Edge Software Catalog
441 Discussions
ESDQ 6.1 on ElKhart Lake Platform can not run (Vision test module fail)
Eke
Hi Sir:
we hope to validate Elkhart Lake with Vision ESDQ .
Issue Description :
The final report data (esdqReport_2022-05-18_03_46.zip) does no shows the test result output of “ Vision test module ”.
So far we test mix ESDQ 5.0 and 6.1 componet module, but still fail and many times .
1. The new 6.1 Vision module can't download ?
<project path="installation/src" id="621692878bad76002bce2ee8" version="2021.4.1" label="esdq/Vision_Test_Module"/>
Downloading component esdq/Vision_Test_Module
Failed to download the module esdq/Vision_Test_Module. 404 Not Found
2.So we used old vision test module
<project id="6216928e8bad76002bce2ef4" label="esdq/Vision_Test_Module" path="installation/src" version="2021.4.1" />
for the testing with HDDL problem i had been Add following entry in $HDDL_INSTALL_DIR/config/hddl_service.config like this:
"service_settings":
"autoboot_boot_timeout_sec": 10,
that still fail .
| Test Module | Version | ID |
| Vision_Test_Module | 2021.4.1 | 6216928e8bad76002bce2ef4 |
| VATS_Test_Module | 2021.4 | 60f084f3acbb0a002bcaee71 |
Summary
Property
Value
0
ESDQ Version
6.0
1
Execution Timestamp UTC
2022-05-18 03:44:41
2
Duration
0:01:38
3
Number of test category
3
4
Test Categories
'SysInfo' 'Vision_Test_Module' 'VATS_Test_Module'
SystemInfo
System Category
Property
Value
0
SOFTWARE INFO
OS version
Ubuntu 20.04.4 LTS
1
SOFTWARE INFO
Kernel
5.13.0-41-generic
2
HARDWARE INFO
Device Manufacturer
Neousys Technology Inc.
3
HARDWARE INFO
Hardware Architecture
x86_64
4
HARDWARE INFO
Processor
Intel Atom(R) x6425E Processor @ 2.00GHz
5
HARDWARE INFO
GPU
Intel Corporation
6
HARDWARE INFO
Memory size
15Gi
7
HDD Configurations
Model
ATA INTEL SSDSCKKR12 (scsi)
8
HDD Configurations
Disk /dev/sda
120GB
9
HDD Configurations
Sector size (logical/physical)
512B/512B
10
HDD Configurations
Partition Table
gpt
11
HDD Configurations
Disk Flags Header
Number Start End Size File system Name Flags
12
HDD Configurations
Disk Flags
1 1049kB 538MB 537MB fat32 EFI System Partition boot esp
13
HDD Configurations
Disk Flags
2 538MB 120GB 119GB ext4
14
HARDWARE ACCELERATOR
VPU
0
15
FPGA
0
ModulesInfo
Installed Module
Status
0
K3s_Lightweight_Kubernetes
SUCCESS
1
Intel_Distribution_of_OpenVINO_toolkit_2021_4_2_Runtime
SUCCESS
2
Intel_Deep_Learning_Streamer
SUCCESS
3
Docker_Community_Edition_CE
SUCCESS
4
Intel_Distribution_of_OpenVINO_toolkit_2021_4_2_in_a_Container
SUCCESS
5
Docker_Compose
SUCCESS
6
Edgex_Foundry
SUCCESS
7
RI_MultiCamera_Social_Distancing
SUCCESS
8
esdq
SUCCESS
Test Suites
Vision_Test_Module
ModuleName
Test CaseName
SampleProgram
Status
VATS_Test_Module
Missing report !
JesusE_Intel
Hi Eric,
The development team has addressed this issue. I tested from my end and can confirm the test modules are now displaying in the report. Could you please re-download the ESDQ package and test on your side? Please let me know if you have any issues.
Jesus
JesusE_Intel
Hi Eke,
Thanks for reporting, I was able to reproduce the issue and have reached out to the development team. I will let you know what I find out.
Jesus
Eke
Hi Jesus,
Thanks for support, I will be waitting for your further good news!
Eric Ke
JesusE_Intel
Hi Eric,
Jesus
JesusE_Intel
