Edge Software Catalog
446 Discussions
ESDQ 6.0 Vision test module fail
TChio
Hi Sir:
we hope to validate TGL-UP3 with Vision ESDQ .
So far we test mix ESDQ 5.0 and 6.0 componet module but still fail and many times .
1. what the new 6.0 Vision module can't download ?
<project path="installation/src" id="621692878bad76002bce2ee8" version="2021.4.1" label="esdq/Vision_Test_Module"/>
Downloading component esdq/Vision_Test_Module
Failed to download the module esdq/Vision_Test_Module. 404 Not Found
2.So we used old vision test module
<project id="6216928e8bad76002bce2ef4" label="esdq/Vision_Test_Module" path="installation/src" version="2021.4.1" />
for the testing with HDDL problem i had been Add following entry in $HDDL_INSTALL_DIR/config/hddl_service.config like this:
"service_settings":
"autoboot_boot_timeout_sec": 10,
that still fail .
| Test Module | Version | ID |
| Vision_Test_Module | 2021.4.1 | 6216928e8bad76002bce2ef4 |
| VATS_Test_Module | 2021.4 | 60f084f3acbb0a002bcaee71 |
----Starting HDDL Daemon-------
PID of HDDL Daemon - 2698435
Stopping the existing OpenVINO containers
[09:41:01.3401][2698443]I[FileHelper.cpp:268] Set file:/var/tmp/hddl_autoboot_alive.mutex owner: user-'no_change', group-'users', mode-'0660'
[09:41:01.3401][2698443]I[FileHelper.cpp:268] Set file:/var/tmp/hddl_autoboot_ready.mutex owner: user-'no_change', group-'users', mode-'0660'
[09:41:01.3401][2698443]I[FileHelper.cpp:268] Set file:/var/tmp/hddl_autoboot_start_exit.mutex owner: user-'no_change', group-'users', mode-'0660'
[09:41:01.3402][2698443]I[FileHelper.cpp:268] Set file:/tmp/hddl_autoboot_device.map owner: user-'no_change', group-'users', mode-'0660'
[09:41:01.3406][2698443]I[AutoBoot.cpp:308] [Firmware Config] deviceName=default deviceNum=0 firmwarePath=/opt/intel/openvino_2021/deployment_tools/inference_engine/external/hddl/lib/mvnc/usb-ma2x8x.mvcmd
[E:] [BSL] No device found
[09:41:01.3506][2698443]ERROR[AutoBoot.cpp:478] Error: HDDL hardware initialization failed, exits now.
Running the Container
No image found. Aborting installation.(B
[09:41:01.3287][2698435]I[main.cpp:246] ## HDDL_INSTALL_DIR: /opt/intel/openvino_2021/deployment_tools/inference_engine/external/hddl
[09:41:01.3287][2698435]I[main.cpp:248] Config file '/opt/intel/openvino_2021/deployment_tools/inference_engine/external/hddl/config/hddl_service.config' has been loaded
[09:41:01.3289][2698435]I[FileHelper.cpp:268] Set file:/var/tmp/hddl_service_alive.mutex owner: user-'no_change', group-'users', mode-'0660'
[09:41:01.3291][2698435]I[FileHelper.cpp:268] Set file:/var/tmp/hddl_service_ready.mutex owner: user-'no_change', group-'users', mode-'0660'
[09:41:01.3291][2698435]I[FileHelper.cpp:268] Set file:/var/tmp/hddl_service_failed.mutex owner: user-'no_change', group-'users', mode-'0660'
[09:41:01.3291][2698435]I[FileHelper.cpp:268] Set file:/var/tmp/hddl_start_exit.mutex owner: user-'no_change', group-'users', mode-'0660'
[09:41:01.3300][2698435]I[AutobootStarter.cpp:156] Info: No running autoboot process. Start autoboot daemon...
[09:41:02.3312][2698435]I[AutobootStarter.cpp:79] Info: Service has been waiting for Autoboot to boot up for 1 seconds ...
[09:41:03.3323][2698435]I[AutobootStarter.cpp:79] Info: Service has been waiting for Autoboot to boot up for 2 seconds ...
[09:41:04.3331][2698435]I[AutobootStarter.cpp:79] Info: Service has been waiting for Autoboot to boot up for 3 seconds ...
[09:41:05.3345][2698435]I[AutobootStarter.cpp:79] Info: Service has been waiting for Autoboot to boot up for 4 seconds ...
[09:41:06.3359][2698435]I[AutobootStarter.cpp:79] Info: Service has been waiting for Autoboot to boot up for 5 seconds ...
[09:41:07.3370][2698435]I[AutobootStarter.cpp:79] Info: Service has been waiting for Autoboot to boot up for 6 seconds ...
[09:41:08.3386][2698435]I[AutobootStarter.cpp:79] Info: Service has been waiting for Autoboot to boot up for 7 seconds ...
[09:41:09.3399][2698435]I[AutobootStarter.cpp:79] Info: Service has been waiting for Autoboot to boot up for 8 seconds ...
[09:41:10.3412][2698435]I[AutobootStarter.cpp:79] Info: Service has been waiting for Autoboot to boot up for 9 seconds ...
[09:41:11.3425][2698435]I[AutobootStarter.cpp:79] Info: Service has been waiting for Autoboot to boot up for 10 seconds ...
[09:41:12.3439][2698435]I[AutobootStarter.cpp:79] Info: Service has been waiting for Autoboot to boot up for 11 seconds ...
[09:41:13.3449][2698435]I[AutobootStarter.cpp:79] Info: Service has been waiting for Autoboot to boot up for 12 seconds ...
[09:41:14.3463][2698435]I[AutobootStarter.cpp:79] Info: Service has been waiting for Autoboot to boot up for 13 seconds ...
[09:41:15.3476][2698435]I[AutobootStarter.cpp:79] Info: Service has been waiting for Autoboot to boot up for 14 seconds ...
[09:41:16.3486][2698435]I[AutobootStarter.cpp:79] Info: Service has been waiting for Autoboot to boot up for 15 seconds ...
[09:41:16.3486][2698435]ERROR[AutobootStarter.cpp:89] Error: Service wait Autoboot to get ready failed due to timeout after 15 seconds.
[09:41:16.3487][2698435]W[AutobootStarter.cpp:90]
** Suggestion: The timeout by default is 10 seconds, and you can increase it by following steps:
(1) Add following entry in $HDDL_INSTALL_DIR/config/hddl_service.config like this:
"service_settings":
(2) Change the '10' to a larger value to increase the time out window, then try again.
[09:41:16.3487][2698435]ERROR[AutobootStarter.cpp:49] Error: Failed to start autoboot
[09:41:17.6488][2698435]ERROR[main.cpp:77] Error: Start Service failed due to autoboot failure
SShan_Intel
Hi TChio,
Sorry for late response, we have fix the issue. Could you redownload the package and try it again?
https://software.intel.com/iot/edgesoftwarehub/download/home/esdq_vision
SShan_Intel
SShan_Intel
Hi TChio,
May i know have you try install the latest 6.1 ? I have tested and it manage to install esdq/Vision_Test_Module. Also, may I know if you are installing within corporate network? Lastly, what is your ubuntu kernel version ?
SShan_Intel
TChio
Hi SShan :
1. That version 6.1 not 6.0 . (Vision_Test_Module download fial , error 404) ; because i confuse that LicenseSummary-ESDQ-6.0 .
2. we used smart phone share Ethernet by USB .
3. System information as below . ( 5.8 and 5.13 had been test)
System Category Property Value
0 SOFTWARE INFO OS version Ubuntu 20.04.4 LTS
1 SOFTWARE INFO Kernel
5.13.0-41-generic
Tab Chiou
SShan_Intel
Hi Tab Chiou,
Could you sent me log file ?
/var/log/esb-cli/Edge_Software_Device_Qualification_6.1/output.log
/var/log/esb-cli/Edge_Software_Device_Qualification_6.1/esdq/install.log
Also for you information, this error that you getting "[E:] [BSL] No device found
[09:41:01.3506][2698443]ERROR[AutoBoot.cpp:478] Error: HDDL hardware initialization failed, exits now." means that you havent setup HDDL device in your system.
SShan_Intel
TChio
Hi SShan :
as attached for you .
we already use below way hope to skip HDDL but no used.
./esdq run [MODULE_ID]
Tab Chiou
(Virus scan in progress ...)
SShan_Intel
Hi TChio,
SShan_Intel
