10 Deinterlace Caps: {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC3,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC3,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC3,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC4,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC4,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC4,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend D3D9 Overlay: Supported DXVA-HD: Supported DDraw Status: Enabled D3D Status: Enabled AGP Status: Enabled ------------- Sound Devices ------------- Description: Default Sound Playback: No Default Voice Playback: No Hardware ID: Manufacturer ID: Product ID: Type: Driver Name: Driver Version: Driver Attributes: WHQL Logo'd: Date and Size: Other Files: Driver Provider: HW Accel Level: Emulation Only Cap Flags: 0x0 Min/Max Sample Rate: 0, 0 Static/Strm HW Mix Bufs: 0, 0 Static/Strm HW 3D Bufs: 0, 0 HW Memory: 0 Voice Management: No EAX(tm) 2.0 Listen/Src: No, No I3DL2(tm) Listen/Src: No, No Sensaura(tm) ZoomFX(tm): No --------------------- Sound Capture Devices --------------------- Description: Line In (Realtek High Definition Audio) Default Sound Capture: Yes Default Voice Capture: Yes Driver Name: RTKVHD64.sys Driver Version: 6.00.0001.7541 (English) Driver Attributes: Final Retail Date and Size: 6/18/2015 19:45:16, 4496600 bytes Cap Flags: 0x1 Format Flags: 0xFFFFF Description: Stereo Mix (Realtek High Definition Audio) Default Sound Capture: No Default Voice Capture: No Driver Name: RTKVHD64.sys Driver Version: 6.00.0001.7541 (English) Driver Attributes: Final Retail Date and Size: 6/18/2015 19:45:16, 4496600 bytes Cap Flags: 0x1 Format Flags: 0xFFFFF --------------------- Video Capture Devices Number of Devices: 0 --------------------- ------------------- DirectInput Devices ------------------- Device Name: Mouse Attached: 1 Controller ID: n/a Vendor/Product ID: n/a FF Driver: n/a Device Name: Keyboard Attached: 1 Controller ID: n/a Vendor/Product ID: n/a FF Driver: n/a Poll w/ Interrupt: No ----------- USB Devices ----------- + USB Root Hub (xHCI) | Vendor/Product ID: 0x8086, 0xA12F | Matching Device ID: USB\ROOT_HUB30 | Service: USBHUB3 | Driver: USBHUB3.SYS, 11/24/2015 22:40:09, 516448 bytes | +-+ USB Input Device | | Vendor/Product ID: 0x046D, 0xC05A | | Location: Port_#0001.Hub_#0001 | | Matching Device ID: USB\Class_03&SubClass_01 | | Service: HidUsb | | Driver: hidusb.sys, 7/10/2015 03:59:38, 38400 bytes | | Driver: hidclass.sys, 7/10/2015 03:59:38, 153088 bytes | | Driver: hidparse.sys, 7/10/2015 03:59:38, 39936 bytes | | | +-+ HID-compliant mouse | | | Vendor/Product ID: 0x046D, 0xC05A | | | Matching Device ID: HID_DEVICE_SYSTEM_MOUSE | | | Service: mouhid | | | Driver: mouhid.sys, 7/10/2015 03:59:39, 32256 bytes | | | Driver: mouclass.sys, 7/10/2015 03:59:39, 59232 bytes | | +-+ USB Input Device | | Vendor/Product ID: 0x413C, 0x2107 | | Location: Port_#0002.Hub_#0001 | | Matching Device ID: USB\Class_03&SubClass_01 | | Service: HidUsb | | Driver: hidusb.sys, 7/10/2015 03:59:38, 38400 bytes | | Driver: hidclass.sys, 7/10/2015 03:59:38, 153088 bytes | | Driver: hidparse.sys, 7/10/2015 03:59:38, 39936 bytes | | | +-+ HID Keyboard Device | | | Vendor/Product ID: 0x413C, 0x2107 | | | Matching Device ID: HID_DEVICE_SYSTEM_KEYBOARD | | | Service: kbdhid | | | Driver: kbdhid.sys, 7/10/2015 03:59:38, 36864 bytes | | | Driver: kbdclass.sys, 7/10/2015 03:59:38, 62304 bytes ---------------- Gameport Devices ---------------- ------------ PS/2 Devices ------------ ------------------------ Disk & DVD/CD-ROM Drives ------------------------ Drive: C: Free Space: 1.7 GB Total Space: 122.1 GB File System: NTFS Model: TS128GMTS400 -------------- System Devices -------------- Name: High Definition Audio Controller Device ID: PCI\VEN_8086&DEV_A170&SUBSYS_72708086&REV_31\3&11583659&0&FB Driver: C:\Windows\system32\DRIVERS\hdaudbus.sys, 10.00.10240.17146 (English), 9/29/2016 21:05:18, 80896 bytes Driver: C:\Windows\system32\drivers\drmk.sys, 10.00.10240.16384 (English), 7/10/2015 03:59:36, 96768 bytes Driver: C:\Windows\system32\drivers\portcls.sys, 10.00.10240.16515 (English), 9/16/2015 22:50:33, 320000 bytes Name: Intel(R) 100 Series/C230 Series Chipset Thermal subsystem - A131 Device ID: PCI\VEN_8086&DEV_A131&SUBSYS_72708086&REV_31\3&11583659&0&A2 Driver: n/a Name: PCI standard host CPU bridge Device ID: PCI\VEN_8086&DEV_191F&SUBSYS_20158086&REV_07\3&11583659&0&00 Driver: n/a Name: PCI-to-PCI Bridge Device ID: PCI\VEN_111D&DEV_806E&SUBSYS_00000000&REV_02\4&2FFDBD31&0&0008 Driver: C:\Windows\system32\DRIVERS\pci.sys, 10.00.10240.16942 (English), 5/27/2016 22:00:08, 327520 bytes Name: PCI-to-PCI Bridge Device ID: PCI\VEN_111D&DEV_806E&SUBSYS_00000000&REV_02\5&1B9B1C97&0&180008 Driver: C:\Windows\system32\DRIVERS\pci.sys, 10.00.10240.16942 (English), 5/27/2016 22:00:08, 327520 bytes Name: Intel(R) 100 Series/C230 Series Chipset SMBus - A123 Device ID: PCI\VEN_8086&DEV_A123&SUBSYS_72708086&REV_31\3&11583659&0&FC Driver: n/a Name: PCI-to-PCI Bridge Device ID: PCI\VEN_111D&DEV_806E&SUBSYS_00000000&REV_02\5&1B9B1C97&0&200008 Driver: C:\Windows\system32\DRIVERS\pci.sys, 10.00.10240.16942 (English), 5/27/2016 22:00:08, 327520 bytes Name: Intel(R) USB 3.0 eXtensible Host Controller - 1.0 (Microsoft) Device ID: PCI\VEN_8086&DEV_A12F&SUBSYS_72708086&REV_31\3&11583659&0&A0 Driver: C:\Windows\system32\DRIVERS\USBXHCI.SYS, 10.00.10240.16461 (English), 8/18/2015 00:55:45, 373072 bytes Name: Intel(R) Management Engine Interface Device ID: PCI\VEN_8086&DEV_A13A&SUBSYS_19998086&REV_31\3&11583659&0&B0 Driver: C:\Windows\system32\DRIVERS\TeeDriverW8x64.sys, 11.00.0005.1189 (English), 3/28/2016 22:01:56, 186424 bytes Name: PCI-to-PCI Bridge Device ID: PCI\VEN_111D&DEV_806E&SUBSYS_00000000&REV_02\5&1B9B1C97&0&100008 Driver: C:\Windows\system32\DRIVERS\pci.sys, 10.00.10240.16942 (English), 5/27/2016 22:00:08, 327520 bytes Name: Intel(R) 100 Series/C230 Series Chipset Family LPC Controller - A143 Device ID: PCI\VEN_8086&DEV_A143&SUBSYS_72708086&REV_31\3&11583659&0&F8 Driver: C:\Windows\system32\DRIVERS\msisadrv.sys, 10.00.10240.16384 (English), 7/10/2015 03:59:38, 19296 bytes Name: Ubi Device Device ID: PCI\VEN_1172&DEV_E001&SUBSYS_2404A106&REV_09\6&1A932327&0&00200008 Driver: n/a Name: Intel(R) Serial IO I2C Host Controller - A160 Device ID: PCI\VEN_8086&DEV_A160&SUBSYS_72708086&REV_31\3&11583659&0&A8 Driver: C:\Windows\system32\DRIVERS\iaLPSS2_I2C.sys, 30.63.1519.0007 (English), 7/20/2015 14:52:46, 185128 bytes Name: Intel(R) 100 Series/C230 Series Chipset PMC - A121 Device ID: PCI\VEN_8086&DEV_A121&SUBSYS_72708086&REV_31\3&11583659&0&FA Driver: n/a Name: Intel(R) HD Graphics 530 Device ID: PCI\VEN_8086&DEV_1912&SUBSYS_00008086&REV_06\3&11583659&0&10 Driver: C:\Windows\system32\DRIVERS\igdkmd64.sys, 21.20.0016.4534 (English), 11/2/2016 13:02:13, 11033056 bytes Driver: C:\Windows\system32\igd10iumd64.dll, 21.20.0016.4534 (English), 11/2/2016 13:02:12, 22139072 bytes Driver: C:\Windows\system32\igd10idpp64.dll, 21.20.0016.4534 (English), 11/2/2016 13:02:12, 433872 bytes Driver: C:\Windows\system32\igd11dxva64.dll, 21.20.0016.4534 (English), 11/2/2016 13:02:13, 48250120 bytes Driver: C:\Windows\system32\igd12umd64.dll, 21.20.0016.4534 (English), 11/2/2016 13:02:13, 3484120 bytes Driver: C:\Windows\system32\igdumdim64.dll, 21.20.0016.4534 (English), 11/2/2016 13:02:18, 94205376 bytes Driver: C:\Windows\system32\igdail64.dll, 21.20.0016.4534 (English), 11/2/2016 13:02:13, 327688 bytes Driver: C:\Windows\system32\igfxcmrt64.dll, 6.00.0000.1189 (English), 11/2/2016 13:02:18, 197072 bytes Driver: C:\Windows\system32\igfx11cmrt64.dll, 6.00.0000.1189 (English), 11/2/2016 13:02:18, 194512 bytes Driver: C:\Windows\system32\igfxcmjit64.dll, 6.00.0000.1189 (English), 11/2/2016 13:02:18, 2324496 bytes Driver: C:\Windows\system32\igdde64.dll, 21.20.0016.4534 (English), 11/2/2016 13:02:13, 224784 bytes Driver: C:\Windows\system32\IntelCpHDCPSvc.exe, 1.00.0000.0001 (English), 11/2/2016 13:02:18, 480224 bytes Driver: C:\Windows\system32\igdusc64.dll, 21.20.0016.4534 (English), 11/2/2016 13:02:18, 6628128 bytes Driver: C:\Windows\system32\iga64.dll, 11/2/2016 13:02:11, 1349776 bytes Driver: C:\Windows\system32\igc64.dll, 21.20.0016.4534 (English), 11/2/2016 13:02:12, 18608480 bytes Driver: C:\Windows\system32\igdmd64.dll, 21.20.0016.4534 (English), 11/2/2016 13:02:13, 2922488 bytes Driver: C:\Windows\system32\igxpun.exe, 1.07.0022.0000 (English), 11/2/2016 13:02:18, 1019872 bytes Driver: C:\Windows\SysWow64\igd10iumd32.dll, 21.20.0016.4534 (English), 11/2/2016 13:02:12, 17333920 bytes Driver: C:\Windows\SysWow64\igd10idpp32.dll, 21.20.0016.4534 (English), 11/2/2016 13:02:12, 411888 bytes Driver: C:\Windows\SysWow64\igd11dxva32.dll, 21.20.0016.4534 (English), 11/2/2016 13:02:12, 47370208 bytes Driver: C:\Windows\SysWow64\igd12umd32.dll, 21.20.0016.4534 (English), 11/2/2016 13:02:13, 3384536 bytes Driver: C:\Windows\SysWow64\igdumdim32.dll, 21.20.0016.4534 (English), 11/2/2016 13:02:14, 92943584 bytes Driver: C:\Windows\SysWow64\igdail32.dll, 21.20.0016.4534 (English), 11/2/2016 13:02:13, 308232 bytes Driver: C:\Windows\SysWow64\igdde32.dll, 21.20.0016.4534 (English), 11/2/2016 13:02:13, 183896 bytes Driver: C:\Windows\SysWow64\igfxcmrt32.dll, 6.00.0000.1189 (English), 11/2/2016 13:02:18, 170712 bytes Driver: C:\Windows\SysWow64\igfx11cmrt32.dll, 6.00.0000.1189 (English), 11/2/2016 13:02:18, 170800 bytes Driver: C:\Windows\SysWow64\igfxcmjit32.dll, 6.00.0000.1189 (English), 11/2/2016 13:02:18, 1711624 bytes Driver: C:\Windows\SysWow64\igdusc32.dll, 21.20.0016.4534 (English), 11/2/2016 13:02:18, 5090168 bytes Driver: C:\Windows\SysWow64\iga32.dll, 11/2/2016 13:02:11, 1119216 bytes Driver: C:\Windows\SysWow64\igc32.dll, 21.20.0016.4534 (English), 11/2/2016 13:02:12, 15921728 bytes Driver: C:\Windows\SysWow64\igdmd32.dll, 21.20.0016.4534 (English), 11/2/2016 13:02:13, 2273048 bytes Driver: C:\Windows\SysWow64\iglhcp32.dll, 9.00.0030.7777 (English), 11/2/2016 13:02:18, 203312 bytes Driver: C:\Windows\SysWow64\iglhsip32.dll, 9.00.0030.9000 (English), 11/2/2016 13:02:18, 1814072 bytes Driver: C:\Windows\SysWow64\IntelCpHeciSvc.exe, 9.00.0031.9015 (English), 11/2/2016 13:02:18, 301536 bytes Driver: C:\Windows\system32\iglhxs64.vp, 11/2/2016 13:02:18, 12742 bytes Driver: C:\Windows\system32\iglhxo64.vp, 11/19/2015 19:55:42, 40343 bytes Driver: C:\Windows\system32\iglhxc64.vp, 11/19/2015 19:55:42, 40316 bytes Driver: C:\Windows\system32\iglhxg64.vp, 11/19/2015 19:55:42, 39658 bytes Driver: C:\Windows\system32\iglhxo64_dev.vp, 11/19/2015 19:55:42, 40931 bytes Driver: C:\Windows\system32\iglhxc64_dev.vp, 11/19/2015 19:55:42, 41296 bytes Driver: C:\Windows\system32\iglhxg64_dev.vp, 11/19/2015 19:55:42, 39798 bytes Driver: C:\Windows\system32\iglhxa64.vp, 11/19/2015 19:55:42, 1125 bytes Driver: C:\Windows\system32\iglhxa64.cpa, 11/19/2015 19:55:42, 2813952 bytes Driver: C:\Windows\system32\iglhcp64.dll, 9.00.0030.7777 (English), 11/2/2016 13:02:18, 238904 bytes Driver: C:\Windows\system32\iglhsip64.dll, 9.00.0030.9000 (English), 11/2/2016 13:02:18, 1816720 bytes Driver: C:\Windows\system32\cp_resources.bin, 11/2/2016 13:02:11, 560260 bytes Driver: C:\Windows\system32\difx64.exe, 1.04.0003.0000 (English), 11/2/2016 13:02:11, 175072 bytes Driver: C:\Windows\system32\igfxDH.dll, 6.15.0010.4534 (English), 11/2/2016 13:02:18, 923656 bytes Driver: C:\Windows\system32\igfxDHLib.dll, 1.00.0000.0000 (Invariant Language), 11/2/2016 13:02:18, 115208 bytes Driver: C:\Windows\system32\igfxDHLibv2_0.dll, 1.00.0000.0000 (Invariant Language), 11/2/2016 13:02:18, 123912 bytes Driver: C:\Windows\system32\igfxDI.dll, 6.15.0010.4534 (English), 11/2/2016 13:02:18, 396296 bytes Driver: C:\Windows\system32\igfxDILib.dll, 1.00.0000.0000 (Invariant Language), 11/2/2016 13:02:18, 29704 bytes Driver: C:\Windows\system32\igfxDILibv2_0.dll, 1.00.0000.0000 (Invariant Language), 11/2/2016 13:02:18, 29200 bytes Driver: C:\Windows\system32\igfxLHM.dll, 6.15.0010.4534 (English), 11/2/2016 13:02:18, 1988104 bytes Driver: C:\Windows\system32\igfxLHMLib.dll, 1.00.0000.0000 (Invariant Language), 11/2/2016 13:02:18, 22536 bytes Driver: C:\Windows\system32\igfxLHMLibv2_0.dll, 1.00.0000.0000 (Invariant Language), 11/2/2016 13:02:18, 22536 bytes Driver: C:\Windows\system32\igfxSDK.exe, 11/2/2016 13:02:18, 992736 bytes Driver: C:\Windows\system32\igfxSDKLib.dll, 1.00.0000.0000 (Invariant Language), 11/2/2016 13:02:18, 97288 bytes Driver: C:\Windows\system32\igfxSDKLibv2_0.dll, 1.00.0000.0000 (Invariant Language), 11/2/2016 13:02:18, 107528 bytes Driver: C:\Windows\system32\igfxEM.exe, 6.15.0010.4534 (English), 11/2/2016 13:02:18, 523232 bytes Driver: C:\Windows\system32\igfxEMLib.dll, 1.00.0000.0000 (Invariant Language), 11/2/2016 13:02:18, 27656 bytes Driver: C:\Windows\system32\igfxEMLibv2_0.dll, 1.00.0000.0000 (Invariant Language), 11/2/2016 13:02:18, 27656 bytes Driver: C:\Windows\system32\GfxUIEx.exe, 6.15.0010.4534 (English), 11/2/2016 13:02:11, 458720 bytes Driver: C:\Windows\system32\Gfxv4_0.exe, 8.15.0010.4534 (English), 11/2/2016 13:02:11, 912864 bytes Driver: C:\Windows\system32\Gfxv4_0.exe.config, 11/19/2015 19:55:20, 935 bytes Driver: C:\Windows\system32\Gfxv2_0.exe, 8.15.0010.4534 (English), 11/2/2016 13:02:11, 907232 bytes Driver: C:\Windows\system32\Gfxv2_0.exe.config, 11/19/2015 19:55:20, 895 bytes Driver: C:\Windows\system32\GfxResources.dll, 8.15.0010.4534 (English), 11/2/2016 13:02:11, 5056520 bytes Driver: C:\Windows\system32\MetroIntelGenericUIFramework.dll, 1.00.0000.0000 (English), 11/2/2016 13:02:18, 640008 bytes Driver: C:\Windows\system32\igfxCUIServicePS.dll, 11/2/2016 13:02:18, 102920 bytes Driver: C:\Windows\system32\igfxCUIService.exe, 6.15.0010.4534 (English), 11/2/2016 13:02:18, 341984 bytes Driver: C:\Windows\system32\igfxCPL.cpl, 11/2/2016 13:02:18, 271368 bytes Driver: C:\Windows\system32\igfxDTCM.dll, 6.15.0010.4534 (English), 11/2/2016 13:02:18, 208392 bytes Driver: C:\Windows\system32\igfxext.exe, 6.15.0010.4534 (English), 11/2/2016 13:02:18, 302560 bytes Driver: C:\Windows\system32\igfxexps.dll, 6.15.0010.4534 (English), 11/2/2016 13:02:18, 55248 bytes Driver: C:\Windows\system32\ColorImageEnhancement.wmv, 11/19/2015 19:55:16, 375173 bytes Driver: C:\Windows\system32\ImageStabilization.wmv, 11/19/2015 19:55:42, 403671 bytes Driver: C:\Windows\system32\FilmModeDetection.wmv, 11/19/2015 19:55:20, 641530 bytes Driver: C:\Windows\SysWow64\igfxexps32.dll, 6.15.0010.4534 (English), 11/2/2016 13:02:18, 52744 bytes Driver: C:\Windows\system32\ig9icd64.dll, 21.20.0016.4534 (English), 11/2/2016 13:02:11, 13801992 bytes Driver: C:\Windows\SysWow64\ig9icd32.dll, 21.20.0016.4534 (English), 11/2/2016 13:02:11, 10542600 bytes Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\llvm_release_license.txt, 11/19/2015 19:55:46, 1981 bytes Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\readme.txt, 11/19/2015 19:55:48, 9788 bytes Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\version.ini, 11/2/2016 13:02:19, 32 bytes Driver: C:\Windows\SysWow64\Intel_OpenCL_ICD32.dll, 2.01.0000.0000 (English), 11/2/2016 13:02:18, 104464 bytes Driver: C:\Windows\SysWow64\IntelOpenCL32.dll, 21.20.0016.4534 (English), 11/2/2016 13:02:18, 325640 bytes Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\task_executor32.dll, 6.06.0000.0359 (English), 11/2/2016 13:02:19, 378376 bytes Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\OclCpuBackend32.dll, 6.06.0000.0359 (English), 11/2/2016 13:02:19, 8677392 bytes Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\intelocl32.dll, 6.06.0000.0359 (English), 11/2/2016 13:02:19, 1470984 bytes Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\cpu_device32.dll, 6.06.0000.0359 (English), 11/2/2016 13:02:19, 525328 bytes Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\clbltfnn8.rtl, 11/2/2016 13:02:19, 1304100 bytes Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\clbltfnn8_img_cbk.o, 11/2/2016 13:02:19, 321224 bytes Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\clbltfnn8_img_cbk.rtl, 11/2/2016 13:02:19, 392476 bytes Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\clbltfng9.rtl, 11/2/2016 13:02:19, 1242036 bytes Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\clbltfng9_img_cbk.o, 11/2/2016 13:02:19, 312484 bytes Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\clbltfng9_img_cbk.rtl, 11/2/2016 13:02:19, 392356 bytes Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\clbltfns9.rtl, 11/2/2016 13:02:19, 897152 bytes Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\clbltfns9_img_cbk.o, 11/2/2016 13:02:19, 263856 bytes Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\clbltfns9_img_cbk.rtl, 11/2/2016 13:02:19, 350160 bytes Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\clang_compiler32.dll, 6.06.0000.0359 (English), 11/2/2016 13:02:19, 1427464 bytes Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\__ocl_svml_n8.dll, 3.04.0000.0000 (English), 11/2/2016 13:02:19, 5022728 bytes Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\__ocl_svml_g9.dll, 3.04.0000.0000 (English), 11/2/2016 13:02:19, 5360136 bytes Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\__ocl_svml_s9.dll, 3.04.0000.0000 (English), 11/2/2016 13:02:19, 5238280 bytes Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\tbb\tbbmalloc.dll, 4.03.2015.0528 (English), 11/2/2016 13:02:19, 274088 bytes Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\tbb\tbb.dll, 4.03.2015.0528 (English), 11/2/2016 13:02:19, 436392 bytes Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\tbb\tbb_preview.dll, 4.02.2013.1002 (), 11/2/2016 13:02:19, 356000 bytes Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\common\clbltfnshared.rtl, 11/2/2016 13:02:19, 1066888 bytes Driver: C:\Windows\system32\Intel_OpenCL_ICD64.dll, 2.01.0000.0000 (English), 11/2/2016 13:02:18, 113672 bytes Driver: C:\Windows\system32\IntelOpenCL64.dll, 21.20.0016.4534 (English), 11/2/2016 13:02:18, 427536 bytes Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\task_executor64.dll, 6.06.0000.0359 (English), 11/2/2016 13:02:19, 434696 bytes Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\OclCpuBackend64.dll, 6.06.0000.0359 (English), 11/2/2016 13:02:19, 11609096 bytes Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\intelocl64.dll, 6.06.0000.0359 (English), 11/2/2016 13:02:19, 1711112 bytes Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\cpu_device64.dll, 6.06.0000.0359 (English), 11/2/2016 13:02:19, 671240 bytes Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\clbltfnh8.rtl, 11/2/2016 13:02:19, 1251848 bytes Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\clbltfnh8_img_cbk.o, 11/2/2016 13:02:19, 344208 bytes Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\clbltfnh8_img_cbk.rtl, 11/2/2016 13:02:19, 407884 bytes Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\clbltfne9.rtl, 11/2/2016 13:02:19, 1189792 bytes Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\clbltfne9_img_cbk.o, 11/2/2016 13:02:19, 331136 bytes Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\clbltfne9_img_cbk.rtl, 11/2/2016 13:02:19, 407764 bytes Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\clbltfnl9.rtl, 11/2/2016 13:02:19, 829680 bytes Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\clbltfnl9_img_cbk.o, 11/2/2016 13:02:19, 283240 bytes Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\clbltfnl9_img_cbk.rtl, 11/2/2016 13:02:19, 365936 bytes Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\clang_compiler64.dll, 6.06.0000.0359 (English), 11/2/2016 13:02:19, 1869832 bytes Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\__ocl_svml_h8.dll, 3.04.0000.0000 (English), 11/2/2016 13:02:19, 5234184 bytes Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\__ocl_svml_e9.dll, 3.04.0000.0000 (English), 11/2/2016 13:02:19, 5744648 bytes Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\__ocl_svml_l9.dll, 3.04.0000.0000 (English), 11/2/2016 13:02:19, 5627400 bytes Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\tbb\tbbmalloc.dll, 4.03.2015.0528 (English), 11/2/2016 13:02:19, 323752 bytes Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\tbb\tbb.dll, 4.03.2015.0528 (English), 11/2/2016 13:02:19, 521896 bytes Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\tbb\tbb_preview.dll, 4.02.2013.1002 (), 11/2/2016 13:02:19, 433824 bytes Driver: C:\Windows\SysWow64\IntelOpenCL32.dll, 21.20.0016.4534 (English), 11/2/2016 13:02:18, 325640 bytes Driver: C:\Windows\SysWow64\igdbcl32.dll, 21.20.0016.4534 (English), 11/2/2016 13:02:13, 412168 bytes Driver: C:\Windows\SysWow64\igdrcl32.dll, 21.20.0016.4534 (English), 11/2/2016 13:02:13, 6386192 bytes Driver: C:\Windows\SysWow64\common_clang32.dll, 4.03.0006.0427 (English), 11/2/2016 13:02:11, 24667664 bytes Driver: C:\Windows\SysWow64\igdmcl32.dll, 21.20.0016.4534 (English), 11/2/2016 13:02:13, 4840456 bytes Driver: C:\Windows\SysWow64\igdfcl32.dll, 21.20.0016.4534 (English), 11/2/2016 13:02:13, 239112 bytes Driver: C:\Windows\system32\IntelOpenCL64.dll, 21.20.0016.4534 (English), 11/2/2016 13:02:18, 427536 bytes Driver: C:\Windows\system32\igdbcl64.dll, 21.20.0016.4534 (English), 11/2/2016 13:02:13, 460808 bytes Driver: C:\Windows\system32\igdrcl64.dll, 21.20.0016.4534 (English), 11/2/2016 13:02:13, 7089672 bytes Driver: C:\Windows\system32\common_clang64.dll, 4.03.0006.0427 (English), 11/2/2016 13:02:11, 36624904 bytes Driver: C:\Windows\system32\igdmcl64.dll, 21.20.0016.4534 (English), 11/2/2016 13:02:13, 6886920 bytes Driver: C:\Windows\system32\igdfcl64.dll, 21.20.0016.4534 (English), 11/2/2016 13:02:13, 279048 bytes Driver: C:\Windows\system32\igdclbif.bin, 11/2/2016 13:02:13, 8096666 bytes Driver: C:\Windows\SysWow64\libEGL.dll, 11/2/2016 13:02:18, 141320 bytes Driver: C:\Windows\SysWow64\libGLESv1_CM.dll, 11/2/2016 13:02:18, 101384 bytes Driver: C:\Windows\SysWow64\libGLESv2.dll, 11/2/2016 13:02:18, 112136 bytes Driver: C:\Program Files\Intel\Media SDK\libmfxhw32.dll, 7.16.0009.0019 (English), 11/2/2016 13:02:18, 8838456 bytes Driver: C:\Program Files\Intel\Media SDK\mfxplugin32_hw.dll, 1.16.0009.0019 (English), 11/2/2016 13:02:18, 4719320 bytes Driver: C:\Program Files\Intel\Media SDK\mfx_mft_h264ve_32.dll, 7.16.0009.0026 (English), 11/2/2016 13:02:18, 1478096 bytes Driver: C:\Program Files\Intel\Media SDK\mfx_mft_mjpgvd_32.dll, 7.16.0009.0026 (English), 11/2/2016 13:02:18, 1368792 bytes Driver: C:\Program Files\Intel\Media SDK\mfx_mft_vp8vd_32.dll, 7.16.0009.0026 (English), 11/2/2016 13:02:18, 1378520 bytes Driver: C:\Program Files\Intel\Media SDK\mfx_mft_vp9vd_32.dll, 7.16.0009.0026 (English), 11/2/2016 13:02:18, 1378520 bytes Driver: C:\Program Files\Intel\Media SDK\mfx_mft_h265ve_32.dll, 7.16.0009.0026 (English), 11/2/2016 13:02:18, 1493336 bytes Driver: C:\Program Files\Intel\Media SDK\h265e_32.vp, 11/2/2016 13:02:11, 65737 bytes Driver: C:\Program Files\Intel\Media SDK\he_32.vp, 11/2/2016 13:02:11, 64141 bytes Driver: C:\Program Files\Intel\Media SDK\c_32.cpa, 11/19/2015 19:55:20, 846855 bytes Driver: C:\Program Files\Intel\Media SDK\cpa_32.vp, 11/2/2016 13:02:11, 993 bytes Driver: C:\Program Files\Intel\Media SDK\dev_32.vp, 11/2/2016 13:02:11, 21523 bytes Driver: C:\Program Files\Intel\Media SDK\mj_32.vp, 11/2/2016 13:02:19, 59421 bytes Driver: C:\Program Files\Intel\Media SDK\libmfxhw64.dll, 7.16.0009.0019 (English), 11/2/2016 13:02:18, 9272792 bytes Driver: C:\Program Files\Intel\Media SDK\mfxplugin64_hw.dll, 1.16.0009.0019 (English), 11/2/2016 13:02:18, 4886752 bytes Driver: C:\Program Files\Intel\Media SDK\mfx_mft_h264ve_64.dll, 7.16.0009.0026 (English), 11/2/2016 13:02:18, 1835544 bytes Driver: C:\Program Files\Intel\Media SDK\mfx_mft_mjpgvd_64.dll, 7.16.0009.0026 (English), 11/2/2016 13:02:18, 1699552 bytes Driver: C:\Program Files\Intel\Media SDK\mfx_mft_vp8vd_64.dll, 7.16.0009.0026 (English), 11/2/2016 13:02:18, 1708760 bytes Driver: C:\Program Files\Intel\Media SDK\mfx_mft_vp9vd_64.dll, 7.16.0009.0026 (English), 11/2/2016 13:02:18, 1709280 bytes Driver: C:\Program Files\Intel\Media SDK\mfx_mft_h265ve_64.dll, 7.16.0009.0026 (English), 11/2/2016 13:02:18, 1860784 bytes Driver: C:\Program Files\Intel\Media SDK\h265e_64.vp, 11/2/2016 13:02:11, 13761 bytes Driver: C:\Program Files\Intel\Media SDK\he_64.vp, 11/2/2016 13:02:11, 13141 bytes Driver: C:\Program Files\Intel\Media SDK\c_64.cpa, 11/19/2015 19:55:20, 1519616 bytes Driver: C:\Program Files\Intel\Media SDK\cpa_64.vp, 11/2/2016 13:02:11, 993 bytes Driver: C:\Program Files\Intel\Media SDK\dev_64.vp, 11/2/2016 13:02:11, 21523 bytes Driver: C:\Program Files\Intel\Media SDK\mj_64.vp, 11/2/2016 13:02:19, 12621 bytes Driver: C:\Windows\system32\igfxCoIn_v4534.dll, 1.03.0020.0000 (English), 11/2/2016 13:02:18, 220168 bytes Driver: C:\Windows\system32\DisplayAudiox64.cab, 11/2/2016 13:02:11, 908485 bytes Name: Intel(R) Xeon(R) E3 - 1200/1500 v5/6th Gen Intel(R) Core(TM) Gaussian Mixture Model - 1911 Device ID: PCI\VEN_8086&DEV_1911&SUBSYS_20158086&REV_00\3&11583659&0&40 Driver: n/a Name: Standard SATA AHCI Controller Device ID: PCI\VEN_8086&DEV_A102&SUBSYS_72708086&REV_31\3&11583659&0&B8 Driver: C:\Windows\system32\DRIVERS\storahci.sys, 10.00.10240.16384 (English), 7/10/2015 03:59:39, 133984 bytes Name: Intel(R) Serial IO UART Host Controller - A127 Device ID: PCI\VEN_8086&DEV_A127&SUBSYS_72708086&REV_31\3&11583659&0&F0 Driver: C:\Windows\system32\DRIVERS\iaLPSS2_UART2.sys, 30.63.1519.0007 (English), 7/20/2015 14:52:46, 281896 bytes Name: Intel(R) I210 Gigabit Network Connection Device ID: PCI\VEN_8086&DEV_1533&SUBSYS_00000000&REV_01\6&287B87F&0&00180008 Driver: C:\Windows\system32\DRIVERS\e1r65x64.sys, 12.12.0226.0000 (English), 4/21/2015 01:02:28, 486344 bytes Driver: C:\Windows\system32\e1r65x64.din, 5/4/2015 17:23:10, 3096 bytes Driver: C:\Windows\system32\NicCo4.dll, 4.02.0003.0000 (English), 4/18/2014 13:17:32, 125728 bytes Driver: C:\Windows\system32\NicInE1R.dll, 9.12.0010.0000 (English), 2/25/2015 04:23:58, 89872 bytes Driver: C:\Windows\system32\e1rmsg.dll, 10.00.0417.0000 (English), 4/2/2015 04:46:38, 75288 bytes Name: Intel(R) Xeon(R) E3 - 1200/1500 v5/6th Gen Intel(R) Core(TM) PCIe Controller (x16) - 1901 Device ID: PCI\VEN_8086&DEV_1901&SUBSYS_20158086&REV_07\3&11583659&0&08 Driver: C:\Windows\system32\DRIVERS\pci.sys, 10.00.10240.16942 (English), 5/27/2016 22:00:08, 327520 bytes Name: Intel(R) Ethernet Connection (2) I219-LM Device ID: PCI\VEN_8086&DEV_15B7&SUBSYS_00008086&REV_31\3&11583659&0&FE Driver: C:\Windows\system32\DRIVERS\e1d65x64.sys, 12.13.0017.0007 (English), 8/13/2015 02:14:46, 531424 bytes Driver: C:\Windows\system32\e1d65x64.din, 8/13/2015 02:13:12, 3130 bytes Driver: C:\Windows\system32\NicCo4.dll, 4.02.0003.0000 (English), 4/18/2014 13:17:32, 125728 bytes Driver: C:\Windows\system32\NicInstD.dll, 9.12.0013.0000 (English), 6/17/2015 01:28:44, 90608 bytes Driver: C:\Windows\system32\e1dmsg.dll, 10.00.0417.0000 (English), 4/2/2015 04:46:38, 75288 bytes Name: Intel(R) Serial IO I2C Host Controller - A161 Device ID: PCI\VEN_8086&DEV_A161&SUBSYS_72708086&REV_31\3&11583659&0&A9 Driver: C:\Windows\system32\DRIVERS\iaLPSS2_I2C.sys, 30.63.1519.0007 (English), 7/20/2015 14:52:46, 185128 bytes ------------------ DirectShow Filters ------------------ DirectShow Filters: WMAudio Decoder DMO,0x00800800,1,1,WMADMOD.DLL,10.00.10240.16644 WMAPro over S/PDIF DMO,0x00600800,1,1,WMADMOD.DLL,10.00.10240.16644 WMSpeech Decoder DMO,0x00600800,1,1,WMSPDMOD.DLL,10.00.10240.16644 MP3 Decoder DMO,0x00600800,1,1,mp3dmod.dll,10.00.10240.16644 Mpeg4s Decoder DMO,0x00800001,1,1,mp4sdecd.dll,10.00.10240.16644 WMV Screen decoder DMO,0x00600800,1,1,wmvsdecd.dll,10.00.10240.16644 WMVideo Decoder DMO,0x00800001,1,1,wmvdecod.dll,10.00.10240.17113 Mpeg43 Decoder DMO,0x00800001,1,1,mp43decd.dll,10.00.10240.16644 Mpeg4 Decoder DMO,0x00800001,1,1,mpg4decd.dll,10.00.10240.16644 DV Muxer,0x00400000,0,0,qdv.dll,10.00.10240.16384 Color Space Converter,0x00400001,1,1,quartz.dll,10.00.10240.17113 WM ASF Reader,0x00400000,0,0,qasf.dll,12.00.10240.16384 AVI Splitter,0x00600000,1,1,quartz.dll,10.00.10240.17113 VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,10.00.10240.17113 SBE2MediaTypeProfile,0x00200000,0,0,sbe.dll,10.00.10240.16384 Microsoft DTV-DVD Video Decoder,0x005fffff,2,4,msmpeg2vdec.dll,12.00.10240.16635 AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,10.00.10240.16384 StreamBufferSink,0x00200000,0,0,sbe.dll,10.00.10240.16384 MJPEG Decompressor,0x00600000,1,1,quartz.dll,10.00.10240.17113 MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,10.00.10240.17113 SAMI (CC) Parser,0x00400000,1,1,quartz.dll,10.00.10240.17113 VBI Codec,0x00600000,1,4,VBICodec.ax,10.00.10240.16384 MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,10.00.10240.16384 Closed Captions Analysis Filter,0x00200000,2,5,cca.dll,10.00.10240.16384 SBE2FileScan,0x00200000,0,0,sbe.dll,10.00.10240.16384 Microsoft MPEG-2 Video Encoder,0x00200000,1,1,msmpeg2enc.dll,12.00.10240.16644 Internal Script Command Renderer,0x00800001,1,0,quartz.dll,10.00.10240.17113 MPEG Audio Decoder,0x03680001,1,1,quartz.dll,10.00.10240.17113 DV Splitter,0x00600000,1,2,qdv.dll,10.00.10240.16384 Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,10.00.10240.17113 Microsoft MPEG-2 Encoder,0x00200000,2,1,msmpeg2enc.dll,12.00.10240.16644 ACM Wrapper,0x00600000,1,1,quartz.dll,10.00.10240.17113 Video Renderer,0x00800001,1,0,quartz.dll,10.00.10240.17113 MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,10.00.10240.16384 Line 21 Decoder,0x00600000,1,1,, Video Port Manager,0x00600000,2,1,quartz.dll,10.00.10240.17113 Video Renderer,0x00400000,1,0,quartz.dll,10.00.10240.17113 VPS Decoder,0x00200000,0,0,WSTPager.ax,10.00.10240.16384 WM ASF Writer,0x00400000,0,0,qasf.dll,12.00.10240.16384 VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,10.00.10240.16384 File writer,0x00200000,1,0,qcap.dll,10.00.10240.16384 DVD Navigator,0x00200000,0,3,qdvd.dll,10.00.10240.16644 Overlay Mixer2,0x00200000,1,1,, Microsoft MPEG-2 Audio Encoder,0x00200000,1,1,msmpeg2enc.dll,12.00.10240.16644 WST Pager,0x00200000,1,1,WSTPager.ax,10.00.10240.16384 MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,10.00.10240.16384 DV Video Decoder,0x00800000,1,1,qdv.dll,10.00.10240.16384 SampleGrabber,0x00200000,1,1,qedit.dll,10.00.10240.16644 Null Renderer,0x00200000,1,0,qedit.dll,10.00.10240.16644 MPEG-2 Sections and Tables,0x005fffff,1,0,Mpeg2Data.ax,10.00.10240.16384 Microsoft AC3 Encoder,0x00200000,1,1,msac3enc.dll,10.00.10240.16384 StreamBufferSource,0x00200000,0,0,sbe.dll,10.00.10240.16384 Smart Tee,0x00200000,1,2,qcap.dll,10.00.10240.16384 Overlay Mixer,0x00200000,0,0,, AVI Decompressor,0x00600000,1,1,quartz.dll,10.00.10240.17113 AVI/WAV File Source,0x00400000,0,2,quartz.dll,10.00.10240.17113 Wave Parser,0x00400000,1,1,quartz.dll,10.00.10240.17113 MIDI Parser,0x00400000,1,1,quartz.dll,10.00.10240.17113 Multi-file Parser,0x00400000,1,1,quartz.dll,10.00.10240.17113 File stream renderer,0x00400000,1,1,quartz.dll,10.00.10240.17113 Microsoft DTV-DVD Audio Decoder,0x005fffff,1,1,msmpeg2adec.dll,12.00.10240.16635 StreamBufferSink2,0x00200000,0,0,sbe.dll,10.00.10240.16384 AVI Mux,0x00200000,1,0,qcap.dll,10.00.10240.16384 Line 21 Decoder 2,0x00600002,1,1,quartz.dll,10.00.10240.17113 File Source (Async.),0x00400000,0,1,quartz.dll,10.00.10240.17113 File Source (URL),0x00400000,0,1,quartz.dll,10.00.10240.17113 Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,10.00.10240.16384 Enhanced Video Renderer,0x00200000,1,0,evr.dll,10.00.10240.17113 BDA MPEG2 Transport Information Filter,0x00200000,2,0,psisrndr.ax,10.00.10240.16384 MPEG Video Decoder,0x40000001,1,1,quartz.dll,10.00.10240.17113 WDM Streaming Tee/Splitter Devices: Tee/Sink-to-Sink Converter,0x00200000,1,1,ksproxy.ax,10.00.10240.16644 Video Compressors: WMVideo8 Encoder DMO,0x00600800,1,1,wmvxencd.dll,10.00.10240.16644 WMVideo9 Encoder DMO,0x00600800,1,1,wmvencod.dll,10.00.10240.16644 MSScreen 9 encoder DMO,0x00600800,1,1,wmvsencd.dll,10.00.10240.16644 DV Video Encoder,0x00200000,0,0,qdv.dll,10.00.10240.16384 MJPEG Compressor,0x00200000,0,0,quartz.dll,10.00.10240.17113 Audio Compressors: WM Speech Encoder DMO,0x00600800,1,1,WMSPDMOE.DLL,10.00.10240.16644 WMAudio Encoder DMO,0x00600800,1,1,WMADMOE.DLL,10.00.10240.16644 IMA ADPCM,0x00200000,1,1,quartz.dll,10.00.10240.17113 PCM,0x00200000,1,1,quartz.dll,10.00.10240.17113 Microsoft ADPCM,0x00200000,1,1,quartz.dll,10.00.10240.17113 GSM 6.10,0x00200000,1,1,quartz.dll,10.00.10240.17113 CCITT A-Law,0x00200000,1,1,quartz.dll,10.00.10240.17113 CCITT u-Law,0x00200000,1,1,quartz.dll,10.00.10240.17113 MPEG Layer-3,0x00200000,1,1,quartz.dll,10.00.10240.17113 Audio Capture Sources: Line In (Realtek High Definition Audio),0x00200000,0,0,qcap.dll,10.00.10240.16384 Stereo Mix (Realtek High Definition Audio),0x00200000,0,0,qcap.dll,10.00.10240.16384 PBDA CP Filters: PBDA DTFilter,0x00600000,1,1,CPFilters.dll,10.00.10240.17113 PBDA ETFilter,0x00200000,0,0,CPFilters.dll,10.00.10240.17113 PBDA PTFilter,0x00200000,0,0,CPFilters.dll,10.00.10240.17113 Midi Renderers: Default MidiOut Device,0x00800000,1,0,quartz.dll,10.00.10240.17113 Microsoft GS Wavetable Synth,0x00200000,1,0,quartz.dll,10.00.10240.17113 WDM Streaming Capture Devices: Realtek HD Audio Line input,0x00200000,1,1,ksproxy.ax,10.00.10240.16644 Realtek HD Audio Stereo input,0x00200000,1,1,ksproxy.ax,10.00.10240.16644 Realtek HD Audio Mic input,0x00200000,1,1,ksproxy.ax,10.00.10240.16644 WDM Streaming Rendering Devices: Realtek HD Audio output,0x00200000,1,1,ksproxy.ax,10.00.10240.16644 BDA Network Providers: Microsoft ATSC Network Provider,0x00200000,0,1,MSDvbNP.ax,10.00.10240.16384 Microsoft DVBC Network Provider,0x00200000,0,1,MSDvbNP.ax,10.00.10240.16384 Microsoft DVBS Network Provider,0x00200000,0,1,MSDvbNP.ax,10.00.10240.16384 Microsoft DVBT Network Provider,0x00200000,0,1,MSDvbNP.ax,10.00.10240.16384 Microsoft Network Provider,0x00200000,0,1,MSNP.ax,10.00.10240.16384 Multi-Instance Capable VBI Codecs: VBI Codec,0x00600000,1,4,VBICodec.ax,10.00.10240.16384 BDA Transport Information Renderers: BDA MPEG2 Transport Information Filter,0x00600000,2,0,psisrndr.ax,10.00.10240.16384 MPEG-2 Sections and Tables,0x00600000,1,0,Mpeg2Data.ax,10.00.10240.16384 BDA CP/CA Filters: Decrypt/Tag,0x00600000,1,1,EncDec.dll,10.00.10240.17113 Encrypt/Tag,0x00200000,0,0,EncDec.dll,10.00.10240.17113 PTFilter,0x00200000,0,0,EncDec.dll,10.00.10240.17113 XDS Codec,0x00200000,0,0,EncDec.dll,10.00.10240.17113 WDM Streaming Communication Transforms: Tee/Sink-to-Sink Converter,0x00200000,1,1,ksproxy.ax,10.00.10240.16644 Audio Renderers: Default DirectSound Device,0x00800000,1,0,quartz.dll,10.00.10240.17113 Default WaveOut Device,0x00200000,1,0,quartz.dll,10.00.10240.17113 ---------------------------- Preferred DirectShow Filters ---------------------------- [HKEY_LOCAL_MACHINE\Software\Microsoft\DirectShow\Preferred] <media subtype GUID>, [<filter friendly name>, ]<filter CLSID> MEDIASUBTYPE_MPEG1Payload, MPEG Video Decoder, CLSID_CMpegVideoCodec MEDIASUBTYPE_MPEG1Packet, MPEG Video Decoder, CLSID_CMpegVideoCodec MEDIASUBTYPE_DVD_LPCM_AUDIO, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS MEDIASUBTYPE_MPEG2_AUDIO, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS MEDIASUBTYPE_MPEG2_VIDEO, Microsoft DTV-DVD Video Decoder, CLSID_CMPEG2VidDecoderDS {78766964-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject {7634706D-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject MEDIASUBTYPE_mp4s, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject {6C737664-0000-0010-8000-00AA00389B71}, DV Video Decoder, CLSID_DVVideoCodec {64737664-0000-0010-8000-00AA00389B71}, DV Video Decoder, CLSID_DVVideoCodec {64697678-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject {64687664-0000-0010-8000-00AA00389B71}, DV Video Decoder, CLSID_DVVideoCodec {58564944-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject {5634504D-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject MEDIASUBTYPE_MP4S, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject MEDIASUBTYPE_WMVR, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject MEDIASUBTYPE_WMVP, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject MEDIASUBTYPE_MJPG, MJPEG Decompressor, CLSID_MjpegDec {44495658-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject MEDIASUBTYPE_WMVA, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject MEDIASUBTYPE_mpg4, Mpeg4 Decoder DMO, CLSID_CMpeg4DecMediaObject MEDIASUBTYPE_MPG4, Mpeg4 Decoder DMO, CLSID_CMpeg4DecMediaObject MEDIASUBTYPE_h264, Microsoft DTV-DVD Video Decoder, CLSID_CMPEG2VidDecoderDS MEDIASUBTYPE_H264, Microsoft DTV-DVD Video Decoder, CLSID_CMPEG2VidDecoderDS MEDIASUBTYPE_WMV3, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject MEDIASUBTYPE_mp43, Mpeg43 Decoder DMO, CLSID_CMpeg43DecMediaObject MEDIASUBTYPE_MP43, Mpeg43 Decoder DMO, CLSID_CMpeg43DecMediaObject MEDIASUBTYPE_m4s2, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject MEDIASUBTYPE_WMV2, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject MEDIASUBTYPE_MSS2, WMV Screen decoder DMO, CLSID_CMSSCDecMediaObject MEDIASUBTYPE_M4S2, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject MEDIASUBTYPE_WVP2, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject MEDIASUBTYPE_mp42, Mpeg4 Decoder DMO, CLSID_CMpeg4DecMediaObject MEDIASUBTYPE_MP42, Mpeg4 Decoder DMO, CLSID_CMpeg4DecMediaObject MEDIASUBTYPE_WMV1, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject MEDIASUBTYPE_MSS1, WMV Screen decoder DMO, CLSID_CMSSCDecMediaObject MEDIASUBTYPE_WVC1, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject MEDIASUBTYPE_AVC1, Microsoft DTV-DVD Video Decoder, CLSID_CMPEG2VidDecoderDS {20637664-0000-0010-8000-00AA00389B71}, DV Video Decoder, CLSID_DVVideoCodec MEDIASUBTYPE_MPEG_LOAS, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS MEDIASUBTYPE_MPEG_ADTS_AAC, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS MEDIASUBTYPE_WMAUDIO_LOSSLESS, WMAudio Decoder DMO, CLSID_CWMADecMediaObject MEDIASUBTYPE_WMAUDIO3, WMAudio Decoder DMO, CLSID_CWMADecMediaObject WMMEDIASUBTYPE_WMAudioV8, WMAudio Decoder DMO, CLSID_CWMADecMediaObject MEDIASUBTYPE_MSAUDIO1, WMAudio Decoder DMO, CLSID_CWMADecMediaObject MEDIASUBTYPE_RAW_AAC1, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS WMMEDIASUBTYPE_MP3, MP3 Decoder DMO, CLSID_CMP3DecMediaObject MEDIASUBTYPE_MPEG1AudioPayload, MPEG Audio Decoder, CLSID_CMpegAudioCodec WMMEDIASUBTYPE_WMSP2, WMSpeech Decoder DMO, CLSID_CWMSPDecMediaObject WMMEDIASUBTYPE_WMSP1, WMSpeech Decoder DMO, CLSID_CWMSPDecMediaObject --------------------------- Media Foundation Transforms --------------------------- [HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\Transforms] <category>: <transform friendly name>, <transform CLSID>, <flags>, [<merit>, ]<file name>, <file version> Video Decoders: Intel® Hardware M-JPEG Decoder MFT, {00C69F81-0524-48C0-A353-4DD9D54F9A6E}, 0x6, 7, mfx_mft_mjpgvd_64.dll, 7.16.0009.0026 Intel® Hardware VP8 Decoder MFT, {6D856398-834E-4A89-8EE5-071BB3F58BE4}, 0x6, mfx_mft_vp8vd_64.dll, 7.16.0009.0026 Microsoft MPEG Video Decoder MFT, {2D709E52-123F-49B5-9CBC-9AF5CDE28FB9}, 0x1, msmpeg2vdec.dll, 12.00.10240.16635 DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}, 0x1, mfdvdec.dll, 10.00.10240.16384 Microsoft H265 Video Decoder MFT, {420A51A3-D605-430C-B4FC-45274FA6C562}, 0x1, hevcdecoder.dll, 10.00.10240.17202 Intel® Hardware VP8 Sync Decoder MFT, {451E3CB7-2622-4BA5-8E1D-44B3C41D0924}, 0x1, mfx_mft_vp8vd_64.dll, 7.16.0009.0026 Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT, 0x1, mp4sdecd.dll, 10.00.10240.16644 Microsoft H264 Video Decoder MFT, CLSID_CMSH264DecoderMFT, 0x1, msmpeg2vdec.dll, 12.00.10240.16635 WMV Screen decoder MFT, CLSID_CMSSCDecMediaObject, 0x1, wmvsdecd.dll, 10.00.10240.16644 WMVideo Decoder MFT, CLSID_CWMVDecMediaObject, 0x1, wmvdecod.dll, 10.00.10240.17113 MJPEG Decoder MFT, {CB17E772-E1CC-4633-8450-5617AF577905}, 0x1, mfmjpegdec.dll, 10.00.10240.16384 Mpeg43 Decoder MFT, CLSID_CMpeg43DecMediaObject, 0x1, mp43decd.dll, 10.00.10240.16644 Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject, 0x1, mpg4decd.dll, 10.00.10240.16644 Video Encoders: Intel® Quick Sync Video H.264 Encoder MFT, {4BE8D3C0-0515-4A37-AD55-E4BAE19AF471}, 0x4, 7, mfx_mft_h264ve_64.dll, 7.16.0009.0026 Intel® Hardware H265 Encoder MFT, {BC10864D-2B34-408F-912A-102B1B867B6C}, 0x4, 7, mfx_mft_h265ve_64.dll, 7.16.0009.0026 H264 Encoder MFT, {6CA50344-051A-4DED-9779-A43305165E35}, 0x1, mfh264enc.dll, 10.00.10240.16644 WMVideo8 Encoder MFT, CLSID_CWMVXEncMediaObject, 0x1, wmvxencd.dll, 10.00.10240.16644 H263 Encoder MFT, {BC47FCFE-98A0-4F27-BB07-698AF24F2B38}, 0x1, mfh263enc.dll, 10.00.10240.16384 WMVideo9 Encoder MFT, CLSID_CWMV9EncMediaObject, 0x1, wmvencod.dll, 10.00.10240.16644 Microsoft MPEG-2 Video Encoder MFT, {E6335F02-80B7-4DC4-ADFA-DFE7210D20D5}, 0x2, msmpeg2enc.dll, 12.00.10240.16644 H265 Encoder MFT, {F2F84074-8BCA-40BD-9159-E880F673DD3B}, 0x1, mfh265enc.dll, 10.00.10240.16384 Video Effects: Frame Rate Converter, CLSID_CFrameRateConvertDmo, 0x1, mfvdsp.dll, 10.00.10240.16644 Resizer MFT, CLSID_CResizerDMO, 0x1, vidreszr.dll, 10.00.10240.16644 VideoStabilization MFT, {51571744-7FE4-4FF2-A498-2DC34FF74F1B}, 0x1, MSVideoDSP.dll, 10.00.10240.16384 Color Control, CLSID_CColorControlDmo, 0x1, mfvdsp.dll, 10.00.10240.16644 Color Converter MFT, CLSID_CColorConvertDMO, 0x1, colorcnv.dll, 10.00.10240.16644 Video Processor: Microsoft Video Processor MFT, {88753B26-5B24-49BD-B2E7-0C445C78C982}, 0x1, msvproc.dll, 12.00.10240.16384 Audio Decoders: Microsoft Dolby Digital Plus Decoder MFT, {177C0AFE-900B-48D4-9E4C-57ADD250B3D4}, 0x1, DolbyDecMFT.dll, 10.00.10240.16384 MS AMRNB Decoder MFT, {265011AE-5481-4F77-A295-ABB6FFE8D63E}, 0x1, MSAMRNBDecoder.dll, 10.00.10240.16384 WMAudio Decoder MFT, CLSID_CWMADecMediaObject, 0x1, WMADMOD.DLL, 10.00.10240.16644 Microsoft AAC Audio Decoder MFT, CLSID_CMSAACDecMFT, 0x1, MSAudDecMFT.dll, 10.00.10240.16384 A-law Wrapper MFT, {36CB6E0C-78C1-42B2-9943-846262F31786}, 0x1, mfcore.dll, 12.00.10240.17202 GSM ACM Wrapper MFT, {4A76B469-7B66-4DD4-BA2D-DDF244C766DC}, 0x1, mfcore.dll, 12.00.10240.17202 WMAPro over S/PDIF MFT, CLSID_CWMAudioSpdTxDMO, 0x1, WMADMOD.DLL, 10.00.10240.16644 Microsoft FLAC Audio Decoder MFT, {6B0B3E6B-A2C5-4514-8055-AFE8A95242D9}, 0x1, MSFlacDecoder.dll, 10.00.10240.16384 Microsoft MPEG Audio Decoder MFT, {70707B39-B2CA-4015-ABEA-F8447D22D88B}, 0x1, MSAudDecMFT.dll, 10.00.10240.16384 WMSpeech Decoder DMO, CLSID_CWMSPDecMediaObject, 0x1, WMSPDMOD.DLL, 10.00.10240.16644 G711 Wrapper MFT, {92B66080-5E2D-449E-90C4-C41F268E5514}, 0x1, mfcore.dll, 12.00.10240.17202 IMA ADPCM ACM Wrapper MFT, {A16E1BFF-A80D-48AD-AECD-A35C005685FE}, 0x1, mfcore.dll, 12.00.10240.17202 MP3 Decoder MFT, CLSID_CMP3DecMediaObject, 0x1, mp3dmod.dll, 10.00.10240.16644 Microsoft ALAC Audio Decoder MFT, {C0CD7D12-31FC-4BBC-B363-7322EE3E1879}, 0x1, MSAlacDecoder.dll, 10.00.10240.16384 ADPCM ACM Wrapper MFT, {CA34FE0A-5722-43AD-AF23-05F7650257DD}, 0x1, mfcore.dll, 12.00.10240.17202 Audio Encoders: LPCM DVD-Audio MFT, {068A8476-9229-4CC0-9D49-2FC699DCD30A}, 0x1, winmde.dll, 12.00.10240.17146 MP3 Encoder ACM Wrapper MFT, {11103421-354C-4CCA-A7A3-1AFF9A5B6701}, 0x1, mfcore.dll, 12.00.10240.17202 Microsoft FLAC Audio Encoder MFT, {128509E9-C44E-45DC-95E9-C255B8F466A6}, 0x1, MSFlacEncoder.dll, 10.00.10240.16384 WM Speech Encoder DMO, CLSID_CWMSPEncMediaObject2, 0x1, WMSPDMOE.DLL, 10.00.10240.16644 MS AMRNB Encoder MFT, {2FAE8AFE-04A3-423A-A814-85DB454712B0}, 0x1, MSAMRNBEncoder.dll, 10.00.10240.16384 Microsoft MPEG-2 Audio Encoder MFT, {46A4DD5C-73F8-4304-94DF-308F760974F4}, 0x1, msmpeg2enc.dll, 12.00.10240.16644 WMAudio Encoder MFT, CLSID_CWMAEncMediaObject, 0x1, WMADMOE.DLL, 10.00.10240.16644 Microsoft AAC Audio Encoder MFT, {93AF0C51-2275-45D2-A35B-F2BA21CAED00}, 0x1, mfAACEnc.dll, 10.00.10240.16384 Microsoft ALAC Audio Encoder MFT, {9AB6A28C-748E-4B6A-BFFF-CC443B8E8FB4}, 0x1, MSAlacEncoder.dll, 10.00.10240.16384 Microsoft Dolby Digital Encoder MFT, {AC3315C9-F481-45D7-826C-0B406C1F64B8}, 0x1, msac3enc.dll, 10.00.10240.16384 Audio Effects: AEC, CLSID_CWMAudioAEC, 0x1, mfwmaaec.dll, 10.00.10240.16644 Resampler MFT, CLSID_CResamplerMediaObject, 0x1, resampledmo.dll, 10.00.10240.16644 Multiplexers: Microsoft MPEG2 Multiplexer MFT, {AB300F71-01AB-46D2-AB6C-64906CB03258}, 0x2, mfmpeg2srcsnk.dll, 12.00.10240.16412 Others: Microsoft H264 Video Remux (MPEG2TSToMP4) MFT, {05A47EBB-8BF0-4CBF-AD2F-3B71D75866F5}, 0x1, msmpeg2vdec.dll, 12.00.10240.16635 -------------------------------------------- Media Foundation Enabled Hardware Categories -------------------------------------------- [HKEY_LOCAL_MACHINE\Software\Microsoft\Windows Media Foundation\HardwareMFT] EnableEncoders = 1 EnableDecoders = 1 ------------------------------------- Media Foundation Byte Stream Handlers ------------------------------------- [HKEY_LOCAL_MACHINE\Software\Microsoft\Windows Media Foundation\ByteStreamHandlers] [HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\MediaSources\Preferred] <file ext. or MIME type>, <handler CLSID>, <brief description>[, Preferred] .3g2, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred .3gp, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred .3gp2, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred .3gpp, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred .aac, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred .ac3, {46031BA1-083F-47D9-8369-23C92BDAB2FF}, AC-3 Byte Stream Handler, Preferred .adt, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred .adts, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred .am?, {EFE6208A-0A2C-49FA-8A01-3768B559B6DA}, MF AMRNB Media Source ByteStreamHandler .amr, {EFE6208A-0A2C-49FA-8A01-3768B559B6DA}, MF AMRNB Media Source ByteStreamHandler, Preferred .asf, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred .avi, {7AFA253E-F823-42F6-A5D9-714BDE467412}, AVI Byte Stream Handler, Preferred .dvr-ms, {65964407-A5D8-4060-85B0-1CCD63F768E2}, dvr-ms Byte Stream Handler, Preferred .dvr-ms, {A8721937-E2FB-4D7A-A9EE-4EB08C890B6E}, MF SBE Source ByteStreamHandler .ec3, {46031BA1-083F-47D9-8369-23C92BDAB2FF}, AC-3 Byte Stream Handler, Preferred .flac, {0E41CFB8-0506-40F4-A516-77CC23642D91}, MF FLAC Media Source ByteStreamHandler, Preferred .m2t, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred .m2ts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred .m4a, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred .m4v, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred .mk3d, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred .mka, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred .mks, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred .mkv, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred .mod, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred .mov, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred .mp2v, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred .mp3, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred .mp4, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred .mp4v, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred .mpa, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred .mpeg, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred .mpg, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred .mts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred .nsc, {B084785C-DDE0-4D30-8CA8-05A373E185BE}, NSC Byte Stream Handler, Preferred .sami, {7A56C4CB-D678-4188-85A8-BA2EF68FA10D}, SAMI Byte Stream Handler, Preferred .smi, {7A56C4CB-D678-4188-85A8-BA2EF68FA10D}, SAMI Byte Stream Handler, Preferred .tod, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred .ts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred .tts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred .uvu, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred .vob, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred .wav, {42C9B9F5-16FC-47EF-AF22-DA05F7C842E3}, WAV Byte Stream Handler, Preferred .wm, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred .wma, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred .wmv, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred .wtv, {65964407-A5D8-4060-85B0-1CCD63F768E2}, WTV Byte Stream Handler, Preferred audio/3gpp, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred audio/3gpp2, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred audio/aac, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred audio/aacp, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred audio/eac3, {46031BA1-083F-47D9-8369-23C92BDAB2FF}, AC-3 Byte Stream Handler, Preferred audio/L16, {3FFB3B8C-EB99-472B-8902-E1C1B05F07CF}, LPCM Byte Stream Handler, Preferred audio/mp3, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred audio/mp4, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred audio/MP4A-LATM, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred audio/mpa, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred audio/mpeg, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred audio/mpeg3, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred audio/vnd.dlna.adts, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred audio/vnd.dolby.dd-raw, {46031BA1-083F-47D9-8369-23C92BDAB2FF}, AC-3 Byte Stream Handler, Preferred audio/wav, {42C9B9F5-16FC-47EF-AF22-DA05F7C842E3}, WAV Byte Stream Handler, Preferred audio/x-aac, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred audio/x-m4a, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred audio/x-matroska, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred audio/x-mp3, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred audio/x-mpeg, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred audio/x-ms-wma, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred audio/x-wav, {42C9B9F5-16FC-47EF-AF22-DA05F7C842E3}, WAV Byte Stream Handler, Preferred video/3gpp, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred video/3gpp2, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred video/avi, {7AFA253E-F823-42F6-A5D9-714BDE467412}, AVI Byte Stream Handler, Preferred video/mp4, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred video/mpeg, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred video/msvideo, {7AFA253E-F823-42F6-A5D9-714BDE467412}, AVI Byte Stream Handler, Preferred video/vnd.dece.mp4, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred video/vnd.dlna.mpeg-tts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred video/x-m4v, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred video/x-matroska, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred video/x-ms-asf, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred video/x-ms-wm, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred video/x-ms-wmv, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred video/x-msvideo, {7AFA253E-F823-42F6-A5D9-714BDE467412}, AVI Byte Stream Handler, Preferred -------------------------------- Media Foundation Scheme Handlers -------------------------------- [HKEY_LOCAL_MACHINE\Software\Microsoft\Windows Media Foundation\SchemeHandlers] [HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\MediaSources\Preferred] <URL type>, <handler CLSID>, <brief description>[, Preferred] file:, {477EC299-1421-4BDD-971F-7CCB933F21AD}, File Scheme Handler, Preferred http:, {44CB442B-9DA9-49DF-B3FD-023777B16E50}, Http Scheme Handler http:, {9EC4B4F9-3029-45AD-947B-344DE2A249E2}, Urlmon Scheme Handler http:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred httpd:, {44CB442B-9DA9-49DF-B3FD-023777B16E50}, Http Scheme Handler, Preferred httpnd:, {2EEEED04-0908-4CDB-AF8F-AC5B768A34C9}, Drm Scheme Handler, Preferred https:, {37A61C8B-7F8E-4D08-B12B-248D73E9AB4F}, Secure Http Scheme Handler, Preferred httpsd:, {37A61C8B-7F8E-4D08-B12B-248D73E9AB4F}, Secure Http Scheme Handler, Preferred httpt:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred httpu:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred mcast:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred mcrecv:, {FA6D33D4-9405-4BA5-9983-12604AC8E77A}, Miracast Sink Scheme Handler, Preferred mms:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred ms-appdata:, {CFC81939-3886-4ACF-9692-DA58037AE716}, MsAppData Scheme Handler, Preferred ms-appx-web:, {8DB0224B-3D65-4F6F-8E12-BEB4B78B8974}, MsAppxWeb Scheme Handler, Preferred ms-appx:, {8DB0224B-3D65-4F6F-8E12-BEB4B78B8974}, MsAppx Scheme Handler, Preferred ms-winsoundevent:, {F79A6BF9-7415-4CF3-AE10-4559509ABC3C}, Sound Event Scheme Handler, Preferred rtsp:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred rtspt:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred rtspu:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred sdp:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred ------------------------------------- Preferred Media Foundation Transforms ------------------------------------- [HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\Transforms\Preferred] <media subtype GUID>, [<transform friendly name>, ]<transform CLSID> {E06D802C-DB46-11CF-B4D1-00805F6CBBEA}, Microsoft Dolby Digital Plus Decoder MFT, {177C0AFE-900B-48D4-9E4C-57ADD250B3D4} MFVideoFormat_MPEG2, Microsoft MPEG Video Decoder MFT, {2D709E52-123F-49B5-9CBC-9AF5CDE28FB9} MEDIASUBTYPE_DOLBY_DDPLUS, Microsoft Dolby Digital Plus Decoder MFT, {177C0AFE-900B-48D4-9E4C-57ADD250B3D4} {7634706D-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT {73616D72-767A-494D-B478-F29D25DC9037}, MS AMRNB Decoder MFT, {265011AE-5481-4F77-A295-ABB6FFE8D63E} MEDIASUBTYPE_mp4s, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT MFVideoFormat_DVSL, DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432} MFVideoFormat_DVSD, DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432} MFVideoFormat_DVHD, DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432} {63616C61-0000-0010-8000-00AA00389B71}, Microsoft ALAC Audio Decoder MFT, {C0CD7D12-31FC-4BBC-B363-7322EE3E1879} MFVideoFormat_MP4V, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT {53564548-0000-0010-8000-00AA00389B71}, Microsoft H265 Video Decoder MFT, {420A51A3-D605-430C-B4FC-45274FA6C562} MFVideoFormat_MP4S, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT {53314356-0000-0010-8000-00AA00389B71}, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject MEDIASUBTYPE_WMVR, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject MEDIASUBTYPE_WMVP, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject MFVideoFormat_MJPG, MJPEG Decoder MFT, {CB17E772-E1CC-4633-8450-5617AF577905} {43564548-0000-0010-8000-00AA00389B71}, Microsoft H265 Video Decoder MFT, {420A51A3-D605-430C-B4FC-45274FA6C562} MEDIASUBTYPE_WMVA, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject {3F40F4F0-5622-4FF8-B6D8-A17A584BEE5E}, Microsoft H264 Video Decoder MFT, CLSID_CMSH264DecoderMFT MEDIASUBTYPE_mpg4, Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject MEDIASUBTYPE_MPG4, Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject MFVideoFormat_H264, Microsoft H264 Video Decoder MFT, CLSID_CMSH264DecoderMFT MFVideoFormat_WMV3, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject {33363248-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT MEDIASUBTYPE_mp43, Mpeg43 Decoder MFT, CLSID_CMpeg43DecMediaObject MFVideoFormat_MP43, Mpeg43 Decoder MFT, CLSID_CMpeg43DecMediaObject MEDIASUBTYPE_m4s2, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT MFVideoFormat_WMV2, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject MFVideoFormat_MSS2, WMV Screen decoder MFT, CLSID_CMSSCDecMediaObject MFVideoFormat_M4S2, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT MEDIASUBTYPE_WVP2, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject MEDIASUBTYPE_mp42, Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject MEDIASUBTYPE_MP42, Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject MFVideoFormat_WMV1, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject MFVideoFormat_MSS1, WMV Screen decoder MFT, CLSID_CMSSCDecMediaObject MFVideoFormat_MPG1, Microsoft MPEG Video Decoder MFT, {2D709E52-123F-49B5-9CBC-9AF5CDE28FB9} MFVideoFormat_WVC1, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject MFVideoFormat_DVC, DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432} {0000F1AC-0000-0010-8000-00AA00389B71}, Microsoft FLAC Audio Decoder MFT, {6B0B3E6B-A2C5-4514-8055-AFE8A95242D9} {00007361-0000-0010-8000-00AA00389B71}, MS AMRNB Decoder MFT, {265011AE-5481-4F77-A295-ABB6FFE8D63E} {00002000-0000-0010-8000-00AA00389B71}, Microsoft Dolby Digital Plus Decoder MFT, {177C0AFE-900B-48D4-9E4C-57ADD250B3D4} MFAudioFormat_AAC, Microsoft AAC Audio Decoder MFT, CLSID_CMSAACDecMFT MFAudioFormat_WMAudio_Lossless, WMAudio Decoder MFT, CLSID_CWMADecMediaObject MFAudioFormat_WMAudioV9, WMAudio Decoder MFT, CLSID_CWMADecMediaObject MFAudioFormat_WMAudioV8, WMAudio Decoder MFT, CLSID_CWMADecMediaObject MEDIASUBTYPE_MSAUDIO1, WMAudio Decoder MFT, CLSID_CWMADecMediaObject MEDIASUBTYPE_RAW_AAC1, Microsoft AAC Audio Decoder MFT, CLSID_CMSAACDecMFT MFAudioFormat_MP3, MP3 Decoder MFT, CLSID_CMP3DecMediaObject MFAudioFormat_MPEG, Microsoft MPEG Audio Decoder MFT, {70707B39-B2CA-4015-ABEA-F8447D22D88B} {00000031-0000-0010-8000-00AA00389B71}, GSM ACM Wrapper MFT, {4A76B469-7B66-4DD4-BA2D-DDF244C766DC} {00000011-0000-0010-8000-00AA00389B71}, IMA ADPCM ACM Wrapper MFT, {A16E1BFF-A80D-48AD-AECD-A35C005685FE} WMMEDIASUBTYPE_WMSP2, WMSpeech Decoder DMO, CLSID_CWMSPDecMediaObject MFAudioFormat_MSP1, WMSpeech Decoder DMO, CLSID_CWMSPDecMediaObject KSDATAFORMAT_SUBTYPE_MULAW, G711 Wrapper MFT, {92B66080-5E2D-449E-90C4-C41F268E5514} {00000006-0000-0010-8000-00AA00389B71}, A-law Wrapper MFT, {36CB6E0C-78C1-42B2-9943-846262F31786} KSDATAFORMAT_SUBTYPE_ADPCM, ADPCM ACM Wrapper MFT, {CA34FE0A-5722-43AD-AF23-05F7650257DD} ------------------------------------- Disabled Media Foundation Transforms ------------------------------------- [HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\Transforms\DoNotUse] <transform CLSID> ------------------------ Disabled Media Sources ------------------------ [HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\MediaSources\DoNotUse] <media source CLSID> --------------- EVR Power Information --------------- Current Setting: {5C67A112-A4C9-483F-B4A7-1D473BECAFDC} (Quality) Quality Flags: 2576 Enabled: Force throttling Allow half deinterlace Allow scaling Decode Power Usage: 100 Balanced Flags: 1424 Enabled: Force throttling Allow batching Force half deinterlace Force scaling Decode Power Usage: 50 PowerFlags: 1424 Enabled: Force throttling Allow batching Force half deinterlace Force scaling Decode Power Usage: 0
Topic Options
