Edge Software Catalog
446 Discussions
ESDQ5.0 Vision on Intel(R) Core(TM) i3-10100E CPU
jim-tech10
I have installed and run the Intel ESDQ package for vision on a target system (Processor: Intel(R) Core (TM) i3-10100E CPU @ 3.20GHz). After installation, some of the test modules Failed.
As shown in attachment, the modules “Intel Distribution of OpenVINO toolkit 2021 4 Runtime, Deep Learning DL Streamer Pipelines” have failed.
Attached, please check the logs and ESDQ test report generated. Would you please share your comments and suggestions about this issue.
ModulesInfo
Installed Module
Status
0
Amazon_Web_Services_Greengrass_Prerequisites
SUCCESS
1
K3s_Lightweight_Kubernetes
SUCCESS
2
Azure_IoT_Edge_Prerequisites
SUCCESS
3
Intel_Distribution_of_OpenVINO_toolkit_2021_4_Runtime
FAILED
4
Deep_Learning_DL_Streamer_Pipelines
FAILED
5
Docker_Community_Edition_CE
SUCCESS
6
Intel_Distribution_of_OpenVINO_toolkit_2021_4_Container
SUCCESS
7
edgex_foundry
SUCCESS
8
RI_MultiCamera_Social_Distancing
SUCCESS
9
esdq
SUCCESS
10
Docker_Compose
SUCCESS
Target System Information:
CPU: Intel(R) Core(TM) i3-10100E CPU @ 3.20GHz
OS: Ubuntu 18.04.5 LTS
Kernel: 5.4.0-125-generic
ESDQ Version: 5.0
Thanks & Regards,
Julien
(Virus scan in progress ...)
JesusE_Intel
Hi Julien,
The system you are using is a 11th Gen Desktop processor version with Intel UHD Graphics. I'm testing on a 11th Gen Mobile processor. I'll need to see if I can find a system to test ESDQ. In the meantime, could you make sure the graphics driver is setup and user permissions have been set?
Configurations for Intel® Processor Graphics (GPU) with OpenVINO™ — OpenVINO™ documentation — Version(2022.1)
Jesus
jim-tech10
Hi Jesus
I have tried this solution, but it didn’t work for me. The Media SDK encode sample is still failed.
8 media_sdk MSDK5 mediasdk_sample_encode with h265 Fail
Thanks & Regards,
--Julien
JesusE_Intel
Hi Julien,
My test enviornment has the same software version as your setup and the steps in the troubleshooting guide worked for me. I'll need to find a 10th generation system to test as I'm testing on a 11th generation system. In the meantime, please provide the output of the following command.
dmesg | grep guc
Jesus
jim-tech10
Hi Jesus
The output dmesg | grep guc of this command shows the guc details but submission is disabled, as shown in attachment.
The guide mentions the “Kernel of 5.4 and above needed to support 10th and 11th Gen Intel® Core™ processors.” Do you think that can be the reason for the MSDK5 to fail?
Thanks & Regards,
--Julien
JesusE_Intel
Hi Julien,
I believe your kernel version is 5.15.* so we should be good. I did some more testing on a 9th-generation system and I can reproduce the issue even after enabling the guc per the troubleshooting steps. Let me continue debugging and I will let you know what I find out.
Jesus
jim-tech10
Hi Jesus,
Thanks for the information. I will be waiting for your feedback.
Thanks & Regards,
--Julien
jim-tech10
Hi Jesus,
I have used a 11th generation system similar to your test environment. The MSDK5 test is passed but some of the GPU test have failed as shown in report.  Please let me know if you have any suggestions about these issues.
Would you please tell me also what type of CPU 11th gen. you have used for the test. For me I have used the “11th Gen Intel(R) Core (TM) i9-11900 @ 2.50GHz”.
Thanks & Regards,
--Julien
JesusE_Intel
Hi Julien,
Thanks for providing the ESDQ report, I see the following error when running the GPU tests. Is this a fresh system?
Traceback (most recent call last):
 File "style_transfer_sample/style_transfer_sample.py", line 150, in <module>
  sys.exit(main())
 File "style_transfer_sample/style_transfer_sample.py", line 89, in main
  exec_net = ie.load_network(network=net, device_name=args.device)
 File "ie_api.pyx", line 403, in openvino.inference_engine.ie_api.IECore.load_network
 File "ie_api.pyx", line 442, in openvino.inference_engine.ie_api.IECore.load_network
RuntimeError: Program build failed. You may enable OCL source dump to see the error log.
These are the specs to my 11th Gen system:
Processor: 11th Gen Intel(R) Core(TM) i7-1165G7
OS version: Ubuntu 20.04.5 LTS
Kernel: 5.15.0-52-generic
Did you have any issues during installation when installing the graphics driver? Do you know what driver version is currently installed?
Jesus
jim-tech10
Hi Jesus,
It is the same system with a different CPU: “11th Gen Intel(R) Core(TM) i9-11900 @ 2.50GHz”.
The GPU used is built in the processor.  Below please check the information about it:
product: Intel Corporation
vendor: Intel Corporation
physical id: 2
bus info: pci@0000:00:02.0
version: 04
configuration: driver=i915 latency=0
Thanks & Regards,
--Julien
JesusE_Intel
Hi Julien,
Jesus
jim-tech10
Hi Jesus,
The GPU test is passed after updating the graphics driver by following the link you shared.
Attached, please check an update of the ESDQ test report for the 11th Gen system. “CPU: 11th Gen Intel(R) Core(TM) i9-11900 @ 2.50GHz”.
Vision_Test_Module
  ModuleName Test CaseName SampleProgram Status
0 container_openvino CPU1 image_processing_demo CPU Pass
1 container_openvino CPU2 object_detection_demo_python with CPU Pass
2 container_openvino GPU1 image_processing_demo GPU Pass
3 container_openvino GPU2 object_detection_demo_python with GPU Pass
4 media_sdk MSDK1 Mediasdk_sample_decode with h264 Pass
5 media_sdk MSDK2 mediasdk_sample_multi_transcode with h264 and mpeg2 Pass
6 media_sdk MSDK3 mediasdk_set_commands with h264 mixed model Pass
7 media_sdk MSDK4 mediasdk_set_commands with h265 mixed model Pass
8 media_sdk MSDK5 mediasdk_sample_encode with h265 Pass
9 media_sdk MSDK6 mediasdk_sample_vpp with sw Pass
10 aws_greengrass AWS1 aws_hello_world_sample Pass
11 k3s K3S1 k3s_sample Pass
12 openvino CPU1 hello_reshape_ssd with CPU Pass
13 openvino CPU2 style_transfer_sample_python with CPU Pass
14 openvino CPU3 object_detection_demo_ssd_async CPU Pass
15 openvino CPU4 object_detection_demo_python with CPU Pass
16 openvino GPU1 hello_reshape_ssd with GPU Pass
17 openvino GPU2 style_transfer_sample_python with GPU Pass
18 openvino GPU3 object_detection_demo_ssd_async GPU Pass
19 openvino GPU4 run_tc_object_detection_demo_ssd__python with GPU Pass
20 openvino HDDL1 hello_reshape_ssd with HDDL Pass
21 openvino HDDL2 style_transfer_sample_python with HDDL Pass
22 openvino HDDL3 object_detection_demo_ssd_async HDDL Pass
23 openvino HDDL4 object_detection_demo_ssd_async_python with HDDL Pass
VATS_Test_Module
  Test ID Status Iterations Pass Rate Start Time End Time Duration Host Ave CPU (%) Host Max CPU (%) Host Ave Memory (%) Host Max Memory (%)
0 firmware_loading_time Pass 2 100% 2022-11-16-09:46:07 2022-11-16-09:47:04 57s 55.0 109.0 0.0 8.4
1 reset_1 Pass 1 100% 2022-11-16-09:47:05 2022-11-16-09:47:08 3s 0.0 0.0 0.0 0.0
2 hardware_ping Pass 1 100% 2022-11-16-09:47:09 2022-11-16-09:48:55 1min 45s 0.0 0.6 0.3 0.3
3 io_ping_test Pass 1 100% 2022-11-16-09:48:56 2022-11-16-09:48:59 3s 0.0 0.0 0.6 0.6
4 performance_alexnet Pass 1 100% 2022-11-16-09:49:00 2022-11-16-09:50:10 1min 9s 10.8 55.0 0.0 7.8
5 performance_densenet-121 Pass 1 100% 2022-11-16-09:50:11 2022-11-16-09:51:14 1min 3s 7.1 26.3 2.3 2.3
6 performance_googlenet-v1 Pass 1 100% 2022-11-16-09:51:15 2022-11-16-09:52:19 1min 3s 13.0 26.3 2.0 2.0
7 performance_mobilenet-ssd Pass 1 100% 2022-11-16-09:52:20 2022-11-16-09:53:27 1min 6s 9.0 26.6 0.0 2.2
8 performance_mobilenet-v1-1.0-224 Pass 1 100% 2022-11-16-09:53:28 2022-11-16-09:54:31 1min 3s 15.1 19.2 1.8 1.8
9 performance_mobilenet-v2 Pass 1 100% 2022-11-16-09:54:32 2022-11-16-09:55:36 1min 3s 11.2 27.3 1.9 1.9
10 performance_squeezenet1.1 Pass 1 100% 2022-11-16-09:55:37 2022-11-16-09:56:40 1min 3s 36.2 37.3 0.0 1.0
11 performance_resnet-50-pytorch Pass 1 100% 2022-11-16-09:56:41 2022-11-16-09:57:48 1min 6s 6.0 34.6 0.0 4.8
12 thermal_test Pass 1 100% 2022-11-16-09:57:49 Wed Nov 16 09:58:10 2022 21s 11.6 69.0 0.0 2.8
Thanks & Regards,
--Julien
JesusE_Intel
Hi Julien,
I took a look at the new report, everything looks good. I'm glad that resolved the GPU issue! I believe you still have an open issue with MediaSDK tests on the system with the 10th generation CPU. Last I heard is you were working directly with the engineering team.
Let me know if you are okay with closing this discussion.
Jesus
jim-tech10
Hi Jesus,
That is ok for now. I already updated the engineering team and waiting for their feedback. Thanks for your support.
--Julien
JesusE_Intel
Hi Julien,
Great, thank you! If you need any additional information, please submit a new question as this thread will no longer be monitored.
Jesus
