I was referred here by: https://communities.intel.com/message/521599#521599
Summary:
Fatal inside GPU driver on buffer swap. (apparently)
Vanilla Qt v5.10.0 / QtQuick 2.10 empty project cannot start using MSVC17 / OpenGL
i5-6400 / HD Graphics 530
Windows 10 64-bit Pro : build: 15063.786
DXDiag already lists that version as installed:
There is a video attached to the previous thread of this happening.
https://communities.intel.com/servlet/JiveServlet/download/521376-179987/bandicam%202018-01-23%2011-...
and backtrace
https://communities.intel.com/servlet/JiveServlet/download/521376-179986/Intel_VS2017_OpenGL_Backtra...
Is it happening with the latest driver release?
If so then I need the following template filled out so an issue con be properly reported:
System Setup Information:
System Used: (Manufacturer/Model)
CPU SKU: (i3, i5, Pentium, Celeron, etc.)
GPU SKU: (HD4400, HD5100, etc.)
Processor Line: (Y-Series, U-Series, etc.)
System BIOS Version:
CMOS settings:
Graphics Driver Version:
GOP/VBIOS Version:
Operating System:
OS Version:
API:
Occurs on non-Intel GPUs?:
Steps to Reproduce:
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
Expected Results:
Actual Results:
Additional Information:
Just to add my voice. I too am suffering from this bug on my Intel UHD 530 and again with Qt 5.10.1 + QML. Much like the original reporter the program does not crash if I disable the use of the Intel OpenGL driver and use ANGLE rendering.
From the error it looks like the RegisterProcTableCallback function is being passed a size of 0x1f, but it has either been misaligned or called using the wrong call protocol or the size is being cast to a great size that the call prototype defines such that unrelated memory is being used as part of the size. It looks like the size is being passed as a 16bit value, but used as a 32bit value.
It crashes with this report:
HEAP[myProgram.exe]:
Invalid allocation size - f (exceeded 7ffffffdefff)
Exception at 0x7ffadd92a388, code: 0xe06d7363: C++ exception, flags=0x1 (execution cannot be continued) (first chance) in ig9icd64!RegisterProcTableCallback
My system information from your graphics tool is (RAW EDID's removed (paranoia)):
Intel(R) HD Graphics 530
Report Date: Friday, July 27, 2018
Report Time [hh:mm:ss]: 11:53:53 AM
Driver Version: 23.20.16.4973
Operating System: Windows* 10 Pro (10.0.17134)
Physical Memory: 8079 MB
Vendor ID: 8086
Device ID: 1912
Device Revision: 06
Graphics Output Protocol (GOP) Version: 9.0.1037
Current Resolution: 1920 x 1200
Processor: Intel(R) Core(TM) i7-6700 CPU @ 3.40GHz
Processor Speed: 3408 MHz
Processor Graphics in Use: Intel(R) HD Graphics 530
Shader Version: 5.1
OpenGL* Version: 4.5
OpenCL* Version: 2.1
Vulkan* Version: 1.0.66
* Microsoft DirectX* *
Runtime Version: 12.0
Hardware-Supported Version: 12.0
* Devices connected to the Graphics Accelerator *
Active Displays: 2
* Digital Television *
Display Type: Digital
Serial Number: 7NGPY3471DJU
DDC2 Protocol: Supported
Gamma: 2.2
Connector Type: HDMI
Device Type: Digital Television
Maximum Image Size
Horizontal Size: 18.9 inches
Vertical Size: 10.63 inches
Supported Modes
640 x 480 (60p Hz)
640 x 480 (75p Hz)
720 x 400 (70p Hz)
720 x 480 (60i Hz)
720 x 480 (60p Hz)
720 x 576 (50i Hz)
720 x 576 (50p Hz)
800 x 600 (60p Hz)
800 x 600 (75p Hz)
1024 x 768 (60p Hz)
1024 x 768 (75p Hz)
1152 x 864 (75p Hz)
1280 x 720 (60p Hz)
1280 x 720 (50p Hz)
1280 x 1024 (75p Hz)
1280 x 1024 (60p Hz)
1920 x 1080 (60p Hz)
1920 x 1080 (50i Hz)
1920 x 1080 (50p Hz)
1920 x 1080 (60i Hz)
Power Management Support
Standby Mode: Supported
Suspend Mode: Supported
Active Off Mode: Supported
* Digital Display *
Serial Number: 0FFXD49O129S
Gamma: 2.2
Connector Type: DisplayPort
Device Type: Digital Display
Maximum Image Size
Horizontal Size: 20.47 inches
Vertical Size: 12.6 inches
Supported Modes
640 x 480 (60p Hz)
720 x 400 (70p Hz)
800 x 600 (60p Hz)
1024 x 768 (60p Hz)
1280 x 960 (60p Hz)
1600 x 1200 (60p Hz)
1680 x 1050 (60p Hz)
1920 x 1200 (60p Hz)
* Other names and brands are the property of their respective owners.
For more complete information about compiler optimizations, see our Optimization Notice.
