Community
cancel
Showing results for
Search instead for
Did you mean:
[Vulkan][Linux][Mesa] VK_ERROR_INCOMPATIBLE_DIRVER
Hello guys,
I'm on Gentoo/Linux and tried to run vulkaninfo, but :
VULKAN INFO
Vulkan API Version: 1.0.30
INFO: [loader] Code 0 : Found manifest file /home/celes/.vulkan/Vulkan-LoaderAndValidationLayers/dbuild/layers/VkLayer_threading.json, version "1.0.0"
INFO: [loader] Code 0 : Found manifest file /home/celes/.vulkan/Vulkan-LoaderAndValidationLayers/dbuild/layers/VkLayer_parameter_validation.json, version "1.0.0"
INFO: [loader] Code 0 : Found manifest file /home/celes/.vulkan/Vulkan-LoaderAndValidationLayers/dbuild/layers/VkLayer_swapchain.json, version "1.0.0"
INFO: [loader] Code 0 : Found manifest file /home/celes/.vulkan/Vulkan-LoaderAndValidationLayers/dbuild/layers/VkLayer_object_tracker.json, version "1.0.0"
INFO: [loader] Code 0 : Found manifest file /home/celes/.vulkan/Vulkan-LoaderAndValidationLayers/dbuild/layers/VkLayer_unique_objects.json, version "1.0.0"
INFO: [loader] Code 0 : Found manifest file /home/celes/.vulkan/Vulkan-LoaderAndValidationLayers/dbuild/layers/VkLayer_core_validation.json, version "1.0.0"
INFO: [loader] Code 0 : Found manifest file /home/celes/.vulkan/Vulkan-LoaderAndValidationLayers/dbuild/layers/VkLayer_image.json, version "1.0.0"
Cannot create Vulkan instance.
/home/celes/.vulkan/Vulkan-LoaderAndValidationLayers/demos/vulkaninfo.c:680: failed with VK_ERROR_INCOMPATIBLE_DRIVER
So I have mesa 12.0.1 and dri3 and my graphic card:
00:02.0 VGA compatible controller: Intel Corporation Sky Lake Integrated Graphics (rev 06) (prog-if 00 [VGA controller])
	Subsystem: Micro-Star International Co., Ltd. [MSI] Sky Lake Integrated Graphics
	Flags: bus master, fast devsel, latency 0, IRQ 121
	Memory at dd000000 (64-bit, non-prefetchable) [size=16M]
	Memory at b0000000 (64-bit, prefetchable) [size=256M]
	I/O ports at f000 [size=64]
	Expansion ROM at <unassigned> [disabled]
	Capabilities: [40] Vendor Specific Information: Len=0c <?>
	Capabilities: [70] Express Root Complex Integrated Endpoint, MSI 00
	Capabilities: [ac] MSI: Enable+ Count=1/1 Maskable- 64bit-
	Capabilities: [d0] Power Management version 2
	Capabilities: [100] Process Address Space ID (PASID)
	Capabilities: [200] Address Translation Service (ATS)
	Capabilities: [300] Page Request Interface (PRI)
	Kernel driver in use: i915
Maybe I need to do something to force kernel driver i965?
Have a great day :)
New Contributor III
Seems like you just need to remove the xserver-xorg-video-intel driver to force DRI3 (and thus enable Vulkan)
Thanks for your help, but it's not working.
I think dri3 is okay :
[    88.548] (II) intel(0): Using Kernel Mode Setting driver: i915, version 1.6.0 20151010
[    88.548] (WW) Falling back to old probe method for modesetting
[    88.548] (--) intel(0): gen9 engineering sample
[    88.548] (--) intel(0): CPU: x86-64, sse2, sse3, ssse3, sse4.1, sse4.2, avx, avx2; using a maximum of 4 threads
[    88.548] (II) intel(0): Creating default Display subsection in Screen section
	"Default Screen Section" for depth/fbbpp 24/32
[    88.548] (==) intel(0): Depth 24, (--) framebuffer bpp 32
[    88.548] (==) intel(0): RGB weight 888
[    88.548] (==) intel(0): Default visual is TrueColor
[    88.549] (II) intel(0): Output HDMI1 has no monitor section
[    88.549] (II) intel(0): Enabled output HDMI1
[    88.549] (II) intel(0): Output HDMI2 has no monitor section
[    88.549] (II) intel(0): Enabled output HDMI2
[    88.549] (--) intel(0): Using a maximum size of 256x256 for hardware cursors
[    88.549] (II) intel(0): Output VIRTUAL1 has no monitor section
[    88.549] (II) intel(0): Enabled output VIRTUAL1
[    88.549] (--) intel(0): Output HDMI2 using initial mode 1920x1080 on pipe 0
[    88.549] (==) intel(0): TearFree disabled
[    88.549] (==) intel(0): DPI set to (96, 96)
[    88.549] (II) Loading sub module "dri3"
[    88.549] (II) LoadModule: "dri3"
[    88.549] (II) Module "dri3" already built-in
[    88.549] (II) Loading sub module "dri2"
[    88.549] (II) LoadModule: "dri2"
[    88.549] (II) Module "dri2" already built-in
[    88.549] (II) Loading sub module "present"
[    88.549] (II) LoadModule: "present"
[    88.549] (II) Module "present" already built-in
[    88.549] (II) UnloadModule: "modesetting"
[    88.549] (II) Unloading modesetting
[    88.549] (==) Depth 24 pixmap format is 32 bpp
[    88.549] (II) intel(0): SNA initialized with Skylake (gen9) backend
[    88.549] (==) intel(0): Backing store enabled
[    88.549] (==) intel(0): Silken mouse enabled
[    88.549] (II) intel(0): HW Cursor enabled
[    88.549] (II) intel(0): RandR 1.2 enabled, ignore the following RandR disabled message.
[    88.549] (==) intel(0): DPMS enabled
[    88.549] (==) intel(0): Display hotplug detection enabled
[    88.549] (II) intel(0): [DRI2] Setup complete
[    88.549] (II) intel(0): [DRI2]   DRI driver: i965
[    88.549] (II) intel(0): [DRI2]   VDPAU driver: va_gl
[    88.549] (II) intel(0): direct rendering: DRI2 DRI3 enabled
[    88.549] (II) intel(0): hardware support for Present enabled
I hope I won't have to switch on window to work on Vulkan...
Anyway thanks
Hi Mathieu,
Unfortunately I can't help with Linux driver questions/issues, it is not a specialty. There are some places you can go for help though.
For questions and issues with the Mesa driver, your best options are:
For LVDS issues, your best option is to contact one of Intel's kernel graphics developers. You can find them on IRC atirc://irc.freenode.net/#intel-gfx and on the mailing list  http://lists.freedesktop.org/mailman/listinfo/intel-gfx
-Michael
