Can we use the OVMS as a inference plugin into the DLStreamer pipeline.If so how could we do it.
Could you explain further:
- What are you trying to achieve by using OVMS and DL Streamer? (you use case).
- Which edge software packages are you using (eg: ECI) since you are asking in Edge Software Hub section?
Cordially,
Iffa
Thank you for your question. If you need any additional information from Intel, please submit a new question as Intel is no longer monitoring this thread.
Cordially,
Iffa
