Edge Software Catalog
The Edge Software Catalog community is read-only. For support, please visit the Open Edge Platform (https://github.com/open-edge-platform) GitHub organization and post your question in the relevant repository’s Issues section.
492 Discussions
[ESDQ for Aibox] Error: Failed to verify system dependencies
AmandaLee
Dear Expert,
After the installation of "ESDQ for Aibox" was completed, I tried to execute the "esdq" command, but received "Failed to verify system dependencies".
Is there any solution?
Thanks & Regards,
Amanda
Iffa_Intel
just to clarify, did you use any docker container during installation? If so, ensure you are within the container & try to run the command again.
Cordially,
Iffa
AmandaLee
Hi Iffa,
I tried reinstalling "ESDQ for Aibox" on a clean Ubuntu system, but ran into a new problem.
At "./edgesoftware install" stage, the installation fails. It seems to be caused by the wrong linux kernel header name. Could you help me with how to solve it?
Thank & Regards,
Amanda
Iffa_Intel
Could you try this command:
sudo apt install "your missing header (linux-headers-6.7.10-060710-generic)"
Reboot, then try installing the package again.
Cordially,
Iffa
Iffa_Intel
Intel will no longer monitor this thread since we have provided a solution. If you need any additional information from Intel, please submit a new question.
Cordially,
Iffa
