Edge Software Catalog
486 Discussions
Intel ESDQ ECI download package & no such command module issue
Geen
Dear Sir
I refer to the below link:
https://www.intel.com/content/www/us/en/developer/articles/technical/edge-software-device-qualification-eci.html
Linux wpi 5.10.0-32-rt-amd64 #1 SMP PREEMPT_RT Debian 5.10.223-1 (2024-08-10) x86_64 GNU/Linux
After run the step by step , i have two questions as below:
Q1:
I follow the below step  , but can not  get the package.
"Sudo apt install rtpm"
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
E: Unable to locate package rtpm
All RTPM dependent modules are installed.
  • For Xenomai patched Linux.
    • sudo apt install rtpm-xenomai
  • For Preempt-RT patched Linux.
Q2:
I try to use the below command .
"./esdq module list"
But show the following info
Usage: esdq [OPTIONS] COMMAND [ARGS]...
Try 'esdq --help' for help.
Error: No such command 'module'.
Get RTPM test module ID:
./esdq module list
  1.
            Example output:
Do you have any suggestions about it ?
JiaYiChin
Hi Geen,
To resolve your Q1, can you install the ECI package?
Please follow the instructions in the ECI documentation at Install ECI Packages — ECI documentation (intel.com). After that, you can install the RTPM package by running the following command:
To resolve your Q2, use "esdq module list" to get the module list output.
Iffa_Intel
Thank you for your question. If you need any additional information from Intel, please submit a new question as Intel is no longer monitoring this thread.
Cordially,
Iffa
