Edge Software Catalog
The Edge Software Catalog community is read-only. For support, please visit the Open Edge Platform (https://github.com/open-edge-platform) GitHub organization and post your question in the relevant repository’s Issues section.
Installing desktop
grandixximo
https://eci.intel.com/docs/3.0.2/development/desktop_env.html
After building and installing ECI core image core-bullseye
I follow instructions to install desktop environment.
After sending the apt command to install mate or xfce desktop environment, it seem to want to remove init and systemd, and requires me to type "yes, do as I say!" To continue
If I do, it fails with too many dpkg errors, related.tk removing systemd
JesusE_Intel
Hi grandixximo,
Apologies for the delay, this took longer than expected. I was able to install the desktop environment using the steps below. Could you please give it a try and let me know if it works for you?
sudo apt update
sudo apt install sysvinit-core systemd-sysv-
echo "auto enp0s3
iface enp0s3 inet dhcp" > /etc/network/interfaces.d/enp0s3
reboot
sudo -E apt install task-desktop task-mate-desktop
reboot
Jesus
JesusE_Intel
Hi grandixximo,
Thank you for reporting, I was able to reproduce the same error message. Let me take a deeper look and get back to you as soon as possible.
Jesus
grandixximo
Are you still looking into this?
JesusE_Intel
Hi grandixximo,
sudo apt update
echo "auto enp0s3
reboot
reboot
Jesus
grandixximo
Yes, it does work
I would just like to add before echo the network config, you should send
ip a
that will list your devices names, and you should change enp0s3 in the command for whatever device you have hooked up to the internet.
also after successfully installing the desktop packages, use
rm /etc/network/interfaces.d/*
command to delete the file that was created from the echo command.
JesusE_Intel
Thanks for providing the additional steps, glad that worked for you. If you need any additional information, please submit a new question as this thread will no longer be monitored.
