Edge Software Catalog
The Edge Software Catalog community is read-only. For support, please visit the Open Edge Platform (https://github.com/open-edge-platform) GitHub organization and post your question in the relevant repository’s Issues section.
492 Discussions
[EI4AMR] Confirmation the mapping slip
Arioka
Dear Customer Support,
I verify AMR SDK with AAEON* Robot Kit.
When I create the map following to Section "Control the UP Xtreme i11 Robotic Kit Using a Gamepad" in following website, it’s not working mapping correctly.
Launch Wandering Application on AAEON* Robot Kit (intel.com)
We were testing in a square environment, however the map slips gradually.
Could you please suggest/operation if you have any information.
Arioka
Arioka
Hi Jesus-san,
I re-confirmed calibration. It seems that we don't calibrate well.
This issue is resolved by calibration.
Thank you for your support.
Arioka
JesusE_Intel
Hi Arioka,
Thanks for reaching out, could you please help answer the following questions?
  • What version of Edge Insights for AMR are you using?
  • Did you run into any issues when calibrating your robots IMU sensor?
  • Is the robot moving properly?
  • Are the map results the same when moving the robot with Wandering App or using a gamepad?
Jesus
Arioka
Hi Jesus-san,
-> I use EI for AMR ver.2022.2.
-> I don't face any issue during calibrating. However, I couldn't judge whether I can calibrate correctly because I face this issue every time.
-> Yes. I tried "wandering", "operation by keyboard" and "operation by Game Pad". Robot can move correctly but the mapping is not working correctly.
-> Yes. The mapping can operate correctly only about first 1 minute. If the mapping continues, the mapping slips gradually like as picture.
Arioka
Arioka
Hi Jesus-san,
Arioka
JesusE_Intel
Hi Arioka,
Glad you were able to resolve your issue! If you need any additional information, please submit a new question as this thread will no longer be monitored.
Jesus
