Edge Software Catalog
The Edge Software Catalog community is read-only. For support, please visit the Open Edge Platform (https://github.com/open-edge-platform) GitHub organization and post your question in the relevant repository’s Issues section.
492 Discussions
ESDQ for Edge AI Box installation issue
AmandaLee
Dear Expert,
According to the guide, I am trying to setup and execute the "ESDQ for AIbox" version 3.1.1/3.1 on Ubuntu 22.04. But "modules/Aibox Test Module" installation failure happened.
Please share any suggestions to resolve this.
Thanks & Regards,
Amanda
SShan_Intel
Hi Amanda,
We are aware of this issue and you can use this as workaround:
  1. Got to Intel_Edge_AI_Box_3.1.1/modules/Aibox_Test_Module/src/openvino_benchmark, change Dockerfile line#41
    from
    RUN pip3 install -r /tmp/yolov5-7.0/requirements.txt && pip3 install ipython==8.22.2
    to
    RUN pip3 install ipython==8.22.2 && pip3 install -r /tmp/yolov5-7.0/requirements.txt
  2. Run `./edgesoftware install` to install again.
We will soon update the documentation on this workaround. Let us know if this resolve the issue.
SShan_Intel
Iffa_Intel
It seems that your issue is related to Docker.
Try running your Docker as non-sudo user and run these commands:
  • sudo apt update
  • sudo apt upgrade
  • sudo reboot
Then, try installing the package again.
Cordially,
Iffa
AmandaLee
Hi Iffa,
Thanks for your reply. However, I just followed the ESDQ guide and did not run Docker manually.
I tried to reinstall ubuntu 22.04, and re-downloaded and executed "./edgesoftware install" according to the guide. The "Aibox Test Module" still can't be installed successfully.
Amanda
SShan_Intel
Hi Amanda,
    from
    to
SShan_Intel
AmandaLee
Hi SShan_Intel,
After modifying the Dockerfile, the error still occurs.
According to the error message, I checked the docker images generated during the installation process and found that there was no 3.1.1 images required for compilation.
So, I tagged aibox-base, aibox-base-devel..etc, to 3.1.1.
It can be solved. Thank you.
Amanda
Iffa_Intel
Just to clarify, did you manage to solve the issue? and do you have any further inquiries?.
If not shall we proceed to close this thread?
Cordially,
Iffa
AmandaLee
Hi Iffa,
This problem has been solved, thank you.
Amanda
Iffa_Intel
Intel will no longer monitor this thread since this issue has been resolved. If you need any additional information from Intel, please submit a new question.
Cordially,
Iffa
