Edge Software Catalog
The Edge Software Catalog community is read-only. For support, please visit the Open Edge Platform (https://github.com/open-edge-platform) GitHub organization and post your question in the relevant repository’s Issues section.
Castle lake server
Rajnish
Hi weng/Murni,
My Csl server is not getting listed on the Csl manager dashboard.i am getting errors while running following command.
$ curl -u <csl_manager_username> <csl_manager_url> api/v1/servers
PFA for logs.
kubelet service is also failing to start.Rest other services are in running state.Could u help me resolving this issue.let me know if i am doing anything wrong.Since i am behind proxy is the above command correct?
Thank you
WengWai_C_Intel
Hi @Rajnish
If you have rebooted the system and do not see the k8s containers are running, please issue below command:
sudo swapoff -a
Then you can use docker ps command to check if the k8s containers are up running.
To use the API command to list the CSL server, the correct format of API is as below. You can get the API command from the csl_api_doc.pdf file under orchestrator/docs directory.
curl -ku user:password -X GET "https://csl-manager-host:8443/api/v1/servers" -H "Accept: application/json"
where, you will use your own username, password and CLS manager host IP in the above API.
WengWai_C_Intel
Hi @Rajnish
sudo swapoff -a
Rajnish
Hi Weng,
I could see the csl server listed in dashboard along with status online.
Thank You
WengWai_C_Intel
Great, thanks for the update.
All the steps are documented in the CSL setup guide and APIs are documented in the csl_api_doc.pdf file. You can use that as reference.
