Developing Games on Intel Graphics
If you are gaming on graphics integrated in your Intel Processor, this is the place for you! Find answers to your questions or post your issues with PC games
489 Discussions
Problems with h264 video display on Intel HD Graphics 4000
Mizuno__Hiroyuki
hello.
I am developing an application that receives and displays a from a network camera.
Updated the graphics driver in the environment that was working normally until now.
Then I encountered a phenomenon that the application hangs when stopping or starting h264 stream display.
Running the html sample we created in the same environment causes IE to stop working in a few hours.
At that time, the error log of ntdll.dll is recorded in the event log.
I asked the intel Graphics forum for help.
I followed the advice of the forum and confirmed that Ivy Bridge computer prepared separately shows the same phenomenon.
Then I got the advice to contact this community.
Test PC spec:
Model: HP ProBook 4540s
CPU: Intel Core i5 - 3210 M 2.5 GHz
RAM: 4 GB
Graphics: Intel HD Graphics 4000
OS: Windows 8 Pro 64bit (clean installation)
I applied version 10.18.10.3958 of intel graphics driver to the above PC and executed the attached HTML as the first post.
Then, the phenomenon that IE stops occurs.
I applied version 10.18.10.4885, but IE will stop in the same way.
What should I do in order to find the cause of the problem?
Finally, I will describe my environment. Also attach the sample html and some files.
thanks.
Michael_C_Intel2
Try using the Intel Graphics Performance Analyzer (GPA), it is a free download and we many tutorials on its use
https://software.intel.com/en-us/gpa
