Edge Software Catalog
The Edge Software Catalog community is read-only. For support, please visit the Open Edge Platform (https://github.com/open-edge-platform) GitHub organization and post your question in the relevant repository’s Issues section.
492 Discussions
Failed to install Edge_Software_Manager
huang06
Software: Edge_Insights_for_Vision_2021.1
OS: Ubuntu 18.04.5 LTS
I try many times to install the Edge_Software_Manager, but encounter the same error message.
Nadia_J_Intel
Hi Huang,
Can you try this to reinstall the ESM module ?
$./edegesoftware update <ESM Module ID>
You can get the Module ID from this command:
$./edegesoftware list
Do update if the issue still persists.
Nadia_J_Intel
Hi Huang,
Thanks for reaching out to us. Can you provide us the specific log for the failed module - Edge Sofware Manager. You can use this command to get the log $./edgesoftware log <module id>
You can use the module ID of the Edge Software Manager from the image you provided.
huang06
The attached file includes the logs of Edge_Software_Manager, I hope it could help you analyze the problem, thanks.
Nadia_J_Intel
Hi Huang,
RaviKira
 I am facing the same problem. Is there any working solution?
 Tried to update, uninstall and reinstall too. Didn't work on Ubuntu 18.4 and 20.4 too
Verifying Edge Software Configurator [.. ] 4%
ERROR: Failed to connect to VM Agent
Setup Failed. Cleaning up ...
Log says
Thu Jun 03 03:46:49 IST 2021 - ERROR - Failed to get vm agent status with return code 200
/var/log/esb-cli/Intel_Edge_Software_Configurator_v3.0/Edge_Software_Configurator/components.log:
**************************************** Logs for service esm_vm-server ****************************************
esm_vm-server.1.gs38zhzieeji@ubuntu20 | |CONF | Application key found. Initializing postgres db uri...
esm_vm-server.1.gs38zhzieeji@ubuntu20 | |CONF | Failed to load file path: File not found: /vm-server/app/../../certs/server.crt
esm_vm-server.1.gs38zhzieeji@ubuntu20 | |CONF | Failed to load file path: File not found: /vm-server/app/../../certs/server.key
esm_vm-server.1.gs38zhzieeji@ubuntu20 | ^[[93m|SSH | hostkey not exist^[[0m
esm_vm-server.1.gs38zhzieeji@ubuntu20 | ^[[93m|RSA WARNING | RSA key not exist^[[0m
esm_vm-server.1.gs38zhzieeji@ubuntu20 | |RSA | New RSA key created
esm_vm-server.1.gs38zhzieeji@ubuntu20 | ^[[92m|RSA | RSA private key created: /opt/vm-server/.ssh/vmserver_key^[[0m
esm_vm-server.1.gs38zhzieeji@ubuntu20 | ^[[92m|RSA | RSA public key created: /opt/vm-server/.ssh/vmserver_key.pub^[[0m
esm_vm-server.1.gs38zhzieeji@ubuntu20 | |MAIN | VM Server status: True
esm_vm-server.1.gs38zhzieeji@ubuntu20 | |MAIN | Verifying database url...
esm_vm-server.1.gs38zhzieeji@ubuntu20 | ^[[94m|MAIN | Start VM Server^[[0m
esm_vm-server.1.gs38zhzieeji@ubuntu20 | ^[[92m|DB | Database connected^[[0m
Ravi Kiran
