Developing Games on Intel Graphics
If you are gaming on graphics integrated in your Intel Processor, this is the place for you! Find answers to your questions or post your issues with PC games
3D engine
Anonymous
Not applicable
Hello there,
ok, here we go, I have a dream, make a 3D engine 100% assembler intel only with CPU, I use rotation matrix only for now.
it works of course, but it's slow when I put a lot of pixels.
Recently I decided to include voxels in my engine, and it's slow when I put> = 8000 voxels (20 * 20 * 20 cube) and when I saw that nvidia display 32M voxels (fire) I wonder how they can do it !
And I have a little idea of  the reason: MMU, paging, segmentation. memory.
Am I right?
Another question, is the FPU is the slowest to compute floating point  than SSE or depending of data manipulate ?
PS: I work without OS like Windows or Linux, I run on my own kernel + bootloader in assembly too with NASM.
Sorry if i don't wirte a good english, i'm french and use google translate ^-^
Bradley_W_Intel
You clearly are using the processor in a very advanced way. I will do my best to answer your questions:
1) Why is your voxel engine not able to efficiently render as many voxels as you'd like? Voxel engines need to maximize their use of parallelism (both threading and SIMD) and also to store the data efficiently in an octree or some other structure that can handle sparse data. If you are doing all these things and still not getting the performance you expect, it's an optimization problem. Some Intel tools like VTune Performance Analyzer are excellent for performance analysis.
2) Is single data floating point math faster than SIMD (if I understood you)? Typically SIMD will be faster than single data instructions if your data is laid out in a way that supports the SIMD calls. In all cases, the only way for you to know for certain which way is faster is to test it.
3) How can you select between discrete and processor graphics? DirectX has methods of enumerating adapters. In such a case, the processor graphics is listed separately from the discrete graphics. If you are choosing your adapter based on the amount of available memory, you may be favoring the processor graphics when you didn't intend to. Intel has sample code that shows how to properly detect adapters in DirectX at https://software.intel.com/en-us/vcsource/samples/gpu-detect. The process for OpenGL is not well documented.
4) Can I use one processor to control execution of a second processor? Probably not. The details on Intel processors are covered at http://www.intel.com/content/www/us/en/processors/architectures-software-developer-manuals.html. It's possible, though unlikely, that you'll be able to find something in there that can help you.
Bernard
Valued Contributor I
>>>I have transfer this code in my project (SDL asm), but my fps fall down, 20 less, relative of fsincos, is it normal ?>>>
Can you test speed of execution of your code with the call to  __libm_sse2_sincos function?
Usually libm_sse2_sincos should be faster than x87 fsincos.
Bernard
>>>I saw in optimization reference manual, fsincos have 119 latency, and latency's instruction of SIMD are around 5-6.
Latency is like clock cycle ?>>>
I have that raw speed(without call and ret overhead)  of libm_sse2_sincos could be less than x87 fsincos. Crude estimation of  libm_sse2_sincos execution speed could be simple as calculation and summation  of the all machine code instructions. Pay attention that some of the instruction can be executed in paralel or out-of-order.
Latency is the time in CPU cycles needed to proces (retire) machine code instruction. For example latency of x87 fsincos is 112 CPU cycles that's mean that 112 cycles are needed to execute that instruction. At the hardware level fsincos is broken down into various  micro-ops which are scheduled to run on FP adder and mul units and accumulate the results into floating point physical registers. Horner Scheme is probably used for the result convergence.
Bernard
Today I will upload my own implementation of trigo instructions.
Bernard
Pseudocode:
for(unsigned int i = 0; i < Len; i +=8 )
       prefetch(array1+x) // prefetch distance x should be calculated by trial and error
        array1 // do some operation
        array2 // do some operation
        array3 // do some operation
        array4 // do some operation
        array5 // do some operation
          prefetch(array2+x) // // prefetch distance x should be calculated by trial and error
        array1[i+1] // do some operation
        array2[i+1] // do some operation on array
        array3[i+1] // do some operation on  array
       array4[i+1] // do some operation on array
       array5[i+1] // do some operation on array
        ............................... code continues
      array1[i+7] // do some operation on array
      array2[i+7] // do some operation on array
      array3[i+7] //  do some operation on array
      array4[i+7] // do some operation on  array
      array5[i+7] // do some operation on array
Bernard
Post #130 is related to post #126.
In post #130 as you can see 8x  unrolling is loading in each array 64-byte stride which can fit L1D cache line.
Anonymous
Not applicable
For difference of speed between fsincos and call      __libm_sse2_sincos, here's the code test:
the generate code made by cos ans sin block, generate 3 * call      __libm_sse2_sincos, that's why i put only 3 * fsincos.
I have try to calling __libm_sse2_sincos through asm inline, but he didn't find this function, and made error at compilation :/
float			rotation_object[4] = { 0 };     // 0: x , 1: y , 2: z
void        put_pixel(float *coord, int color, float* a)
	int		offset_pixel;
	int		a_time_sincosps, b_time_sincosps;
	int		a_time_fsincos, b_time_fsincos;
	unsigned int	loop_test;
	int		temp;
	__asm	rdtsc
	__asm	mov		[a_time_sincosps], eax
			trigo.cos[_x] = cos(DEG2RAD(rotation_object[_x]));
			trigo.cos[_y] = cos(DEG2RAD(rotation_object[_y]));
			trigo.cos[_z] = cos(DEG2RAD(rotation_object[_z]));
			trigo.sin[_x] = sin(DEG2RAD(rotation_object[_x]));
			trigo.sin[_y] = sin(DEG2RAD(rotation_object[_y]));
			trigo.sin[_z] = sin(DEG2RAD(rotation_object[_z]));
	__asm	rdtsc
	__asm	mov		[b_time_sincosps], eax
	printf("time_sincosps = %i\n", b_time_sincosps - a_time_sincosps);
	__asm	rdtsc
	__asm	mov		[a_time_fsincos], eax
			__asm		vxorpd    xmm1, xmm1, xmm1
			__asm		vcvtss2sd xmm1, xmm1, [temp]
			__asm		vmovsd    xmm15, [temp]
			__asm		vmulsd    xmm0, xmm15, xmm1
			__asm		vzeroupper
		__asm		fsincos
			__asm		vxorpd    xmm2, xmm2, xmm2
			__asm		vmovapd   xmm14, xmm0
			__asm		vcvtss2sd xmm2, xmm2, [temp]
			__asm		vcvtsd2ss xmm1, xmm1, xmm1
			__asm		vmulsd    xmm0, xmm15, xmm2
			__asm		vmovss[temp], xmm1
		__asm		fsincos
			__asm		vmovapd   xmm13, xmm0
			__asm		vmovss    [temp], xmm1
		__asm		fsincos
		__asm		vcvtsd2ss xmm14, xmm14, xmm14
		__asm		vcvtsd2ss xmm13, xmm13, xmm13
		__asm		vcvtsd2ss xmm0, xmm0, xmm0
		__asm		vmovss    [temp], xmm14
		__asm		vmovss    [temp], xmm13
		__asm		vmovss    [temp], xmm0
	__asm	rdtsc
	__asm	mov		[b_time_fsincos], eax
	printf("time_fsincos = %i", b_time_fsincos - a_time_fsincos);
	while (1);
I have add store anc convert function because it's the code made by trigo.cos[_x] = ... and other stores.
can't do only cos(DEG2RAD(rotation_object[_x])); because he remove call      __libm_sse2_sincos.
And here the result:
time_sincosps = 19839
time_fsincos = 1981
And, is it possible to modify the processus of compilation by rewrite asm file ? it will be wonderfull if it's possible, i will be able to (correct) the code or rewrite it like i think.
Finnaly is it to possible to personalize the asm code make by icl ? ex:
Keep the display of number, like hexadecimal, and write it with 0x instead H at the end of number:
return 0xdeadbeef --> (origin) mov    eax, -559038737 --> (wish) mov    eax, 0xdeadbeef  ^^
Anonymous
Not applicable
I will try instrinsics function through this wonderfull web page: https://software.intel.com/sites/landingpage/IntrinsicsGuide/
Anonymous
Not applicable
It's too complex to work with intrinsic function, load, set, only cause he don't allowed casting float [4] to __m128 :/
"error : argument of type "float" is incompatible with parameter of type "__m128"
"error : a value of type "__m128" cannot be assigned to an entity of type "float""
"error : cast to type "__m128" is not allowed"
It's strange that the compiler don't authorized this, one more forbidding add in the way programming's black list of high level compiler :/
Bernard
Do not cast __m128 to float array because __m128 is a struct of unions. You can simply initialize __m128 member fields , but this is not recommended or you can cast float pointer to  __m128 type pointer.
float vertex[4] = {0.f,0.f,0.f,0.f};
__m128 *ptr_m128 = (__m128 *)vertex;
http://stackoverflow.com/questions/11759791/is-it-possible-to-cast-floats-directly-to-m128-if-they-are-16-byte-alligned
http://stackoverflow.com/questions/5118158/using-sse-to-speed-up-computation-store-load-and-alignment?rq=1
Anonymous
Not applicable
Ok, but like i do most store and load, it will be a little complexe, and i don't think it will be optimize if i do with that:
	static float	_xmm0[4], _xmm1[4], _xmm2[4], _xmm3[4], _xmm4[4], _xmm7[4];
	trigo.coord = coord;
	trigo._xmm0[0] = sin(DEG2RAD(rotation_object[_x]));
	trigo._xmm0[1] = cos(DEG2RAD(rotation_object[_x]));
	trigo._xmm0[2] = cos(DEG2RAD(rotation_object[_x]));
	trigo._xmm0[3] = sin(DEG2RAD(rotation_object[_x]));
	trigo._xmm0[4] = 1;
	trigo._xmm0[5] = sin(DEG2RAD(rotation_object[_x]));
	trigo._xmm1[0] = sin(DEG2RAD(rotation_object[_z]));
	trigo._xmm1[1] = cos(DEG2RAD(rotation_object[_z]));
	trigo._xmm1[2] = cos(DEG2RAD(rotation_object[_z]));
	trigo._xmm1[3] = sin(DEG2RAD(rotation_object[_z]));
	trigo._xmm1[4] = 1;
	trigo._xmm1[5] = sin(DEG2RAD(rotation_object[_z]));
	trigo._xmm2[0] = sin(DEG2RAD(rotation_object[_y]));
	trigo._xmm2[1] = cos(DEG2RAD(rotation_object[_y]));
	trigo._xmm2[2] = cos(DEG2RAD(rotation_object[_y]));
	trigo._xmm2[3] = sin(DEG2RAD(rotation_object[_y]));
	trigo._xmm2[4] = 1;
	trigo._xmm2[5] = sin(DEG2RAD(rotation_object[_y]));
		// yaw
	//Yaw:; y
		// On applique la rotation au point | [esi + 0] = x
		// | [esi + 4] = y
		// | [esi + 8] = z
		// On calcule x = x.cos(phi_y) * cos(phi_z) - y.cos(phi_y) * sin(phi_z) - z.sin(phi_y)
		// On calcule  A = x.cos(phi_y), B = y.cos(phi_y) et C = z.sin(phi_y)
			*_xmm0 = _mm_mul_ps(trigo._xmm2[1], trigo.coord);
		// On calcule D = A * cos(phi_z), E = B * sin(phi_z) et C = C * 1
			* _xmm0 = _mm_mul_ps(*_xmm0, trigo._xmm1[2]);
		// On calcule F = D - E, C = C - 0
			*_xmm0 = _mm_hsub_ps(*_xmm0, *_xmm0);
		// On calcule xmm0 = F - C
		// On save la new coordonée
			trigo.end_coord[_x] = *_xmm0;
		// / yaw
		// pitch
	//Pitch:; x
		  // | [esi + 4] = y
		  // | [esi + 8] = z
		  // On calcule y = x.(cos(phi_x) * sin(phi_z) - sin(phi_x) * cos(phi_z) * sin(phi_y)) +
		  //				 y.(sin(phi_x) * sin(phi_z) * sin(phi_y) + cos(phi_x) * cos(phi_z)) -
		  //				 z.(sin(phi_x) * cos(phi_y))
		// On calcule A = cos(phi_x) * sin(phi_z), B = sin(phi_x) * cos(phi_z), E = cos(phi_x) * cos(phi_z) et F = sin(phi_x) * sin(phi_z)
		//movddup		xmm0, [_xmm0 + 8]
			_xmm0[2] = trigo._xmm0[2];
			_xmm0[3] = trigo._xmm0[2];
		//movddup		xmm7, [_xmm2 + 12]
			*_xmm0 = _mm_mul_ps(*_xmm0, trigo._xmm1);
		// on sauve xmm0 dans xmm7 pour le copier dans xmm0 de Roll car l'equation de y ressemblent a l'equation de z mis a part que la valeur sin(phi_y) est
		// multiplié par d'autres equations
		// On calcule C' = A' * sin(phi_y) et G' = E' * sin(phi_y)
		// movddup		xmm2, [_xmm2 + 16]
			_xmm7[2] = trigo._xmm2[3];
			_xmm7[3] = trigo._xmm2[3];
			*_xmm7 = _mm_mul_ps(*_xmm7, *_xmm0);
		// On calcule C = B * sin(phi_y) et G = F * sin(phi_y)
		// movhlps		xmm1, xmm0
			_xmm2[2] = trigo._xmm2[4];
			_xmm2[3] = trigo._xmm2[4];
			*_xmm0 = _mm_mul_ps(*_xmm0, *_xmm2);
		// Copie le contenu du haut(64..127) d'un paquet de valeurs réel de simple précision (4*32 bits) dans sa partie basse (0..31).
		// En somme on separe les deux partie x et y : xmm0 = A) cos(phi_x) * sin(phi_z)								xmm0 = cos(phi_x) * sin(phi_z)
		//											 			C) sin(phi_x) * cos(phi_z) * sin(phi_y) = > sin(phi_x) * sin(phi_y) * cos(phi_z)
		//														E) cos(phi_x) * cos(phi_z)								xmm1 = cos(phi_x) * cos(phi_z)
		//														G) sin(phi_x) * sin(phi_z) * sin(phi_y)							sin(phi_x) * sin(phi_y) * sin(phi_z)
			_xmm1[1] = _xmm0[3];
			_xmm1[0] = _xmm0[2];
		// On calcule D = A - C
		// On calcule H = E + G
			*_xmm1 = _mm_hadd_ps(_xmm1, _xmm1);
		// On calcule sin(phi_x) * cos(phi_y) et cos(phi_x) * cos(phi_y)
		// On calcule I.roll = cos(phi_x) * cos(phi_y) et I.Pitch = sin(phi_x) * cos(phi_y)
		// movlps		xmm3, [_xmm0 + 8]
			_xmm3[1] = trigo._xmm0[5];
			_xmm3[0] = trigo._xmm0[4];
		// movlps		xmm2, [_xmm2 + 4]
			_xmm2[1] = trigo._xmm2[2];
			_xmm2[0] = trigo._xmm2[1];
			*_xmm2 = _mm_mul_ps(*_xmm2, *_xmm3);
		// movshdup 	xmm3, xmm2
			_xmm3[0] = _xmm2[1];
			_xmm3[1] = _xmm2[1];
			_xmm3[2] = _xmm2[3];
			_xmm3[3] = _xmm2[3];
		// On calcule x.D + y.H - z.I
		// On calcule J = x.D, K = y.H et L = z.I
		// movsldup		xmm4, xmm1	; y.H
			_xmm4[0] = _xmm1[0];
			_xmm4[1] = _xmm1[0];
			_xmm4[2] = _xmm1[2];
			_xmm4[3] = _xmm1[2];
		// movss		xmm4, xmm0	; x.D
			_xmm4[0] = _xmm0[0];
		// movlhps		xmm4, xmm3; z.I.Pitch
			_xmm4[2] = _xmm3[0];
			_xmm4[3] = _xmm3[1];
			*_xmm4 = _mm_mul_ps(*_xmm4, trigo.coord);
		// On calcule M = J + K
			_xmm4 = _mm_hadd_ps(*_xmm4, *_xmm4)
		// On calcule N = M - L
			_xmm4 = _mm_hsub_ps(*_xmm4, *_xmm4)
			trigo.end_coord[_y] = *_xmm4;
		// / pitch
		// roll
	//Roll:; z
		// | [esi + 4] = y
		// | [esi + 8] = z
		// On calcule z' = x.(cos(phi_x) * cos(phi_z) * sin(phi_y) + sin(phi_x) * sin(phi_z)) +
		//				  y.(sin(phi_x) * cos(phi_z) - cos(phi_x) * sin(phi_z) * sin(phi_y)) +
		//				  z.(cos(phi_x) * cos(phi_y))
			// En somme on separe les deux partie x et y : xmm7 = C') cos(phi_x) * sin(phi_z) * sin(phi_y)				xmm7 =	C') cos(phi_x) * sin(phi_z) * sin(phi_y))
			//											 			B') sin(phi_x) * cos(phi_z)						 =>				B') sin(phi_x) * cos(phi_z)
			//														G') cos(phi_x) * cos(phi_z) * sin(phi_y)				xmm1 =	G') cos(phi_x) * cos(phi_z) * sin(phi_y)
			//														F') sin(phi_x) * sin(phi_z)										F') sin(phi_x) * sin(phi_z)
		// movhlps		xmm1, xmm7
			_xmm1[0] = _xmm7[2];
			_xmm1[1] = _xmm7[3];
		// On calcule D' = -B' + C'
			or	xmm7[0], 0x80000000;
			*_xmm7 = _mm_hadd_ps(_xmm7, _xmm7);
		// On calcule H' = G' + F'
		// On calcule x.D' + y.H' + z.I'
		// On calcule J = x.D', K = y.H' et L = z.I'
		// movsldup		xmm4, xmm7	; y.D'
			_xmm4[0] = _xmm7[0];
			_xmm4[1] = _xmm7[0];
			_xmm4[2] = _xmm7[2];
			_xmm4[3] = _xmm7[2];
		// movss		xmm4, xmm1	; x.H'
		// movlhps 	xmm4, xmm2	; z.I'
			_xmm4[2] = _xmm2[0];
			_xmm4[3] = _xmm2[1];
		// On calcule M' = J' + K'
		// On calcule N' = M' + L'
			trigo.end_coord[_z] = *_xmm4;
		// / roll
Bernard
	int		offset_pixel;
	int		temp;
	__asm	rdtsc
	__asm	rdtsc
	__asm	rdtsc
			__asm		vzeroupper
		__asm		fsincos
		__asm		fsincos
		__asm		fsincos
	__asm	rdtsc
	while (1);
time_fsincos = 1981
The piece of code which  calls library cos and sin function is expected to run slower than code which is using CPU built-in x87 fsincos machine code instruction. I would try to run both of pieces of code inside the double loop and calculate the average of the runs. When using rdtsc you must serialize the execution inside the CPU because of the  nature of out-of-order processing there is a possibility that part of the code will be scheduled to run before the execution of rdtsc instruction.
Bernard
>>>Finnaly is it to possible to personalize the asm code make by icl ? ex:>>>
If I understood your question correctly you can load compiled exe file into IDA Pro disassembler and perform any assembly code changes after that you can recompile the code. I am not sure if this will work correctly.
Bernard
	trigo._xmm0[4] = 1;
	trigo._xmm1[4] = 1;
	trigo._xmm2[4] = 1;
		// yaw
	//Yaw:; y
		// | [esi + 4] = y
		// | [esi + 8] = z
		// / yaw
		// pitch
	//Pitch:; x
		  // | [esi + 4] = y
		  // | [esi + 8] = z
		// / pitch
		// roll
	//Roll:; z
		// | [esi + 4] = y
		// | [esi + 8] = z
		// / roll
trigo._xmm0[] array member should have size divisable by 4 in order to be loaded into xmm register. I do not think if it is a good way to use compiler intrinsic  *_xmm0 = _mm_mul_ps(trigo._xmm2[1], trigo.coord);
Anonymous
Not applicable
trigo._xmm0 have 6 float member
       ._xmm1
       ._xmm2
So i will not read out of array, i have control of those array, don't worry. If of course icl will not fragment array's member.
Anonymous
Not applicable
It will be difficult with IDA :/
Anonymous
Not applicable
For test difference speed, i can't test fsincos through asminline, cause, like i wrote, only one asm in line fall down my fps of -170  (now) fps :D
The only way to see the truth is contact intel engineer :/
Bernard
>>>So i will not read out of array, i have control of those array, don't worry. If of course icl will not fragment array's member.>>>
ICL will not fragment array data type it is by design of the compiler to allocate contigous chunk of memory for the array.
Bernard
>>>It will be difficult with IDA :/>>>
Yes I know that, but for simple code patching it can be used.
Bernard
>>>For test difference speed, i can't test fsincos through asminline, cause, like i wrote, only one asm in line fall down my fps of -170  (now) fps :D>>>
Does it mean that fsincos caused 170 fps drop?
Anonymous
Not applicable
No of course, i mean if i put only one mov, it fall down:
Ex:
              __asm      mov       eax, 0xdeadbeef
Two reason for this behaviour, one is icl don't like asm inline, second i don't know how to configure compiler's option correctly .
Anonymous
Not applicable
Intel need really must learn, in this world there isn't only hacker, but developers who want programming without obstacle.
I talk about new technologie of protections program and data: Intel SGX && intel MPX. I'm scared about futur, who we'll don't allow programming without enter through a lot of protocol, like 10_000 ^^
And of course the most powerfull technologie "anti-hack", pagination :D (hate this one particularly)
Do you know how to access to first pixel of thé screen, easier way like vesa. I would like to continue my project of 3D engine without OS in IA-32e mode. i don't know why VBE core is discontinue :/
I have learn we're king of the world if we can access to pixel of screen and second parameter is how many time need to access to them.
Do intel show calendar of new Extensions ISA ? i tried to search it
