Edge Software Catalog
The Edge Software Catalog community is read-only. For support, please visit the Open Edge Platform (https://github.com/open-edge-platform) GitHub organization and post your question in the relevant repository’s Issues section.
492 Discussions
[Robotics SDK]Fail in run_tc_kudan_slam_cpu and run_tc_kudan_slam_gpu
milian1
Hi Sir,
I'm encountering fails in run_tc_kudan_slam_cpu and run_tc_kudan_slam_gpu.
However, in the logs, all I can check is the message, "RuntimeError: Unable to read position/orientation from /tmp/topic_echo_pose.yaml". I've checked and found that there's no content in /tmp/topic_echo_pose.yaml.
Not sure is this runtime error or something else cause the fail of these two test items, may you give some advices to handling these failures? Thank you.
P.s. Attachment: RoboticsSDK_output_20250514.zip contains the whole logs and .csv files of test result and logs.
Milian
JesusE_Intel
Hi Milian,
I received an update from the product team: Kudan will no longer be distributed through our SDK, although we don't have an ETA yet. I understand this may not be the outcome you were expecting, but I wanted to share the news with you as soon as possible.
Jesus
milian1
Hi Sir,
Additional information for the test environment:
CPU: 12th Gen Intel® Core™ i5-12500E.
OS: Ubuntu 22.04.2 LTS
Kernel: 5.15.0-1078-intel-iotg
All installation commands are follow: https://amrdocs.intel.com/docs/2.2/gsg_robot/index.html
Milian
Peh_Intel
Hi Milian,
For your information, Intel® Robotics SDK only extended license validity for Kudan Visual SLAM until end of February 2025. This statement is available in Release Notes.
Based on your run_tc_kudan_slam_cpu-log.txt and run_tc_kudan_slam_gpu-log.txt, in the Line 32, you can notice that it failed to load license due to expired.
Full error message as follow:
[kdvisual_ros2]: Failed to load license: Missing or invalid license file! Pass file path to Kd::Visual::Slam or Kd::Visual::MapOptimiser constructor. License has expired (-3)
Peh
milian1
Hi Peh,
Thanks for your explanation!
Will Intel release a new version of Robotics SDK that extend license validity for Kudan Visual SLAM, or is it okay to submit the report with  run_tc_kudan_slam_cpu and run_tc_kudan_slam_gpu fail?
Milian
Peh_Intel
Hi Milian,
Let me check with the engineering team and get back to you at the earliest.
Peh
milian1
Hi Peh,
Is there any update for this case?
Milian
JesusE_Intel
Hi Milian,
I apologize for the delay. I have escalated this issue to our development team and will keep you updated as soon as I have more information.
Jesus
milian1
Hi Jesus,
Appreciating for your reply!
Since there's almost a month since I post this issue, here I would like to check the process.
Is there any update on your side? thank you.
Milian
JesusE_Intel
Hi Milian,
I apologize for the delay in our response. I have followed up with the product team, and they informed me that they are currently working on updating the license. Unfortunately, I don't have an estimated time of completion at the moment. I will update this thread as soon as I have more information. Thank you for your patience.
Jesus
milian1
Hi Jesus,
Thanks for your reply again!
Though there's no estimated time, it's still a great news that your product team will work on updating recently:)
Milian
JesusE_Intel
Hi Milian,
Jesus
milian1
Hi Jesus,
Thanks for letting me know!
Since there's no ETA, I think I'll submit the test report with Kudan-related tests failed (others are pass).
Sincerely thank you and Peh for following up this issue.
Milian
JesusE_Intel
Hi Milian,
No problem, please feel free to start a new discussion if you need any additional help as this thread will no longer be monitored.
Jesus
