Edge Software Catalog
488 Discussions
ESDQ failed on Tiger Lake platform
J-N-ch
I have tested both ESDQ 3.0 and 4.0 on two separated clean and newly installed Ubuntu 20.04. Both with Linux kernel 5.8. The result turned out that ESDQ 4.0 were mostly failed, while most of the failures in ESDQ 3.0 is associated with Movidius. The following reports were attached.
JesusE_Intel
Hi J-N-ch,
Looking at the Reports for the Tiger Lake platform, when you used ESDQ 3.0 the system had Kernel 5.8. However, when you used ESDQ 4.0 the system had Kernel 5.11. Could you double check? ESDQ currently support Kernel 5.4 and 5.8.
Could you attach the reports again? I don't see the .html file for the 6305E system and the Tiger Lake system for ESDQ 4.0 show Pass for all testes.
Jesus
JesusE_Intel
Hi J-N-ch,
Jesus
JesusE_Intel
