I have installed and run the Intel ESDQ package for vision on a target system (Processor: Intel(R) Core (TM) i3-10100E CPU @ 3.20GHz). After installation, some of the test modules Failed.
As shown in attachment, the modules “Intel Distribution of OpenVINO toolkit 2021 4 Runtime, Deep Learning DL Streamer Pipelines” have failed.
Attached, please check the logs and ESDQ test report generated. Would you please share your comments and suggestions about this issue.
ModulesInfo
Installed Module |
Status |
0 |
Amazon_Web_Services_Greengrass_Prerequisites |
SUCCESS |
1 |
K3s_Lightweight_Kubernetes |
SUCCESS |
2 |
Azure_IoT_Edge_Prerequisites |
SUCCESS |
3 |
Intel_Distribution_of_OpenVINO_toolkit_2021_4_Runtime |
FAILED |
4 |
Deep_Learning_DL_Streamer_Pipelines |
FAILED |
5 |
Docker_Community_Edition_CE |
SUCCESS |
6 |
Intel_Distribution_of_OpenVINO_toolkit_2021_4_Container |
SUCCESS |
7 |
edgex_foundry |
SUCCESS |
8 |
RI_MultiCamera_Social_Distancing |
SUCCESS |
9 |
esdq |
SUCCESS |
10 |
Docker_Compose |
SUCCESS |
Target System Information:
CPU: Intel(R) Core(TM) i3-10100E CPU @ 3.20GHz
OS: Ubuntu 18.04.5 LTS
Kernel: 5.4.0-125-generic
ESDQ Version: 5.0
Thanks & Regards,
Julien
Hi Julien,
The system you are using is a 11th Gen Desktop processor version with Intel UHD Graphics. I'm testing on a 11th Gen Mobile processor. I'll need to see if I can find a system to test ESDQ. In the meantime, could you make sure the graphics driver is setup and user permissions have been set?
Jesus
Hi Julien,
I just tested ESDQ5.0 on Ubuntu 18.04 and OpenVINO failed to install as well. Looking at the logs, I see ONNX failed to install which caused the OpenVINO Model Optimizer installation to fail. I resolved this by installing ONNX manually: pip3 install onnx==1.8.1. Could you try and see if this resolves the issue for you?
If this does not work, please provide the log files for OpenVINO installation under /var/log/esb-cli/Edge_Software_Device_Qualification/Intel_Distribution_of_OpenVINO_toolkit_2021.4_Runtime
Jesus
Hi Jesus,
Thanks for the response. I have followed your instructions by installing the ONNX and run the ESDQ again. Then, the OpenVino works fine for now.
But I face some new issues as shown below, the MSDK5 test fails, and the report is missing for the VATS_Test_Module.
Attached, please check the test report. Have you faced this issue as well? Please let me know if you have an idea on how to solve it, please.
Summary
Property | Value | |
0 | ESDQ Version | 5.0 |
1 | Execution Timestamp UTC | 2022-09-19 03:44:11 |
2 | Duration | 0:09:48 |
3 | Number of test category | 3 |
4 | Test Categories | 'SysInfo' 'Vision_Test_Module' 'VATS_Test_Module' |
SystemInfo
System Category | Property | Value | |
0 | SOFTWARE INFO | OS version | Ubuntu 18.04.5 LTS |
1 | SOFTWARE INFO | Kernel | 5.4.0-125-generic |
2 | HARDWARE INFO | Device Manufacturer | Default string |
3 | HARDWARE INFO | Hardware Architecture | x86_64 |
4 | HARDWARE INFO | Processor | Intel(R) Core(TM) i3-10100E CPU @ 3.20GHz |
5 | HARDWARE INFO | GPU | Intel Corporation |
6 | HARDWARE INFO | Memory size | 3.7G |
7 | HDD Configurations | Model | ATA WDC WDS250G2B0A (scsi) |
8 | HDD Configurations | Disk /dev/sda | 250GB |
9 | HDD Configurations | Sector size (logical/physical) | 512B/512B |
10 | HDD Configurations | Partition Table | gpt |
11 | HDD Configurations | Disk Flags Header | Number Start End Size File system Name Flags |
12 | HDD Configurations | Disk Flags | 1 1049kB 538MB 537MB fat32 EFI System Partition boot esp |
13 | HDD Configurations | Disk Flags | 2 538MB 250GB 250GB ext4 |
14 | HARDWARE ACCELERATOR | VPU | 0 |
15 | HARDWARE ACCELERATOR | FPGA | 0 |
ModulesInfo
Installed Module | Status | |
0 | Amazon_Web_Services_Greengrass_Prerequisites | SUCCESS |
1 | K3s_Lightweight_Kubernetes | SUCCESS |
2 | Azure_IoT_Edge_Prerequisites | SUCCESS |
3 | Intel_Distribution_of_OpenVINO_toolkit_2021_4_Runtime | SUCCESS |
4 | Deep_Learning_DL_Streamer_Pipelines | SUCCESS |
5 | Docker_Community_Edition_CE | SUCCESS |
6 | Intel_Distribution_of_OpenVINO_toolkit_2021_4_Container | SUCCESS |
7 | edgex_foundry | SUCCESS |
8 | RI_MultiCamera_Social_Distancing | SUCCESS |
9 | esdq | SUCCESS |
10 | Docker_Compose | SUCCESS |
Test Suites
Vision_Test_Module
ModuleName | Test CaseName | SampleProgram | Status | |
0 | media_sdk | MSDK1 | Mediasdk_sample_decode with h264 | Pass |
1 | media_sdk | MSDK2 | mediasdk_sample_multi_transcode with h264 and mpeg2 | Pass |
2 | media_sdk | MSDK3 | mediasdk_set_commands with h264 mixed model | Pass |
3 | media_sdk | MSDK4 | mediasdk_set_commands with h265 mixed model | Pass |
4 | media_sdk | MSDK5 | mediasdk_sample_encode with h265 | Fail |
5 | media_sdk | MSDK6 | mediasdk_sample_vpp with sw | Pass |
6 | aws_greengrass | AWS1 | aws_hello_world_sample | Pass |
7 | k3s | K3S1 | k3s_sample | Pass |
8 | openvino | CPU1 | hello_reshape_ssd with CPU | Pass |
9 | openvino | CPU2 | style_transfer_sample_python with CPU | Pass |
10 | openvino | CPU3 | object_detection_demo_ssd_async CPU | Pass |
11 | openvino | CPU4 | object_detection_demo_python with CPU | Pass |
12 | openvino | GPU1 | hello_reshape_ssd with GPU | Pass |
13 | openvino | GPU2 | style_transfer_sample_python with GPU | Pass |
14 | openvino | GPU3 | object_detection_demo_ssd_async GPU | Pass |
15 | openvino | GPU4 | run_tc_object_detection_demo_ssd__python with GPU | Pass |
VATS_Test_Module
Missing report !
Thanks & Regards,
Julien
Please check the logs and test report in attachment.
Hi Julien,
From the logs, I can see your system is not detecting any hardware accelerator (HDDL) devices. Is there one installed in your system? Can you provide the output of the lsusb command? The empty VATs tests are expected when no HDDL device is connected to the system.
Regarding the MediaSDK test fails, I see [ERROR], sts=MFX_ERR_UNSUPPORTED(-3) error in the log file. Could you please try the steps included in the Troubleshooting section of the installation guide? Please let me know if this works for you.
Jesus
Hi Jesus,
I have used the “Intel® Neural Compute Stick 2” shown in attachment and run the test again. The VATs tests is appeared now, but there are some failed tests from VATs. Attached, please check the update result. Please let me know if you have any suggestions.
I have also tried to use the steps included in the Troubleshooting section of the installation guide to fix the MediaSDK test. But it doesn’t work for me. Please suggest.
ModulesInfo
Test Suites
Vision_Test_Module
16 | openvino | HDDL1 | hello_reshape_ssd with HDDL | Fail |
17 | openvino | HDDL2 | style_transfer_sample_python with HDDL | Fail |
18 | openvino | HDDL3 | object_detection_demo_ssd_async HDDL | Fail |
19 | openvino | HDDL4 | object_detection_demo_ssd_async_python with HDDL | Fail |
VATS_Test_Module
Test ID | Status | Iterations | Pass Rate | Start Time | End Time | Duration | Host Ave CPU (%) | Host Max CPU (%) | Host Ave Memory (%) | Host Max Memory (%) | |
0 | firmware_loading_time | Fail | 2 | 0% | 2022-09-21-15:05:40 | 2022-09-21-15:06:19 | 39s | 0.0 | 24.6 | 0.2 | 4.2 |
1 | reset_1 | Pass | 1 | 100% | 2022-09-21-15:06:20 | 2022-09-21-15:06:23 | 3s | 0.0 | 0.0 | 0.0 | 0.0 |
2 | hardware_ping | Fail | 1 | 0% | 2022-09-21-15:06:24 | 2022-09-21-15:07:03 | 39s | 0.1 | 1.0 | 0.0 | 0.3 |
3 | io_ping_test | Pass | 1 | 100% | 2022-09-21-15:07:04 | 2022-09-21-15:07:07 | 3s | 0.0 | 0.0 | 0.2 | 0.2 |
4 | performance_alexnet | Fail | 1 | 0% | 2022-09-21-15:07:08 | 2022-09-21-15:07:11 | 3s | 0.0 | 0.0 | 0.3 | 0.3 |
5 | performance_densenet-121 | Fail | 1 | 0% | 2022-09-21-15:07:12 | 2022-09-21-15:07:16 | 3s | 0.0 | 0.0 | 0.3 | 0.3 |
6 | performance_googlenet-v1 | Fail | 1 | 0% | 2022-09-21-15:07:17 | 2022-09-21-15:07:20 | 3s | 0.0 | 0.0 | 0.3 | 0.3 |
7 | performance_mobilenet-ssd | Fail | 1 | 0% | 2022-09-21-15:07:21 | 2022-09-21-15:07:24 | 3s | 0.0 | 0.0 | 0.3 | 0.3 |
8 | performance_mobilenet-v1-1.0-224 | Fail | 1 | 0% | 2022-09-21-15:07:25 | 2022-09-21-15:07:28 | 3s | 0.0 | 0.0 | 0.3 | 0.3 |
9 | performance_mobilenet-v2 | Fail | 1 | 0% | 2022-09-21-15:07:29 | 2022-09-21-15:07:32 | 3s | 0.0 | 0.0 | 0.3 | 0.3 |
10 | performance_squeezenet1.1 | Fail | 1 | 0% | 2022-09-21-15:07:33 | 2022-09-21-15:07:36 | 3s | 0.0 | 0.0 | 0.3 | 0.3 |
11 | performance_resnet-50-pytorch | Fail | 1 | 0% | 2022-09-21-15:07:37 | 2022-09-21-15:07:40 | 3s | 0.0 | 0.0 | 0.3 | 0.3 |
12 | thermal_test | Fail | 1 | 0% | 2022-09-21-15:07:41 | Wed Sep 21 15:07:44 2022 | 3s | 0.0 | 0.0 | 0.2 | 0.2 |
Thanks & regards,
--Julien
Hi Jesus,
ModulesInfo
Test Suites
Vision_Test_Module
VATS_Test_Module
Thanks & regards,
--Julien
Hi Jesus,
I have also tried to use the steps included in the Troubleshooting section of the installation guide to fix the MediaSDK test. But it doesn’t work for me. Please suggest, Thanks.
ModulesInfo
Test Suites
Vision_Test_Module
VATS_Test_Module
Thanks & regards,
--Julien
Hi Jesus,
I have also tried to use the steps included in the Troubleshooting section of the installation guide to fix the MediaSDK test. But it doesn’t work for me. Please suggest, thanks.
ModulesInfo
Test Suites
Vision_Test_Module
VATS_Test_Module
Thanks & regards,
--Julien
Hi Julien,
Apologies for the delay, I somehow missed the notification for your last message. I believe you need to use an Intel Vision Accelerator with MYRIAD X (HDDL) that uses the HDDL Plugin. The Intel Neural Compute Stick 2 utilizes the Myriad Plugin from OpenVINO. The HDDL plugin may also pick up the NCS 2 and configure it as an HDDL device but I'll need to run some tests and confirm.
In the meantime, could you try these steps: https://www.intel.com/content/www/us/en/developer/articles/technical/edge-software-device-qualification-vision.html#inpage-nav-6-undefined-1
Also, try to install the Intel NCS 2 device rules:
Jesus
Hi Jesus,
Thanks for your response. I have already tried the troubleshooting steps mentioned in these links but still not working.
About the Intel NCS 2 device rules, the demo (Image Classification verification script.) test still shows “[ERROR] no device found” as shown in attachment.
Attached, please also check the output of lsusb command. Please let me know if you have further information about the The HDDL plugin to configure the NCS 2 as an HDDL device.
Thanks & regards,
--Julien
Hi Julien,
The lsusb command shows the Intel Neural Compute Stick 2 is being used by the HDDL Plugin. Could you try to use the latest ESDQ 6.1 and see if the same behavior is seen? After installing ESDQ 6.0 reboot your system to ensure the device rules have been properly configured for the Myriad X device.
From my test, only the HDDL Hardware ping fails, all other tests pass. I will confirm with the team if we have validated with an Intel Neural Compute Stick 2.
Jesus
Hi Jesus,
Thanks for the update. I have some more questions:
Which ubuntu version do you use to run the ESDQ6.0 vision test?
Have you done any additional configuration for NCS 2 (or just plug & play)?
As you suggested I have installed, the ESDQ6.1 vision on ubuntu 18.04 but some VATS still fail.
I also face this new problem with the new version (ESDQ6.01) , the Vision_Test_Module can not be executed because it is stuck while Pinging https://www.intel.com to check the internet connectivity as shown below (over 1 hour):
“Pinging https://www.intel.com for checking Internet Connectivity. Please wait for few seconds.” any idea about this issue?
Attached, please check logs for the ESDQ6.1 test. Please let me know about your suggestions.
Thanks & Regards
Julien
Hi Julien,
For ESDQ 6.1, I am running on Ubuntu 20.04. I am just connecting the NCS 2 when running the tests.
- Installed fresh Ubuntu 20.04
- Installed updates: apt update && apt upgrade
- Installed esdq 6.1
- Run test: esdq run -r
I did see the Vision Test Modules getting stuck pinging the site. I assumed it was an issue on my network. Let me open a bug for this new issue, thanks for pointing that out.
Jesus
Hi Jesus,
I have followed your instructions to run the ESDQ6.1 Vision test on ubuntu 20.04 but still face the same issue as shown below. Do you think it might be hardware issue?
I also face the same problem to ping the intel website (https://www.intel.com) while running the Vision Test Modules. Please let me know if there is any update about this bug.
ModulesInfo
0 | K3s_Lightweight_Kubernetes | SUCCESS |
1 | Intel_Distribution_of_OpenVINO_toolkit_2021_4_2_Runtime | SUCCESS |
2 | Intel_Deep_Learning_Streamer | SUCCESS |
3 | Docker_Community_Edition_CE | SUCCESS |
4 | Intel_Distribution_of_OpenVINO_toolkit_2021_4_2_in_a_Container | SUCCESS |
5 | Docker_Compose | SUCCESS |
6 | Edgex_Foundry | SUCCESS |
7 | RI_MultiCamera_Social_Distancing | SUCCESS |
8 | esdq | SUCCESS |
Test Suites
Vision_Test_Module
Missing report !
VATS_Test_Module
0 | firmware_loading_time | Fail | 2 | 0% | 2022-10-03-15:40:11 | 2022-10-03-15:40:41 | 30s | 0.0 | 24.0 | 0.0 | 0.5 |
1 | reset_1 | Pass | 1 | 100% | 2022-10-03-15:40:42 | 2022-10-03-15:40:45 | 3s | 0.0 | 0.0 | 0.0 | 0.0 |
2 | hardware_ping | Fail | 1 | 0% | 2022-10-03-15:40:46 | 2022-10-03-15:41:16 | 30s | 0.1 | 1.0 | 0.0 | 0.0 |
3 | io_ping_test | Pass | 1 | 100% | 2022-10-03-15:41:17 | 2022-10-03-15:41:20 | 3s | 0.0 | 0.0 | 0.0 | 0.0 |
4 | performance_alexnet | Fail | 1 | 0% | 2022-10-03-15:41:21 | 2022-10-03-15:41:24 | 3s | 0.0 | 0.0 | 0.0 | 0.0 |
5 | performance_densenet-121 | Fail | 1 | 0% | 2022-10-03-15:41:25 | 2022-10-03-15:41:28 | 3s | 0.0 | 0.0 | 0.1 | 0.1 |
6 | performance_googlenet-v1 | Fail | 1 | 0% | 2022-10-03-15:41:29 | 2022-10-03-15:41:33 | 3s | 0.0 | 0.0 | 0.0 | 0.0 |
7 | performance_mobilenet-ssd | Fail | 1 | 0% | 2022-10-03-15:41:34 | 2022-10-03-15:41:37 | 3s | 0.0 | 0.0 | 0.0 | 0.0 |
8 | performance_mobilenet-v1-1.0-224 | Fail | 1 | 0% | 2022-10-03-15:41:38 | 2022-10-03-15:41:41 | 3s | 0.0 | 0.0 | 0.0 | 0.0 |
9 | performance_mobilenet-v2 | Fail | 1 | 0% | 2022-10-03-15:41:42 | 2022-10-03-15:41:45 | 3s | 0.0 | 0.0 | 0.0 | 0.0 |
10 | performance_squeezenet1.1 | Fail | 1 | 0% | 2022-10-03-15:41:46 | 2022-10-03-15:41:49 | 3s | 0.0 | 0.0 | 0.0 | 0.0 |
11 | performance_resnet-50-pytorch | Fail | 1 | 0% | 2022-10-03-15:41:50 | 2022-10-03-15:41:53 | 3s | 0.0 | 0.0 | 0.0 | 0.0 |
12 | thermal_test | Fail | 1 | 0% | 2022-10-03-15:41:54 | Mon Oct 3 15:41:57 2022 | 3s | 0.0 | 0.0 | 0.0 | 0.0 |
Thanks & Regards,
--Julien
Hi Julien,
I have reached out to my peers for additional feedback, I will let you know what I find out.
Jesus
Hi Julien,
I was informed you are in contact with someone from the team directly. Please let me know if you still need assistance on this discussion or if we can proceed to close it.
Jesus
Hi Jesus
I am using a new “Accelerator Card with 8 x Movidius Myriad X” for the ESDQ test. I will share the update report soon. And yes, I still need an assistance. I haven’t received any updates recently.
Thanks & Regards,
--Julien
Hi Julien,
Sounds good, I will wait the test results.
Jesus
Hi Jesus
Attached, please check an update of the test report. With the “Intel Accelerator Card with 8 x Movidius Myriad X”, most of the ESDQ6.1 vision test passed. Except the script related to media sdk encode with h265 failed as shown below.
SystemInfo
0 | SOFTWARE INFO | OS version | Ubuntu 20.04.5 LTS |
1 | SOFTWARE INFO | Kernel | 5.15.0-50-generic |
6 | HARDWARE INFO | Memory size | 35Gi |
7 | HDD Configurations | Model | ATA INTEL SSDSC2BB08 (scsi) |
8 | HDD Configurations | Disk /dev/sda | 80.0GB |
9 | HDD Configurations | Sector size (logical/physical) | 512B/4096B |
13 | HDD Configurations | Disk Flags | 2 538MB 80.0GB 79.5GB ext4 |
14 | HARDWARE ACCELERATOR | VPU | 8 Intel® Movidius™ Visual Processing Unit |
ModulesInfo
Test Suites
Vision_Test_Module
0 | container_openvino | CPU1 | image_processing_demo CPU | Pass |
1 | container_openvino | CPU2 | object_detection_demo_python with CPU | Pass |
2 | container_openvino | GPU1 | image_processing_demo GPU | Pass |
3 | container_openvino | GPU2 | object_detection_demo_python with GPU | Pass |
4 | media_sdk | MSDK1 | Mediasdk_sample_decode with h264 | Pass |
5 | media_sdk | MSDK2 | mediasdk_sample_multi_transcode with h264 and mpeg2 | Pass |
6 | media_sdk | MSDK3 | mediasdk_set_commands with h264 mixed model | Pass |
7 | media_sdk | MSDK4 | mediasdk_set_commands with h265 mixed model | Pass |
8 | media_sdk | MSDK5 | mediasdk_sample_encode with h265 | Fail |
9 | media_sdk | MSDK6 | mediasdk_sample_vpp with sw | Pass |
10 | aws_greengrass | AWS1 | aws_hello_world_sample | Pass |
11 | k3s | K3S1 | k3s_sample | Pass |
12 | openvino | CPU1 | hello_reshape_ssd with CPU | Pass |
13 | openvino | CPU2 | style_transfer_sample_python with CPU | Pass |
14 | openvino | CPU3 | object_detection_demo_ssd_async CPU | Pass |
15 | openvino | CPU4 | object_detection_demo_python with CPU | Pass |
16 | openvino | GPU1 | hello_reshape_ssd with GPU | Pass |
17 | openvino | GPU2 | style_transfer_sample_python with GPU | Pass |
18 | openvino | GPU3 | object_detection_demo_ssd_async GPU | Pass |
19 | openvino | GPU4 | run_tc_object_detection_demo_ssd__python with GPU | Pass |
20 | openvino | HDDL1 | hello_reshape_ssd with HDDL | Pass |
21 | openvino | HDDL2 | style_transfer_sample_python with HDDL | Pass |
22 | openvino | HDDL3 | object_detection_demo_ssd_async HDDL | Pass |
23 | openvino | HDDL4 | object_detection_demo_ssd_async_python with HDDL | Pass |
VATS_Test_Module
0 | firmware_loading_time | Pass | 2 | 100% | 2022-10-18-11:09:36 | 2022-10-18-11:10:34 | 57s | 34.6 | 68.0 | 0.0 | 0.9 |
1 | reset_1 | Pass | 1 | 100% | 2022-10-18-11:10:35 | 2022-10-18-11:10:38 | 3s | 0.0 | 0.0 | 0.0 | 0.0 |
2 | hardware_ping | Pass | 1 | 100% | 2022-10-18-11:10:39 | 2022-10-18-11:12:24 | 1min 45s | 0.0 | 1.0 | 0.0 | 0.0 |
3 | io_ping_test | Pass | 1 | 100% | 2022-10-18-11:12:25 | 2022-10-18-11:12:28 | 3s | 0.0 | 0.0 | 0.0 | 0.0 |
4 | performance_alexnet | Pass | 1 | 100% | 2022-10-18-11:12:29 | 2022-10-18-11:13:39 | 1min 9s | 10.6 | 33.7 | 0.0 | 0.8 |
5 | performance_densenet-121 | Pass | 1 | 100% | 2022-10-18-11:13:40 | 2022-10-18-11:14:46 | 1min 6s | 6.8 | 21.0 | 0.0 | 0.2 |
6 | performance_googlenet-v1 | Pass | 1 | 100% | 2022-10-18-11:14:47 | 2022-10-18-11:15:51 | 1min 3s | 12.7 | 20.3 | 0.2 | 0.2 |
7 | performance_mobilenet-ssd | Pass | 1 | 100% | 2022-10-18-11:15:52 | 2022-10-18-11:16:58 | 1min 6s | 8.5 | 24.3 | 0.0 | 0.2 |
8 | performance_mobilenet-v1-1.0-224 | Pass | 1 | 100% | 2022-10-18-11:16:59 | 2022-10-18-11:18:03 | 1min 3s | 14.6 | 23.3 | 0.2 | 0.2 |
9 | performance_mobilenet-v2 | Pass | 1 | 100% | 2022-10-18-11:18:04 | 2022-10-18-11:19:10 | 1min 6s | 10.6 | 28.3 | 0.0 | 0.2 |
10 | performance_squeezenet1.1 | Pass | 1 | 100% | 2022-10-18-11:19:11 | 2022-10-18-11:20:15 | 1min 3s | 33.0 | 33.5 | 0.1 | 0.1 |
11 | performance_resnet-50-pytorch | Pass | 1 | 100% | 2022-10-18-11:20:16 | 2022-10-18-11:21:22 | 1min 6s | 5.9 | 24.6 | 0.0 | 0.5 |
12 | thermal_test | Pass | 1 | 100% | 2022-10-18-11:21:23 | Tue Oct 18 11:21:44 2022 | 21s | 5.7 | 33.3 | 0.0 | 0.3 |
Thanks & Regards,
--Julien
Hi Julien,
Glad the Vision Accelerator Tests are now working with the Hardware Accelerator! Looking at the test results and log files shared. The Media SDK encode sample is failing with the following error:
libva info: VA-API version 1.12.0
libva info: User environment variable requested driver 'iHD'
libva info: Trying to open /opt/intel/mediasdk/lib64/iHD_drv_video.so
libva info: Found init function __vaDriverInit_1_12
libva info: va_openDriver() returns 0
[ERROR], sts=MFX_ERR_UNSUPPORTED(-3), AllocFrames, Query (for encoder) failed at /docker/worker/mediasdk/build_dir/repos/MediaSDK/samples/sample_encode/src/pipeline_encode.cpp:964
[ERROR], sts=MFX_ERR_UNSUPPORTED(-3), ResetMFXComponents, AllocFrames failed at /docker/worker/mediasdk/build_dir/repos/MediaSDK/samples/sample_encode/src/pipeline_encode.cpp:2071
[ERROR], sts=MFX_ERR_UNSUPPORTED(-3), Init, ResetMFXComponents failed at /docker/worker/mediasdk/build_dir/repos/MediaSDK/samples/sample_encode/src/pipeline_encode.cpp:1852
[ERROR], sts=MFX_ERR_UNSUPPORTED(-3), main, pPipeline->Init failed at /docker/worker/mediasdk/build_dir/repos/MediaSDK/samples/sample_encode/src/sample_encode.cpp:1745
Frame number: 0
Encoding fps: -nan
mediasdk_sample_encode with h265 program Failed 253
Could you check if the steps mentioned in the follownig link address the issue?
Jesus
