Developing Games on Intel Graphics
If you are gaming on graphics integrated in your Intel Processor, this is the place for you! Find answers to your questions or post your issues with PC games
548 Discussions
Problem with intel gs45 hdmi-hdmi connection
tascon85
Hi everybody, my first time posting. Let's go with problem, i hope somebody can help me with it. I recently bought an LCD full hd tv/monitor it is the Asus 24t1e. That lcd panel supports 1920x1080p@60Hz as native resolution. I want it to use with my Acer aspire 3810T netbook to work more comfortable when i'm at home and to play some hd movies.
The pc has an intel gs45 integrated chipset with hdmi output, cpu intel core 2solo su3500 (1.4GHz). Well my problem comes when i connect the hdmi output from the intel chipset to one of the hdmi inputs in the asus lcd panel. First overscan appears. Easy to fix that with intel graphics control panel.
But then the image is poor, text is blurry and doesnt look well. Quality is worst than when it's connected by vga output. I try everything to fix this issue but nothing works. I try to edit the edid but doesn't work. Try to use intel tv wizard, but it only allows me choose 480p60, 720p60 and 1080i60 modes but not 1080p60.
I try to create a custom resolution using powerstrip but again doesn't work. I email intel support but they say that i try to install latest drivers from acer or buy a better hdmi wire. I do both but still having the problem. Sorry about my english, im from Spain.
Some edid info if helps:
Monitor
Model name............... ASUS 24T1E
Manufacturer............. Asus
Plug and Play ID......... ACI24F4
Serial number............ 98LVQS001722
Manufacture date......... 2009, ISO week 32
EDID revision............ 1.3
Input signal type........ Digital
Color bit depth.......... Undefined
Display type............. RGB color
Screen size.............. 520 x 290 mm (23,4 in)
Power management......... Standby, Suspend, Active off/sleep
Extension blocs.......... 1 (CEA-EXT)
DDC/CI................... Supported
MCCS revison............. 2.0
Display technology....... TFT
Controller............... Mstar
Firmware revision........ Not supported
Firmware flags........... 0x00000045
Active power on time..... 65 hours
Power consumption........ Not supported
Current frequency........ Not supported
Color characteristics
Default color space...... sRGB
Display gamma............ 2,20
Red chromaticity......... Rx 0,647 - Ry 0,334
Green chromaticity....... Gx 0,284 - Gy 0,607
Blue chromaticity........ Bx 0,151 - By 0,071
White point (default).... Wx 0,313 - Wy 0,328
Additional descriptors... None
Timing characteristics
Horizontal scan range.... 31-83kHz
Vertical scan range...... 56-76Hz
Video bandwidth.......... 170MHz
CVT standard............. Not supported
GTF standard............. Not supported
Preferred timing......... Yes
Native/preferred timing.. 1920x1080p at 60Hz (16:9)
Modeline............... "1920x1080" 148,500 1920 2008 2052 2200 1080 1084 1089 1125 +hsync -vsync
Standard timings supported
720 x 400p at 70Hz - IBM VGA
640 x 480p at 60Hz - IBM VGA
640 x 480p at 67Hz - Apple Mac II
640 x 480p at 72Hz - VESA
640 x 480p at 75Hz - VESA
800 x 600p at 56Hz - VESA
800 x 600p at 60Hz - VESA
800 x 600p at 72Hz - VESA
800 x 600p at 75Hz - VESA
832 x 624p at 75Hz - Apple Mac II
1024 x 768p at 60Hz - VESA
1024 x 768p at 70Hz - VESA
1024 x 768p at 75Hz - VESA
1280 x 1024p at 75Hz - VESA
1152 x 864p at 75Hz - VESA STD
1280 x 1024p at 60Hz - VESA STD
1280 x 960p at 60Hz - VESA STD
1440 x 900p at 60Hz - VESA STD
1600 x 1200p at 60Hz - VESA STD
1680 x 1050p at 60Hz - VESA STD
1280 x 720p at 60Hz - VESA STD
EIA/CEA-861 Information
Revision number.......... 3
IT underscan............. Supported
Basic audio.............. Supported
YCbCr 4:4:4.............. Supported
YCbCr 4:2:2.............. Supported
Native formats........... 1
Detailed timing #1....... 1920x1080p at 60Hz (16:9)
Modeline............... "1920x1080" 148,500 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync
Detailed timing #2....... 1920x1080i at 60Hz (16:9)
Modeline............... "1920x1080" 74,250 1920 2008 2052 2200 1080 1084 1094 1124 interlace +hsync +vsync
Detailed timing #3....... 1280x720p at 60Hz (16:9)
Modeline............... "1280x720" 74,250 1280 1390 1430 1650 720 725 730 750 +hsync +vsync
Detailed timing #4....... 1920x1080i at 50Hz (16:9)
Modeline............... "1920x1080" 74,250 1920 2448 2492 2640 1080 1084 1094 1124 interlace -hsync +vsync
Detailed timing #5....... 1280x720p at 50Hz (16:9)
Modeline............... "1280x720" 74,250 1280 1720 1760 1980 720 725 730 750 +hsync +vsync
CE video identifiers (VICs) - timing/formats supported
1920 x 1080p at 60Hz - HDTV (16:9, 1:1) [Native]
1920 x 1080i at 60Hz - HDTV (16:9, 1:1)
1280 x 720p at 60Hz - HDTV (16:9, 1:1)
720 x 480p at 60Hz - EDTV (16:9, 32:27)
720 x 480p at 60Hz - EDTV (4:3, 8:9)
640 x 480p at 60Hz - Default (4:3, 1:1)
720 x 576p at 50Hz - EDTV (4:3, 16:15)
720 x 576p at 50Hz - EDTV (16:9, 64:45)
1280 x 720p at 50Hz - HDTV (16:9, 1:1)
1920 x 1080i at 50Hz - HDTV (16:9, 1:1)
1920 x 1080p at 50Hz - HDTV (16:9, 1:1)
720 x 480i at 60Hz - Doublescan (16:9, 32:27)
720 x 576i at 50Hz - Doublescan (16:9, 64:45)
NB: NTSC refresh rate = (Hz*1000)/1001
CE audio data (formats supported)
LPCM 2-channel, 16/20/24 bit depths at 32/44/48 kHz
CE speaker allocation data
Channel configuration.... 2.0
Front left/right......... Yes
Front LFE................ No
Front center............. No
Rear left/right.......... No
Rear center.............. No
Front left/right center.. No
Rear left/right center... No
Rear LFE................. No
CE vendor specific data (VSDB)
IEEE registration number. 0x000C03
CEC physical address..... 1.0.0.0
Maximum TMDS clock....... 165MHz
Report information
Date generated........... 25/08/2010
Software revision........ 2.52.0.857
Data source.............. Real-time 0x0041
Operating system......... 6.1.7600.2
Raw data
00,FF,FF,FF,FF,FF,FF,00,04,69,F4,24,01,01,01,01,20,13,01,03, 80,34,1D,78,EE,EE,D0,A5,55,48,9B,26,
12,50,54,BF,EF,00,71,4F,81,80,81,40,95,00,A9,40,B3,00,81,C0, 01,01,02,3A,80,18,71,38,2D,40,58,2C,
45,00,09,25,21,00,00,1A,00,00,00,FD,00,38,4C,1F,53,11,00,0A, 20,20,20,20,20,20,00,00,00,FC,00,41,
53,55,53,20,32,34,54,31,45,0A,20,20,00,00,00,FF,00,39,38,4C, 56,51,53,30,30,31,37,32,32,0A,01,4B,
02,03,20,F1,4D,90,05,04,03,02,01,11,12,13,14,1F,07,16,23,09, 07,07,83,01,00,00,65,03,0C,00,10,00,
02,3A,80,18,71,38,2D,40,58,2C,45,00,09,25,21,00,00,1F,01,1D, 80,18,71,1C,16,20,58,2C,25,00,09,25,
21,00,00,9F,01,1D,00,72,51,D0,1E,20,6E,28,55,00,09,25,21,00, 00,1F,01,1D,80,D0,72,1C,16,20,10,2C,
25,80,09,25,21,00,00,9D,01,1D,00,BC,52,D0,1E,20,B8,28,55,40, 09,25,21,00,00,1E,00,00,00,00,00,A2
tascon85
Any idea? Just to make me try something more.
chrisadam11
____________________________________________________________________________________________
Want to get-on Google's first page and loads of traffic to our website? Hire a SEO Specialist from Ocean Groups seo specialist
