Edge Software Catalog
The Edge Software Catalog community is read-only. For support, please visit the Open Edge Platform (https://github.com/open-edge-platform) GitHub organization and post your question in the relevant repository’s Issues section.
492 Discussions
EIS installation fails on Ubuntu 18.04.5
Mauricio
Hi team,
I´m writing to share with you the error I am getting in the installation of the EIS framework, in a virtual machine with ubuntu 18.04.5 (VirtualBox).
I´ve attached two images.
In image "cap1.png", we can see the result of the first installation attempt on the left, and the result of the following attempts on the right.
On the first attempt, the installation of "coreDNS" fails, and on subsequent attempts the installation of "Castle Lake Manager" fails.
Therefore, the orchestrator module cannot be installed.
The "cap2.png" image refers to a message we get in the middle of the installation, before it fails.
Could you please give me a feedback on these errors?
Best regards.
Mauricio Aguilar
Software Developer
Murni_J_Intel
Hi @Mauricio
May I know if this error is showing by using the Download Version 2.3.1? if yes, you can get the new Download Version 2.3.2 and continue to use the user guide for the manual installation because for the new release this orchestrator component will not be auto-installed.
Previously you mentioning that you only need the video analytics component to be installed. In that case, you can use the customize and download. You can uncheck for this component and proceed to install the package.
Murni_J_Intel
Hi @Mauricio
Mauricio
Hi team,
I am writing to tell you that we have already been able to install the EIS, with a custom installation, by disabling the modules:
>Training and Learning Suite (TLS).
>Rotor Bearing Defector Detector.
>Manageability.
>Orchestrator.
Thank you very much for your help.
Best regards.
